Question about Canon imageRUNNER 8500 Copier
Canon IR8500 showing a E000013-0010 error code
Cannot clear the error code.
E000100 - 0000
Posted on Jun 16, 2010
  • Canon Expert
  • 287 Answers
Hello x,
I have to admit I do not have the exact manual for the 8500 but I do have the manual for the Ir105 which is basically a faster version of your device, as they are of the same family and were released as such. Canon is very good about maintaining the integrity of their error codes thru models and even thru the years of their models. They tend to merely make distinctions (as technology changes) with the suffix (the 4 digit add on, as in your case 0010 which means you followed the instructions in the display and turned the copier off and back on and the copier could not recover). E13 means that the waste toner delivery system has a problem. Let me elaborate as I am full of hot air. In an ideal world all of the image that is developed in order to make the copy you requested is transferred from the drum and to the paper. In truth a small portion of the image(toner) remains on the drum and must be removed to make the drum ready for the next image or you would see Aunt Helen's chili recipe faintly on the next copy. That "waste toner" is removed by using a a rubber squeegee (cleaning blade) that presses against the drum. Then the accumulated waste must transported away and deposited into the waste toner bottle. This is done via a relatively long tube that is the path between the image area and the waste toner bottle. There is an auger/long coiled screw within the tube that makes sure the toner carried to the waste toner bottle. The toner is so "fine" that without the stirring of the auger( which maintains fluff and flow) it could easily turn into a rock hard mass. But, if the waste toner bottle gets full and the waste toner delivery system continues to shove toner into a confined area, it will become obstructed which trips a sensor that is sensitive to even the smallest amount difficulty. I don't recall the exact verbage but i know that the copier will warn you in the display that the waste toner bottle is almost full before you get this code because the sensor once triggered begins a count sequence. So, make sure the waste toner bottle is empty. But at this point, you probably have to remove the back cover and locate the aluminum tube that delivers the toner to the waste toner bottle and "TRY" to remove the now concrete that has formed within the tube. This will require removing the tube and manually cleaning all that **** out. I dont think you have to go into srvice mode to reset this code once you have freed the system up. But if you complete the afore mention process and the code remains then press "additional functions" then press 2 and 8 at the same time , the press additional functions again. Press copier, then functions, then error, then clear, then at the lower right corner press ok. Power off and power on. Sorry to rattle on so much but i wanred to be as helpful as possible. GFL/. SPINAL......
Posted on Jul 22, 2008
    Problem Solver:
  • 4 Answers
What is the error message you are getting?
2 Suggested Answers
  • 58 Answers
SOURCE: ir8500 error code e000020-0010?
you have to clear this error by doing the following press additional function(*) and 2,8 together) then press additional functions (*)again (you have to do this quickly to get into service mode then you press copier
then you press function
then you press clear
then you press ERR
then you press ok
then turn off the machine and then back on
this is a low toner level detection code
do you have a new toner in the machine?
Posted on Aug 07, 2009
What does the Canon IR8500 error code E000222-0000 means?
There's no code like that in my manual.It's220-001 means lamp inverter PCB faulty,or reader controller PCB faulty. There's also a E 225-000 error which mean scanning lamp(xenon tube) is faulty,or inverter or CCD
Oct 14, 2014 | Canon Office Equipment & Supplies
I have canon ir8500, when i copy document, it showing E00069-000.
Error- 69, just try to clean the transfer unit, and change the all the corona wire,
Sep 03, 2011 | Canon imageRUNNER 8500 Copier
Hi, I get error E249-0001 on my canon ir8500
This error code relates to a problem between the scanner and the reader board the connector looks like and old printer connector (parallel) try unplugging and reseating this should resolve it.
Mar 04, 2010 | Canon imageRUNNER 8500 Copier
Why better canon ir8500 than canon ir7200
Features - The Canon imageRUNNER 8500 benefits from a number of unique features including 85 ppm output, 4 trays online, 100 sheet document feeder, digital copying, built in duplex , network printing/scanning option, professional image quality and compact and reliable design. The Canon iR8500 can copy or print up to A3 paper size. This high volume copier provides an easy and efficient solution for work groups.
Sep 06, 2009 | Canon Office Equipment & Supplies
Ir8500 error code e000020-0010?
then you press ERR
then you press ok
Aug 05, 2009 | Canon imageRUNNER 105 Copier
Error code e824-000
E824 indicates an error in the primary charge fan.May be tough to access on an IR8500.Good luck
Apr 06, 2009 | Canon imageRUNNER 8500 Copier
I nedd sst for canon IR8500
i can get you the newest ver. of the SST but i need your email and you have to rate first
Mar 15, 2009 | Office Equipment & Supplies
E000019 Error Code for Canon IR8500.
Which model is it? IR-400 or IR-8500.... It has to do with the fixing dive.. I would say you need a service tech. You have to fix the problem in order to clear the code. Most times it could be the cleaning web is wraped around the UFR or the LFR has the LFR pick-offs dug in to the LFR or it could be the actural fuser diver gear on the fixing unit is gumed up or the ball bearings are seased up.... It's up to you????
Jul 17, 2008 | Canon imageRUNNER 400S Copier
IR8500 giving E000830-0000 Error code
Having trouble with my IR8500 getting Error code E000218-0000. Any Suggestions? Thanks
Nov 30, 2007 | Canon imageRUNNER 8500 Copier
Canon imageRUNNER 8500 Copier Logo
1,048 people viewed this question
old marine
old marine
