Question about Canon CanoScan N1220U Flatbed Scanner
I suppose there are no drivers available yet, or ever, for Windows 7
    President:
  • 1,932 Answers
Yes there is no drivers for windows 7 yet.Sorry
thank You
Posted on Feb 06, 2011
SOURCE:
Gaterway zx4951 multimedia drivers will not load...how
The Gateway website lists Win 7 drivers for the 64-bit OS. Are you trying to load a 32-bit OS instead? That's the only issue I could see being a problem here.
Oct 20, 2014 | Computers & Internet
I purchased a desktop computer with Windows 7 and need to install a wireless USB adapter. I've purchased two wireless adapters and both came with a small CD from Realtek Semiconductor supposedly with
Download available to fix realtek usb driver errors. Recommended: To repair realtek usb driver errors, use this software package: RegCure Pro. This repair tool has been proven to identify and fix realtek usb driver errors and other Windows problems with very high efficiency.
Download Now
File Size 5.6MB Requirements Windows XP / Vista / 7 / 8 Downloads Over 500,000 Download Time Broadband: 6 sec / Dial-Up: 3 min End User License Agreement
Uninstall Instructions
Apr 17, 2014 | Realtek Semiconductor Computers & Internet
Looking for driver MF5630 canon Win_64
I have spent hours to find a solution... there is no driver. But there are definitely 2 solutions:
1. MF5630 - using ONLY printer in Win 7 x64:
You have to use the drivers for MF5700 Series - http://driverscollection.com/?file_cid=4213082682609f383f81540957d
- http://www.techulator.com/resources/4156-How-add-Printer-manually-your-Windows.aspx
1. First, Click on the Start button in your screen, further click on Control Panel button and then double click on Devices and Printers button.
2. Then click on Add a Printer button in the menu.
3. Further select the Add a local printer button from the available menu.
4. Then choose an existing LPT port and click Next button .
5. Further select the correct driver from the driver list menu for your printer. Suppose if the requisite driver is not available then click on the Windows Update button. After the Windows 7 Update installation finishes in your computer, once again search for the appropriate driver for your printer.
2. FINAL SOLUTION - for printer and scanner - if you have proper PC configuration:)
Win7 has a possibility: http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
you can install the WIN XP environment where you can easily install driver for Canon MF 5630 (or any other by Win7 x64 not supported printer/scanner) and additional software.
BUT YOU NEED to run: Windows 7 Professional, Enterprise, or Ultimate editions. Windows XP Mode is not supported on Windows 8.
Your BIOS must support Virtual Machine.
Jan 31, 2012 | Office Equipment & Supplies
I have a TM-T88IIIP model MI29C and windows 7 operating system. Do you have a download available for this?? Thank you Carol
Here's the driver link for the Epson TM-T88IIP Receipt Printer: http://www.posmicro.com/RECPRINTERS/EPSON/Epson-TM-T88II.htm
This link will take you to the download page for the manual as well. This driver is supposed to be for Windows XP but should work for Windows 7 32 bit OS. Give it a try - if it doesn't work or won't install, then post back to this solution and I will help you further. It is likely that a Windows 7 driver doesn't exist, but unless you have the 64 bit version of Windows 7 this driver should work one way or another.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
May 03, 2011 | Computers & Internet
Own a lexmark X7350 printer. Have Windows 7 OS. Downloaded the Vista driver for printer. Cannot scan a document. have to use Lexmark Photo Editor and scan as a black and white photo. This info was...
Upgrading to Windows 7
Lexmark X7350 support
Summary Use Vista Driver in Windows 7
Detail Driver Support
For many of our products, the Vista driver will work in the Windows 7 environment.
Driver Availability
The links below list products which have Windows 7 support.
Windows 7 Home Office and SMB Products (Inkjet and All-In-One)
Windows 7 Business Products (Laser)
Driver Delivery
Windows 7 Compatible Drivers are available from the following sources:
Download from support.lexmark.com
Recently released printers include Microsoft Windows 7 drivers on the Software and Documentation CD provided in the box with the printer
Many printer models have drivers included with the Windows Operating System or available through Windows Live Update
Feb 06, 2010 | Lexmark X7350 All-In-One Printer
After installing windows 7 webcam is not functining
Your lenevo IdeaPad S10 doesn't support windows 7 nor Windows Vista, so no drivers is available for your webcam.You might be able to install Windows 7 but only Windows XP drivers are available from IBM site.
If your system has atleast support Windows Vista and the drivers for windows vista might work with windows 7 as 90% of the drivers meant for Windows Vista works fine with windows 7,
Check out the chipset of your webcam and go to the manufacturer site and check if any updates are available from their side.
Good Luck..
Happy New Year.
Jan 01, 2010 | Lenovo IdeaPad S10-42312CU Notebook
Cannot install x125 on windows 7 in new hp computer
Driver Support
Lexmark is in the process of preparing for the launch of the new Microsoft Windows 7 operating system.
Driver Availability
In the weeks leading to consumer launch of Microsoft Windows 7, Lexmark will publish the type of support expected and the timeframe in which drivers will be available. Lexmark is currently finalizing Windows 7 support for a variety of its existing products. The list of products which will have Windows 7 support at launch is available in the links below. Windows 7 Business Products
Operating System Driver Support
Some printer models will have native easy-to-install printer drivers embedded in the operating system's driver library. Lexmark is providing a wide variety of printer drivers to be included with Microsoft Windows 7.
Driver Delivery
Drivers will be available for download from support.lexmark.com , and recently released printers may have the Microsoft Windows 7 driver available on the Software and Documentation CD provided in the box with the device, or a combination of both driver delivery methods will be available.
Future Products
Starting in 2010, all new products will ship with Windows 7 support.
Nov 09, 2009 | Lexmark X125 All-In-One InkJet Printer
Can't get my lexmark z1420 to work with windows 7. tells me to enable bi-directional communication. already downloaded the lexmark drivers for windows 7 but no difference.
Driver Support
Driver Availability
Driver Delivery
Future Products
Nov 09, 2009 | Lexmark Z1420 Printer
I have recently installed a window 7, but software cd which i have of hp f4288, that is the old version, that is not installing on this window what should i do now/
Its possible that your f4288 software CD only has drivers for Windows XP or older operating systems. Unfortunately they are not compatible with Windows 7. Try going to the HP website and look at the support area for the F4288, see if they have updated Windows 7 drivers or look for Vista drivers if Windows 7 are not available (as Vista drivers are supposed to be compatible with Windows 7). If Windows 7 (or Vista) drivers are not available on the HP website you are out of luck for now until HP releases new drivers.
Oct 27, 2009 | HP DeskJet F4280 All In One Printer InkJet
Windows 7 problem with video card (Intel 852-855)
I've search about that chip video card of your motherboard, I don't it has a software driver for windows 7, maybe it's not supported yet to run for windows 7.
I have a link here but for only Intel 852/855GM/865G/845G/910G/915G Graphics Driver 14.9 Windows 2000/XP. www.Intel852GM.com/vga
And supposed to be for the windows.
All you have to do is buy a new VGA that support for windows 7, at least now many kind of VGA card available. Hope this might give you some ideas.
Aug 05, 2009 | Computers & Internet
Canon CanoScan N1220U Flatbed Scanner Logo
43 people viewed this question
Clive
Clive
old marine
old marine
