Microsoft Xbox 360 Console Logo
Posted on Jul 21, 2008
XBox 360 No Sound
Everything is fine except no sound any advice
  • 6 more comments
  • mrsheridan29 Oct 07, 2008
    everything works apart from sound checked leads and settings for both tv and xbox 360 and tryed lense cleaners all to no avail please please help me?!
  • Anonymous Oct 27, 2008
    i connect my xbox 360 through hdmi and the picture is fine but no sound. i tried with different hdmi cable and still no sound. i switch to component and stereo audio and still no sound...help
    P.S. it work fine before.
  • bogeygolf316 Dec 07, 2008
    my 360 works fine on the bedroom tv with monster hdmi, but no sound on the living room tv with the supplied microsoft hdmi.
  • Anonymous Jan 04, 2009
    Microsoft is aware of the problem. Occurs via HDMI. Component cables should work until the fix comes out. Many reports are people using Vizio TV's (like me).
  • Anonymous Jan 11, 2009
    i have a problem like this but its the console thats faulty.
  • Anonymous Jan 30, 2009
    I know my hdmi cable is good because I can hook my friend's 360 to it and their console gets sound, but mine still does not.
  • t-man2304 Jan 31, 2009
    I just switched TV's and I plugged in my xbox 360. It has no sound but the picture is fine. I'm using the HDMI cable because I can't find the one that connects with the jacks. If I plug it into my other TV which is not very old, it works fine. We tried a DVD player on the TV and there was sound. Ive fiddled with everything that has to do with sound in the menu. Help?
  • Anonymous May 01, 2009
    I just swapped from an old 360 to a newer one with HDMI (not an elite) and have connected via HDMI but have an amazing picture with no sound.
    Connecting my blu ray laptop to the TV works fine having changed the sound output of the laptop to HDMI, is there a similar fix on the Xbox that I have missed??
A
Anonymous
I have had the same problem with 2 microsoft hdmi cables..
used another and all ok
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 08, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
5175
Points
No sound but picture
Anonymous
Level 1:
  • Posted on Nov 28, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5175
Points
Just moved unit to new location. Everything is good but no sound!
Xbox 360 working thru HDMI working fine. Now no sound & weird pic
it is prolly an internal problem. have to tried connecting the componet cables?
3helpful
2answers
I cannot connect to xbox live because my xbox360 cannot find my network
i had this exact problem. the reason mine wasn't working was because the security settings for my wireless router were set on wp2a and the xbox 360 can't pick this up. change your wireless router security to wpa and you should be fine...after i did this it saw my network and i was fine
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Sound
I'm almost positive the problem is the audio cable. If everything else is working fine, you'll need to replace the audio/video cables. I've had that problem and I just bought the new cables and it worked like a beaut!
Still need help? Let me know!
Olivia~*
Xbox 360 Video Problem
Have you adjusted your tv settings at all, rather has anyone screwed aroung with your tv?
Surround sound not working properly
this isnt a solution to your problem but i have a suggestion. I see this problem has been posted a couple days now and i think that because your problem looks like it involves more stereo equipment rather than the xbox 360 console. i think you would get a better answer actually a soltuion if you posted this in the stereo section.
4answers
Xbox 360 has sound but no picture on HD setting
Is the tv rated for HD? if its not the inputs will be at a wrong voltage and will create that snow like effect.
Is the TV you normally game on HD?
Dvds playing on the xbox 360
read this first:
http://forums.xbox-scene.com/index.php?showtopic=610277
2answers
XBOX 360
The problem is probably that you have put the cords in the wrong places or have used the wrong cords
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
