Question about Dishwashers
Danby dishwasher E3 error
I just bought a brand new Danby DDW497W dishwasher. This is only the second time I have used the dishwasher, and it shut off in mid cycle after about 20 minutes with the message E3 flashing on the digital display.
I have no idea what is going wrong! Any advice?
  • 4 more comments
  • Anonymous Sep 20, 2008
    i have the same problem and this is BS. what is E3?
  • Anonymous Oct 18, 2008
    Same problem, E3 does not flash.
  • colewiebe Dec 21, 2008
    I'm having the same problem on my Danby DDW497W. The hoses are perfectly straight with no kinks. The dishwasher fills with water, runs for about 15 minutes, drains lots of hot sudsy water after the first part of the cycle, then mysteriously begins to beep and displays a flashing E3 message.
    I have a Danby DDW497W with the same problem. The dishwasher fills and begins to wash the dishes. There's plenty of water splashing around in the dishwasher. In about 15 minutes it begins to beep, drains all the hot sudsy water and shuts down. A flashing E3 message displays. It was suggested that the hoses were kinked but they're straight and water is flowing well in both directions. Every dozen or so loads the P2 progam executes without a hitch. The dishwasher's only about 3 months old.
  • timbles1_ Jan 29, 2009
    I have the same problem, and E3 does not flash. There seems to be nothing in the documentation regarding error codes.
  • Anonymous Mar 17, 2009
    Even if you didn't let the water run hot before you started, the water would be cold in the pipe for the second cycle. Remember, the entire cycle takes two hours. My DDW497W has been in the shop for 10 weeks (yes 10 weeks) and all they can say is it will be another 3-4 weeks. BS.
Same issue here so I just got off the phone with Danby. They said the E3 means the water is not hot enough when it goes into the machine. Now I dont know your guys situation but I let the water run hot until I cant touch it anymore, then I turn on the machine and plug it in. So it sounds like the heating mechanism is not working properly and does not heat the water to the appropriate temp to continue with the cycle. I will say that their support was really friendly and she informed me that since it was purchased less than a year ago it would be covered under the warranty. She gave me the number of a local repair shop. Lets just hope they dont tell me nothing is wrong with it because my water temp is fine. I will let ya guys know. Here is the number for Danby that I called. General office: 419-425-5052. Good Luck!
Posted on Feb 13, 2009
  • jonosb Jun 26, 2011
    Thank you for contacting Danby products Ltd.
    When Did you purchase the unit ? we can refer you to a servicer in your area, we would need your address to do so.
    The E3 Error Code could be either of the following:
    problem solution
    Error 3 Voltage is too low Minimum voltage of 198 V
    Damaged/ defective thermostat Replace the thermostat
    Damaged or defective wiring Repair the wiring
    NTC thermistor damaged/out of position Replace or readjust the thermistor
    Damaged/ defective heating element Replace the heating element
    Defective electric control Replace the electric control
    Should you have any further questions please do not hesitate to contact us again by replying to this email or by telephone at 1-800-263-2629 to speak with a member of our Customer Service team.
    Sincerely,
    Consumer Service Department
    Danby Products Ltd.
  • grant burgess Nov 07, 2011
    take the lid off and check the wires and the fuse going to the heating element it will be on the left side bottom under the tub... mine was burned off and the fuse was blown i wired it with DECENT wire and no pmore problems
The hose is kinked.
Posted on Oct 17, 2008
    We had to unplug and turn our dishwasher about to find the Serial Number. When we righted it and plugged it in, it worked again.
    Any other electronic device we would have rebooted. Maybe that's all it needed. Try it, find out.
My danby countertop dishwasher ddw497w turns on, drains the water in the tub, refills and right before it usually fires up. click and nothing. just sits there with no fault code. any ideas before i sm
Hey Derrick,
According to the manual:
http://www.danby.com/cms/documents/pdfs/en/DDW497W_EFSOM.pdf
The most likely cause is the appliance not being leveled properly. Apart from that, I have found no useful information.
If you have a smart phone, try using one of the various, 'Surface Level' apps which will allow you to set your phone on the top of the appliance and then adjust the level until the bubble is centered in the crosshairs.
Hope this helps.
Oct 03, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
Danby dishwasher faucet adapter
Yes, I have a new portable dishwasher and no adapter, not sure what size to get. model DDW1899WP-1
Jun 25, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
Drain pump wont stop
Hello there and thank you for choosing fixya
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged. or may
be bad and needs to be replaced.
Also if the cycle timer is going out this may cause the drain to continue so i would havethat checked out as well ok?
Hope this helps
Best regards Mike
Aug 04, 2011 | Danby DDW497W Portable Dishwasher
I turned on my Danby countertop dishwasher without water! and now it does not work at all. Someone help me please, how can i fix it!!!
unless it ran for quite a while there should be no damage. plug it into the water, add a few cups of water to the water to fill the sump and prime the pump and turn it on it should work then.
Our danby at home shuts itself off when there is no water so I'm assuming thats what you are seeing.
Aug 23, 2010 | Danby DDW497W 22 in. Countertop Dishwasher
About 20 minutes into a cycle (I usually use a rapid wash cycle-P3) the machine makes a loud clicking and grinding noise that lasts for about 1 minute. Any ideas what this could be and how to remedy the...
Danby customer service told me that it was built into the machine. The machine would shut off for about 15 minutes after that loud noise occurs. Then would finish the cycle after that point? Got infants, buy one of these products! LOL
Jul 29, 2009 | Danby DDW497W 22 in. Countertop Dishwasher
Dishwashers Logo
1,545 people viewed this question
Top Dishwashers Experts
