Sylvania tv model 6719DG VCR DVD won't turn on
Last night I went to turn the TV on. The two little green lights in the center of the button cluster at the bottom came on, went out, and nothing..The set won't turn on, tried different (working) outlets, tried the remote. I have been unplugging the set and the antennae when not in use. The lights came on when it was plugged in.
I have dial-up, so I might not be "right there"
Thanks, Nancy
  • 13,433 Answers
Well first thing to check is your warranty still valid? If you still got warranty on the unit send it in for repairs / replacement.
Maybe a fuse blown, seems there is no high voltage as the screen doesn't turn on? I would suggest getting a experienced user or a tech to look at it, as there are dangerous voltages inside.
Posted on Jul 21, 2008
  • 6,487 Answers
There may be a cold solder joint, in the video processing or CRT bias paths to start with. The changing of the brightness may be the high voltage multiplier. In your set, it is most likely integrated with the flyback transformer, and all are replaced as a module.
You can try to rotate the G2 or bias pot back and forth a little in case it is sitting on a sort of intermittent spot, but more than likely the HV multiplier section is bad.
Hope that helps.........
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
Tip
Dish Network Combo TV/DVD Remote Codes
CODE Broksonic TV/VCR 748 Goldstar TV/VCR 747 Panasonic TV/VCR 747 Quasar TV/VCR 747 Samsung TV/VCR 738, 755 Sylvania TV/VCR 756 Zenith TV/VCR 747 Aiwa TV/DVD 751 Apex TV/DVD 757 Broksonic TV/DVD 752 Konka TV/DVD 753 Panasonic TV/DVD 734, 765 RCA TV/DVD 749 Sansui TV/DVD 754 Sylvania TV/DVD 764 Toshiba TV/DVD 750 Go Video DVD/VCR 692, 693 JVC DVD/VCR 689 RCA DVD/VCR 690 Samsung DVD/VCR 738, 667, 691 Sony DVD/VCR 768
on Jun 06, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
How to change sylvania tv to video without remote
I was able to get the Sylvania TV to accept a different input (the remote was lost) by connecting the DVD to a Sony VCR using composite RCA jacks then connecting that to the TV. You'll need two 3-jack (yellow, white, red composite) cables - cheap at any store. Here;s how:
1. Connect RCA output jacks from the DVD to the input female receptacles of the VCR (first cable).2. Connect output jacks from VCR to the female input jacks on TV (second cable). 3. Turn on all equipment (VCR, DVD, TV)4. Switch the VCR to "Line 1" (for my Sony VCR, this shows up as "L1") by pressing the TV/VCR button on the VCR remote (which I did have).
Your system should now work.
The principle is to "fool" the TV into thinking that it's primary input is through the RCA composite A/V jacks rather than the cable connection. No need to disconnect the cable at any time. Any functioning VCR should work well as long as you have the remote for that device. Remember, connect output on the DVD to the input on the VCR, then the output on the VCR to the input jacks on the back of the TV. If you have the connectors on the TV, VCR, and DVD, component cables should work as easily. Remember, output from the DVD goes to the input of the VCR. Theoutput from the VCR (for which you DO have the remote) goes to the input side of the TV.
Apr 07, 2012 | Sylvania Televison & Video
I am trying to get a remote code for my slyvania 6719
I also can't find the remote for my Sylvania
TV/VCR/DVD combo...
Model number 6719DF. I don't normally use this tv
(it's an extra spare that I plug into our generator when
the power goes out... since our regular family TV is
quite big and set into the wall making it difficult to
track cords around, I drag this crappy Sylvania down
from our dining room to our family room) I did
happen to find an old Zenith universal remote that
does work with it in some ways (See directions
below). I can turn the TV on and off, set the channels,
language, clock.. etc through the Input select button
on the universal remote but can't set to "Game Mode"
after using connections with video/audio input cords
plugged into the front panel of the TV. So
Playstations, extra dvd players or vcr's, etc won't
work.
Switching from the VCR to DVD and vice versa does
require manually setting the tv itself (remote doesn't
work with that) but at least I can set sub titles, fast
forward through chapters on Dvd's and control the
volume, etc without having to constantly walk over to
the tv.
Programming the remote: I've noticed a lot of people
have tried using codes supplied by different universal
remote providers and couldn't find a code that
worked using their lists with this particular model...
there is a way that it can be done but it's a bit more
time consuming:
Many types of "universal" remotes give the option of
"scanning" the electronic device for a code if one is
not available or the one provided with lists does not
work... Every universal remote though needs certain
buttons pushed during the "scan" and they are all
different! Ha! So if you lost or misplaced the MANUAL
as well (like me!) you might need to do a search on a
manual for your particular universal remote, but I can
at least give you directions on programming a
"Zenith" Universal remote to "scan" for a Sylvania
TV/DVD/VCR combo model 6719DF:
Using the Zenith Universal Remote or any Universal Remote using it's "scan" method:
1: Shut off the TV
2. Press and hold "Code Search" on the remote until
the red LED
light lights up and stays lit.
3. Press the device button for the device (In my case,
for my crappy Sylvania combo, I pressed "TV".)
The LED light will blink once.
4. Scanning: Slowly press and release the "Power"
button on the remote, waiting a few seconds between
while watching the TV to turn on. It's very important
that you pause in between because if you do it too fast
and the TV turns on before you press the power
button again... you'll have to start all over. I've
learned that lesson.
It took 160 presses each time on that button to get the
correct code scanned! I had to do it over 3 times
before I stopped myself beforehand because I was
pressing it too quickly..
5. Right after the TV power turns on, press the "Mute"
button on the remote to set the code. It should work with few limitations (no "game" mode)
after that.
May 26, 2011 | Sylvania 6719DF 19" TV/VCR/DVD
I need the programing code for a sylvania tv
Give these a try.
SYLVANIA ..........0062 0004 0009 0135
......................0189 0183 1141 0227 0456
......................0008 0068 0075 0141 0161
Or these:
Sylvania
004, 006, 008, 019, 062, 068, 069, 074, 075, 076, 077, 088, 116, 161, 183, 184
And incase you need the programming instructions, here ya go!
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to
program.
2. Press and hold the CODE SEARCH/SETUP button on the remote
until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming
(TV, VCR, DVD, etc.). For AUX, press AUX then the device button
you are assigning to AUX. The INDICATOR LIGHT will blink then
remain lit.
4. Enter the three or four digit code for your device using the number
buttons in the GE Universal Remote. After your code is entered the
INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the
POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed,
repeat steps with the next code. If none of the codes listed for your
device work for your device or your brand is not listed, try the Code
Search method described below.
Aug 22, 2010 | GE JASRM24912 Remote Control
Sylvania tv model # ssc719c
I had the same problem programming my directv remote to recognize the ssc719c. What finally worked was programming AV1 (not 'TV') with the sylvania DVD code 20821. This allowed me to turn the tv on and off and change tv channels, but wouldn't allow me to mute or change the volume. To fix this, (at least in my case) you have to program your remote to recognize the volume and mute buttons in the AV1 slide setting. I assume other (non directv) remotes similarly disable the volume and mute buttons when the remote is not in satellite or tv mode. Anyway, here are the instructions that activated the volume & mute buttons on my remote: "Depending on how you set up your remote, the VOL and
MUTE may control the volume only on your TV, regardless
of the position of the MODE switch. This remote can be set
up so that the VOL and MUTE keys work only with the
component selected by the MODE switch. To enable this
feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Now the VOL and MUTE keys will work only for the
component selected by the MODE switch position."
To sum up: if you find a code for your remote that will turn your tv on and off, but doesn't seem to do much of anything else, it's probably the right code; your remote is probably set up not to recognize volume or mute inputs in AV1 or AV2. You change that using a remote-specific code that's probably found somewhere on the remote maker's website.
Jan 31, 2008 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Akai model ws-p28ntf-sf-d-gb (s) tv/dvd combo
I believe you either have a problem with your Power Supply inside your TV from a defective component in the circuit or you have a problem with the Picture Tube on your TV. I don't recommend you working on TV's by yourself unless you know what you're doing since you can get badly shocked. You need to discharge the Picture Tube on the TV before you work down any further. If you don't know what you're doing then you should get someone that knows what they're doing to work on your TV.
Jan 20, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
