Question about Brother MFC-640CW All-In-One InkJet Printer
How do I remove the control panel?
Not long after we got the MFC-640CW, a plant-watering overflow resulted in water on the control panel of the unit. Most of the buttons haven't worked since then. We still used it on occasion via software control but would really like to make it fully functional again.
I have taken apart plenty of gear and cleaned/fixed little carbon-button/membrane switches, so that part I'm OK with. I just can't figure out how to take this thing apart so I can get at the dirty bits.
How do I take this thing apart?
Thanks!
  • zemlin Jul 04, 2014
    fwiw, it's still working 6 years later.
Figured it out. There are three screws under the lid. One of them is tough to get at, but if you remove the lid support and the phone rest the lid will open to 90 degrees. At that point the top just pulls away from the base unit. You may have to unsnap the small cover where the wires pass from the base to the top unit so you can pull enough slack in the wires to pull the top off the hinges. Once that's done removing the last screw is easy.
After the screws are out, prying around the edges of the panel unsnaps the remaining retainers and pops it right off.
The problem in our unit ended up being corrosion in the circuit area of the board. I cleaned up the corrosion and found one trace that was broken. I soldered a jumper around the broken trace. The broken trace was preventing 4 of the buttons from functioning. Once the jumper was in place all the buttons started working.
Back in business.
Posted on Jul 22, 2008
Washing machine will not stop filling during rinse cycle resulting in an FE error
Washer fills with water and overflows:
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Also another trick to check the water valve, is to first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed
By the way my advice is free cuz God is good!
Aug 14, 2012 | LG WM-1832C Front Load Washer
The eco light is flashing constantly on my Dishlex Global 300 dishwasher, it is making a noise like a pump is running continously, but the unit will not operate. Can you give me some possible faults and...
The symptoms on a Dishlex Global 300 dishwasher:
  • eco light is flashing constantly;
  • noise on pump running continuously;
  • but the unit will not operate.
Possible corrective actions include:
  • water level - pls check incoming water pressure, filter, water level sensor, water valve;
  • base/bottom overflow sensor - there is a float switch in the base of the machine inside a small plastic dish. Behind the kick panel, access through a metal lid/panel/cover secured by 2 small screws. Dry completely the area;
  • Air/dry/ventilate the unit/system for a couple of days;
  • reduce incoming water pressure.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 26, 2008 | Dishwashers
Water keeps going and overflows
Hi and welcome to FixYa. I am Kelly
You will have to open the top panel for steps below
Water level control is handled by the water level pressure switch inside the top panel. It is about 3.25 inches in diameter, has 3 wires connected to it and a hose that looks like a small vacuum line.
Check that vacuum looking line for any holes, kinks or disconnects.
You will need about 3 feet of the same knid of line available from any autoparts store for this test.
Remove the machine side hose and connect the 3 ft hose you just obtained. DO NOT drop the machine hose into the machine.
Place the timer on the wash cycle and start the cycle
Result = fill
Force air into the hose orally until you hear a click.
Result = fill stop agitation begin
If it does not pass this test then the pressure switch is bad.
If water never stops flowing the water inlet valve has debris internally and will probably have to be replaced.
Don't forget to reconnect the machine side hose to the pressure switch.
Thanks for using FixYa!
Kelly
Then remove the vacuum
Feb 18, 2010 | Maytag PAV2300 Top Load Washer
Water spewing into the reservoir and ovrflowing
Sounds like you do not have an orifice in the water line to regulate the water pressure.
Feb 25, 2009 | Aprilaire 550 Humidifier
Kenmore HE2 #1104751. Overflows as it is just beginning to fill with water
ck inlet just inside door upper left could be blockage in line from dispenser into tub especially if you have been using dry detergent remove detergent drawer and ck for blockage from that end too
Oct 09, 2008 | Kenmore Elite 45986 Front Load Washer
Brother MFC-640CW
Try pulling the cord from the back of the printer and re-inserting it.
Jan 11, 2008 | Brother MFC-640CW All-In-One InkJet...
Offline status
Under the control panel, click on the printer to bring up the print dialog. Go to printer at the top of page, drop down the menu and uncheck use printer off line. Should bring it on line.
Hope that helps
Oct 30, 2007 | Brother MFC-640CW All-In-One InkJet...
Brother MFC-640CW All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
