Question about GE Heating & Cooling
A/C fan motor burnt; I replaced it, and it will not keep runing very long.
I have an old GE Central A/C condenser & 1/6 hp fan motor. Where can I fine a manual for GE Model #BTN936A100B2 condenser, and wiring diagram?
  • 3 more comments
  • weglass2 Jul 22, 2008
    An official from G.E. Manufacture advised GE sold their Central A/C unit to "Trane" in 1982; the same official said Trane A/C Mfg purchased all manuals rights etc. I still have a problem as to why the fan motor runs for a short time and stops?
    My estimated 30 yr. old central a/c condensor fan motor burnt; I replaced it and clean the condenser coil & replaced the blower motor air filter. Now the new fan motor runs about 10 minutes and stops; the compressor keep runing. What is the probable cause, and how can I correct the problem?
    I purchased a new capacitor for the fan motor; the new A.O. Smith ele. motor replaced the burnt out GE motor. The GE motor wiring colors are purple, black, brown and red. The A.O. Smith Motor wires are tan, tan/white, black, yellow. I'am not sure I have the new capacitor wired correct. ???
    The original repair manual/operating manual cannot be located. What can I do to check my wiring connections to be sure they are connected correctly?
    My issues with the GE A/C has not been resolve. Maybe I need a troubleshooting chart; where can I obtain one?
    Master:
  • 848 Answers
It sounds like you'll probably need a capacitor .......
Posted on Jul 22, 2008
    Brigadier General:
  • 6,966 Answers
Pls try and confirm:
on the old GE motor:
  • Red = low speed
  • Black = high speed
  • Purple (or white) = common (capacitor if only 1 brown)
  • Brown = run capacitor (2 wires)
on the new A.O. Smith Motor
  • tan = capacitor
  • tan/white = common/capacitor
  • black = high speed
  • yellow. = low speed
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • GE Master
  • 13,433 Answers
See if you can find the manuals from here
http://www.geappliances.com/service_and_support/literature/
  • Ekse Jul 22, 2008
    Check with trane for the manual
    http://www.trane.com/Corporate/Contact/i...
    other than that, press on repost the problem / request more assistance, to get more help from other experts as I only jumped at this for knowing where the manual should have been at.
    Thanks,
    Ekse
    Genius:
  • 2,028 Answers
Manuals for these may be near impossible to find considering the age of the unit. I couldn't find anything on line. Your fan problem may lie with the thermostat control. Check the thermostat wiring at the unit end.
Connecting replacement fan motor in HP condenser
What is the model number of the heat pump? What is the voltage that you are dealing with?
Nov 26, 2013 | Carrier Heating & Cooling
My old motor on my central air unit has 4 wires and my new motor has 5 wires. wich brown wire do I use and what do I do with the extra one
There should be a wiring diagram on the side of the motor. Usually when you have two brown wires they connect to the terminals on the capacitor.
May 05, 2012 | Emerson Condenser Fan Motor 1/6 Hp 230v...
The condenser fan motor has stopped working for the 3rd time. This unit is only 10yrs old.We have already replaced it twice.
Is it the motor or capacitor? If the capacitor is bad the motor won;t run, it will just hum or run real slow.
If it is the motor and it's the 3rd one then you need to go to a more heavy duty motor, for instance if it's a 1/4 horse power then go to a 1/3 hp. etc.
May 31, 2010 | Ruud Central System Air Conditioner
Cooling fan in condenser sometimes does not run.
Shut off the power before inspecting or repairing! I would check the wiring harness inside the condensor unit for loose connections and or broken wire first. Then you might try removing the capacitor to the fan (some operate both the fan and compressor) and have it tested. If all is OK then your fan motor is probably overheating and may need replaced. A bad capacitor can cause the motor to overheat. If you had a lightning storm just before the problem the capacitor is most likely the problem.
Aug 05, 2009 | Heating & Cooling
I have a GE central air conditioner model
If you are talking about the indoor fan it is probably a bad capacitor. Replace the fan motor capacitor. And YES, if the fan motor needs replacing too, you can DO-IT-YOURSELF.
Jul 05, 2009 | General Electric Heating & Cooling
Goodman CKL60-1 Condenser Fan Runs OK, then stops
check connections tightness or if you just change the connector will solve the problem that is if the motor has not burn out yet
May 28, 2009 | Goodman CKL60AR60 Air Conditioner
Fan motor on the condenser runs a short time and stops.
Please go to your premium problem
http://www.fixya.com/support/t815660-c_fan_motor_burnt_replaced_will_not
click on repost / request more assistance.
I posted you a solution becouse I knew where the manuals should have been at, but if they are not there. theres noting else I can offer you myself.
Please repost the problem so another expert can respond to your problem.
click on request more assistance or repost the problem im not sure what it looks like on your side.
Jul 22, 2008 | Heating & Cooling
GE Central A/C Unit about 30 yrs old; condenser fan stops after a short time.
I gather that it is the outdoor fan motor that runs a bit then stops.
Fan motors that stop by themselves are overheating and going into self-protect. The fact that you replaced the motor and capacitor opens up a whole world of "which wire is in the wrong place". I could do this if I could see it, but I can't see it. You're probably going to wind up calling a service man to sort out the wiring.
Heating & Cooling Logo
810 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
