Cobra and midland cb
I have a cobra 23 plus cb and a midland 77-118 cb and i can't send or receive any messages. i had them both apart and no wires are off. i think that the mics are good and i have a good antenna. what could be the problem
  •  Direct Computer Builders
    if you have them right next to each other it could be one of them has an audio ic chip blown or it could be a final gone out only way to test them is to take it to a shop and have them checked out...
  • Anonymous Mar 23, 2014
    I Bought A Midland 77-118 cb/Weather Radio and it didn't come with A owners Manual or the other end of the Power cord. The Power Leed coming out of the Back Has Red for Power,Black for Ground,and Orange for acc Pins in A White Clip. to Test it on My Power Supply do I Need to Connect both Orange & Red to the Red side of My Power Supply or Just the Red and is the Orange for some Kind of Memory. Thank You.
    Problem Solver:
  • 3 Answers
It could be that the cb is to small to get your voice out there. I just ran into the same problem with my Midland 77-099 and i got to talking with one of my old family friends, he told me that it was to small and needed to get an amp, so to get an amp and be legal you have to get FCC licensed to run one and then buy you an amp and read the manuals on how to hook it up bc you dont want to destroy the amp or cb itself in a matter of sec. this is all i know to do. Hope it helps if not email me at mag0842@gmail.com
Posted on May 12, 2009
I need Circuit diagram of midland lxt320 2way radio or help no power i got new batterys and its working 0n my cobra cxt450 2way radio
Midland doesn't provide circuit diagrams to the public .They do this because they want you to send your radio back to them to be fixed and if they can't fix it they will send you another.
Nov 21, 2016 | Cobra Radio Communications
Brand new Midland 5001z 40 channel cb blows fuses its turned on
Where did you buy the radio at? Can you return it to the store? If you purchased it at a big box store, like Walmart, they will take it back without a receipt on an exchange.
More than likely the radio was wired backwards by someone, which blew the protection diode, and then was returned to the store and put back on the shelf.
If it is just a blown protection diode, it is only a $10 fix at most any cb radio shop.
If I can help anymore, please let me know.
Dean Pitts
Rollin CBs
dean@rollincb.com
Feb 05, 2012 | Radio Communications
Brand new Midland 5001z blows fuses immediately after its turned on. I tried the power cord on Cobra 25 that has the identical plug configuration and its Ok. I don't have the receipt as I got it a
bad final also check for any burned resistors in the area. If the final caused the resistor to burn the just replacing the resistor it would burn the new one also.
Feb 05, 2012 | Midland 5001 40-Channels Base CB Radio
I need the wiring for the mic
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - 4 wire 1- Shield 2- White 3- Red 4- Black
static - 6 wire 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500 Cobra CA Series 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - 4 wire 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta 1- Shield 2- White 3- Brown 4- Green
Turner RK56 Road King 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Regards, Tony
Apr 07, 2011 | Connex Radio Communications
I have a Midland CB Car with no mike or a car power pluge, the model # is 70 - 336B and the serial # is 760408
Your midland CB will use a standard 4 pin wired CB plug which is most common for most mics sold today. Your power cord will be a standard 3 pin CB power cord which again is most common with CB's today. You need not purchase a "radio specific" cord or mic. Cobra, Uniden, Midland all the same mic pin out and power cords. Good luck.
Feb 09, 2011 | Radio Communications
My mic is a midland mic but is wired for a cobra some wires got mixed up some how in the mic but im not sure which ones go where.
easiest way open mic the coloured wire on the wire at the front of switch is receive, the middle coloured one earth,and end colour transmitt,on the other side of switch is mic colour.find these out first then get back to me.
Sep 14, 2010 | Midland 1001Z 40-Channels Base CB Radio
I have a cobra power mic that has no audio output
Sounds like its not wired up right, the audio wire must be off,take the plug apart and check the white wire, re-solder it. here is the wiring, pin1-shield,pin-2audio-(white), pin3-transmit-(red), pin4-receive-(black).....hope this was helpful...
Apr 23, 2010 | Cobra 29 LTD CB Radio
I have a midland 1001z cb radio with a magnetic mount attenna by cobra. When I transmit receivers are getting a lot of squealing. Before I bought the midland i had a radio shack cb which worked find.
is this same antenna as before. you should always check the SWR's to see if set correctly.. other than that. bad grounds, bad microphone can make any radio squeal..
Nov 27, 2009 | Radio Communications
Converting a different brand of mic for a midland CB
This should be a typical Midland pinout. If you are using a generic 4 pin mic that is wired to cobra/Uniden, all you have to do is switch pin 1 & 2, then 3 & 4.
Not all mics are color coded the same with their wires.
Oct 06, 2008 | Midland 1001Z 40-Channels Base CB Radio
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
