Question about Whirlpool Refrigerators
Emptied ice bin compleatly and it never made ice again
  • 13,433 Answers
Is it running? and cold enought? Try adding some water manually and see what happens.
Posted on Jul 21, 2008
Once full, ice melts and then doesn't start making ice again until bin is completely empty
There should be a temperature sensor (thermostat) close to the top of where the ice comes out of. This determines the height of the ice in the bin by controlling a call for cooling/making ice. This thermostat may be sticking, or is not sensitive enough to read the drop in temperature of the depletion of ice.
Feb 27, 2015 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Tip
Ice maker stopped working
When the ice bin fills up, it won't let the arm all the way down. The arm must go down for more ice to drop into bin. Sometimes an ice cube or two will get caught under the arm and prevent it from cycling. Continuing to use the ice maker will empty bin but no new ice is made. Clear any ice cubes from under the arm and the cycle will start again. My ice maker takes about twelve hours to fill after it has been emptied but ice from the door is available almost imediately.
on Aug 23, 2010 | Refrigerators
Whirlpool refrigerator ED5RHEXMT00 makes plenty of ice but is not dispensing any when the door lever is pressed. The water part is fine.
The ice bin slides down in little tracks and the drive mechanism engages the auger. It sounds like you have frost build-up in the bottom of the little slots that the ice bin rests in. The build-up keeps the drive from engaging the auger. I use a hair dryer to defrost all the accumulation under the bin once it is removed. Remove the bin by tilting out and then lifting up and out at an angle. Also empty the bin of ice cubes and check underneath for ice build up on the bottom of it too.
Dec 10, 2014 | Whirlpool Refrigerators
Portable emerson ice machine
The sensor in the bin that detects the ice to tell if its full could be bad. That or the control board.
May 12, 2013 | Kitchen Appliances - Others
Stopped making ice
Usually, the water line to the ice-maker is frozen. If you defrost the freezer, it should work again.
Aug 22, 2009 | Refrigerators
Ice Melting
ok check the door gaskets they must be toushing forming a compleate seal nothing else is acceptible also there is a possibilty that your ice maker heater is stuck in the on position.also these units are known for a having a bad control boared in the back
Aug 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a Whirlpool refrigerator model et22dq. The ice maker makes ice and dumps it but won't dispense thru the door. It seems to freeze in the ice bin. Could there be a water leak inside the ice maker?...
The ice door located in the ice chute in the door is not closing. Allowing wam air in your ice bin which melts the ice at the bottom of your bin there for making a huge ice dam. Replace cirercut board at cost of 295.00
Nov 21, 2008 | Whirlpool Refrigerators
Ice making problem
There is a metal wire that gets pushed up when the Ice becomes too full and turns off the ice maker. You can pull it back down with you hand and that will unlock it and turn the ice maker back on.
Sep 25, 2008 | Refrigerators
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
