Question about Maytag Dishwashers
Should the drain tube be looped or can it be pulled down for extra length
  • 205 Answers
If the drain line goes into an air-gap on the top of your sink than it can be pulled down. If it goes directly into your garbage disposal then it really should be looped a bit higher than the bottom of your sink incase your sink gets stopped up the water will not flood back into the dishwasher. Some models come with a "check valve" on the end of the drain line (it's plastic and is about 2" long) these prevent water from draining back into machine and potentially flooding your nice floors.
Posted on Jul 22, 2008
Have tried to unblock the drain with hot water and hair dryer after defrosting.
Sometimes you will have to run a small tube down the drain to push out the blockage. A 1/4 inch length of plastic water tubing works well.
Mar 14, 2015 | Refrigerators
2002 Honda Accord. The sunroof's vinyl drain tube on the driver's side has shrunk or pulled back at the bottom end approximately 1.25 inches pulling away from the molded rubber grommet near the kick
here are some pics of your problem,you could get a new tube from honda or a new tube from a hardware store,disconnect the tube from the top,tape the new tube to the top of the old tube,tape it good,pull the old tube out the bottom and attach the new tube at the top and to the grommet on the bottom,OR you may be missing the grommet,get a new grommet or,use a straw from a plastic cup and attach it over the old tube and insert through the hole in body.,25351676-4xvsciucyrxwqvq5ys1rwwmi-2-0.jpg 25351676-4xvsciucyrxwqvq5ys1rwwmi-2-2.jpg 25351676-4xvsciucyrxwqvq5ys1rwwmi-2-5.jpg 25351676-4xvsciucyrxwqvq5ys1rwwmi-2-9.png 25351676-4xvsciucyrxwqvq5ys1rwwmi-2-14.png 25351676-4xvsciucyrxwqvq5ys1rwwmi-2-20.png
Jan 02, 2015 | 2002 Honda Accord
Refill tube constantly detaches from fill valve
A longer piece of tubing may solve the problem. Put the extra down the overflow tube so it won't pop out. Hope this helps.
Dec 29, 2012 | Toto Carlyle 1-piece Elongated Bowl Toilet
How long is the main brake line on a 91 saturn sl1? NO ABS
You get under the car & measure what you will need,
& write down all the different tubing lengths,fittings,etc
You will have to cut,double flair & bend tubing-- so get extra
Dec 05, 2012 | Cars & Trucks
A lot of the exercises I want to try with my exercise band ask that I attach one end to a solid object like a door. How do I accomplish this?
You can buy a proper door attachment; however I am a fan of do-it-yourself projects and would rather teach you how to make a simple and easy attachment at home. All you need is a string piece of cord, at least 5 feet in length.
Begin by folding the cord in half and the in half again. Create a knot about one third of the way down and pull tight. The two thirds below the knot become your cords loop. Then locate the midpoint of your exercise band and create a small loop out of it with your hands. Next put the loop of your cord through the loop of your resistance band. Finally, pull the other end of the cord through the cords loop to create yet another knot and finish by pulling tightly.
Aug 06, 2012 | Exercise & Fitness
I've made a 10m water level using two 5m lengths of clear 6mm internal diameter pipe joined in the middle with a proprietary tube connector. I looped the tube with both ends next to each other and the...
The internal diameter is notional and if the two lengths you have used came from different production batches then their average internal diameter along the length of one half may be different to the other. The fact that there is such large ratio between the length of the tube and the internal diameter only makes matters worse.
You need ideally to source a single 10m length and to select a larger internal diameter to maximise accuracy: 10mm i/d will be better but if you can cope with the extra volume of liquid then 15mm or even 20mm will be much more accurate.
Jul 16, 2010 | Plumbing
MY WHER25 REV. OS. IS LEAKING AT THE HOLE IN THE BOTTOM OF THE SPOUT . i CHANGED THE FILTERS.. IT STILL LEAKED.. I CHECKED THE DRAIN GOING INTO THE P-TRAP .. IT WAS CLEAR .. PLEASE HELP
Remove the faucet spout and unscrew the screw keeping the white plastic piece on the bottom (of the faucet). It's where the red and black tubes enter. Pull out the white plastic with the tubes and clear it of debris (usually placed there when your disposal backs up the black tube, which serves as the filter's drain tube). Once it is cleared of debris, make sure the black rubber washer is back in place (it may be stuck in the faucet, so look for it) and replace the plastic, screw the screw back in, and secure the faucet again. I had this same problem and doing this solved it. Should take about 5 minutes or so. Good luck.
Dec 02, 2009 | Whirlpool Home
Maytag Freezer mqu1556aew 2004-07.Ice buiding up on the bottom of freezer.
if self defrosting model check frozen drain in freezer
Aug 09, 2009 | Freezers
HOTPOINT 3400 DOES NOT DRAIN totally
Hi Bob,
Yeah! I'm a Texan! Cool!
I'd almost bet that your dishwasher drain line is NOT clogged but simply installed incorrectly. If I'm right, some water from the sink will drain (siphon) back to your dishwasher making you believe that it's not draining properly. (BTW, I've had a thousand service calls run for just this problem, so I know of what I speak)
Look under your sink and take a gander at your dishwasher drain line... if it looks like this, it ain't right.
This allows sink/disposal water to siphon off to your DW. All you gotta do is loosen the clamp (in the pic), remove the drain line, pull as much slack as you can (without pulling to hard... like it'll break if you do that) and put a loop in it like this...
OK... after you get your loop, you'll need to tighten your hose clamp. As an extra measure of security (to keep the loop in place), secure the drain hose to your sinks water supply line.
There ya go! 15 minutes, no parts, no head-aches and you're done! Cool, huh? All you gotta do now is kick back and wait for the Cowboys pre-season! (BTW... if your drain is installed properly, write back and we'll go a little deeper into a diagnosis, OK?)
SG
May 17, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Dishwashers Logo
122 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
