Question about Maytag Refrigerators
My top freezer and the refrigerator part isn't getting cold ican here the fan.I turned it off and back on that didn't help.Do i need to buy a new one?
I had to buy a new one.
Posted on Jul 22, 2008
Freezer fan is not turning....freezer is cold, but fridge is not. Tried to turn fan with my finger & it's very hard to turn
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Sep 09, 2011 | Roper RT21SKXLQ Top Freezer Refrigerator
I have a Sub Zero 690 (June 1999 model). The frig size light switch went out. We popped it out to test to see if it had continuity (it didn't). We put it back in and planned to call service guy to...
remove the top light cover,hold in the other switch that's next to the light switch,the fan should turn on,it sounds like the fan isn't working,go back up top,remove the metal cover that's above the switches and see if you knocked the wire off of the fan switch.why can't you see the control panel?did it go out when you touched the light switch?
Sep 04, 2011 | Sub-Zero 690 Side by Side Refrigerator
Hi, I have a Samsung refrigerator and the top part isn't cold enough and the freezer is working perfectly fine. I need help fixing the fan.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 03, 2011 | Samsung Refrigerators
Hello, My fridge side of my hotpoint model # Hsm25gftc sided by side fridge/freezer isn't getting cold anymore. I purchased it in 2007 I believe. I've tore the ice maker and tray out and pulled...
if the freezer is working fine it sounds like you could have a bad damper control,also there's another thing i want you to check first,hotpoint is a g.e. product,they have sensors in the machines,you said you had the back wall off,take it off again and on top of the evap coil you'll see a sensor,it looks like a white bullet with two whits wires going to it,look at it and if where the wires connect to it it has a black ring around it you have to change it out,also ther's one of these sensors in the fidge section too,it senses how cold the fridge is and tells the damper door to open and close,it sounds like your damper is staying shut,the part number for the temp. sensors are WR55X10025 and it's like 8 dollars,if they have the black ring on them they most likely are your problem,the new sensors are all white,if you have the white sensors then you could have a bad damper.go to this site,it's sears site http://www.searspartsdirect.com/partsdirect/part-model/Hotpoint-Parts/Refrigerator-Parts/Model-HSM25GFTCSA/1811/0165000/H0712760/00006?blt=06&prst=&shdMod= go to the fresh food diagram and look at the damper and the sensor,one of these parts are badmalso g.e. has had alot of problems with the mother boards,the computer board in the back of the fridge,if the condenser fan and evap fans are running fine and the freezer is fine then i would replace the damper and the sensor but change out the sensor first because it's 8 bucks,if that doesn't do it then buy the damper,all it does is the fan blows cold air from the freezer to the fridge section,if the damper isn't opening the air can't enter into the fridge section.hope this helps and points you in the right derection,let me know how you make out,good luck salde
Aug 12, 2011 | Hotpoint HSM25GFRSA
We have a Kitchenaid superba side by side. The freezer is working fine, but the refrigerator isn't cold. I have vacuumed the coils at the top of the model, but didn't solve the problem. I can...
The cooling normally comes from the freezer side, through cooling tubes. There should be a fan either blowing or sucking the air through these cooling tubes. So the first thing you should do is verify that the evaporator fan is turning and then see if you feel air flow in both compartments. If you have air flow in the freezer but not the refrigerator side, then the cooling tube must be blocked.
Most of the time the blockage is ice or frost, and you will need to open up the inner back panel of the freezer to get to the cooling tube. Look for an opening under the evaporator. Suggest a hair dryer to defrost the tube.
Jul 15, 2011 | KitchenAid Refrigerators
Whirlpool ET18NK fridge does not get cold but freezer is ok. I took off the freezer back panel -- the fan behind it isn't working.
Hello, Thank You for using FixYa. I will be helping you today. Check to see if the fan is getting 120 volts when the compressor is running if it is replace the fan motor part w10189703
Thank You and please rate my answer if it was helpful..
Jun 21, 2011 | Whirlpool ET8GTKXKQ Top Freezer...
The top of the freezer part is getting cold but the bottom of the Refrigerator part is not getting cold. The Refrigerator is only 10-11 months old ; what is wrong?
you need to check and see if the fan in the back of the freezer compartment is running. when the fan is not running the cold air will not be passed to the refrigerator compartment. open the freezer door and turn the unit to its coldest setting until the compressor kicks in then listen to hear the fan in the freezer compartment.
Sep 16, 2009 | Refrigerators
Freezer comparment will freeze OK, but fridge does not get cold.
If the freezer is working properly, and the fridge is not, it is usually the evaporator fan. It should be located behind the back panel in the freezer. Usually, a fan blade is stuck, or the motor is stuck on it's bearing. You may need to reposition the fan or apply some oil to the bearing. If you cannot get the fan to spin, you might need a new fan motor. Check the voltage first before buying a new motor. You should get around 110V AC .
Dec 31, 2008 | Hotpoint  16.6 Cu. Ft. Top-Freezer...
GE TFX 22CR Freezer works but not Refrigerator.
If the evaporator fan isn`t working, the frig will not circulate the cold air needed from the freezer to the fresh food compartment. You will need to remove the panel and check for ice around the fan. Make sure it can turn free. If it isn`t blocked and you can turn it freely and there is voltage going to it, the fan motor has gone bad and needs to be replaced if there.
Nov 11, 2008 | Refrigerators
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
