Question about Toshiba (APS3902U-U0001X) 800-Watt Power Supply
Power saver when ever i start my computer sme times i can see window with the msg like power saver has stopped working i m very confused now how to solve this problem?is there any major problem or not? if u can help me to solve this problem please.
  • 1 more comment
  • nilampatel Jul 21, 2008
    i ll appreciate if u ll help me please
  • nilampatel Jul 22, 2008
    i have a laptop toshiba satellite a135-s4467
  • David
    David May 11, 2010
    do you have laptop or desktop
Didnt help
Posted on Jul 23, 2008
  • 781 Answers
Right click desktop go to properties when open go to settings /advanced see if power saver is on or off
Posted on Jul 22, 2008
HOW TO SET SCREEN TIMES? cOMPUTER GOES BLACK WHEN i AN WORKING
Do you mean the computer shuts off? Confused bout "screen time." a what you mean.
Aug 10, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Bettery is good but I can start the car and door lock, radio all others not working except light
Try unhooking one of the battery cables and leave it off for at least 20 minutes. When you hook it back up the computers should re-boot. That has solved problems for me with heater, interior lites, power windows, AC, day time running lites, power mirrors, fast idle, rough or slow shifting, CD player, and wipers on GM autos and S-10 PU and Dodge trucks. None of the switches are connected to the device they control anymore. The switch tells the computer to open the window and the computer send a signal to the window motor. When the computer gets confused strange things will happen or not happen. Of course you may have to re-set your radio stations.
Sep 03, 2010 | Chevrolet Chevette Cars & Trucks
Cannot start and interior lights out and alarm led off, door locks dont work
Try unhooking one of the battery cables and leave it off for at least 20 minutes. When you hook it back up the computers should re-boot. That has solved problems for me with heater, interior lites, power windows, AC, day time running lites, power mirrors, CD player, and wipers on GM autos and S-10 PU and Dodge trucks. None of the switches are connected to the device they control anymore. The switch tells the computer to open the window and the computer send a signal to the window motor. When the computer gets confused strange things will happen or not happen.
Aug 29, 2010 | 2002 Buick Rendezvous
ArcSoft Connect Notifier has stopped working
ArcSoft Connect Notifier has stopped... Solve Every time I switch on my lap-top,I get the same msg, "ArcCon.ac - Unable To Locate... (More) Every time I switch on my lap-top,I get the same msg, "ArcCon.ac - Unable To Locate Component" in the title bar with "This application has failed to start because ArcCon.dll was not found. Re-installing the application may fix this problem." Can any1 help?
Aug 08, 2009 | Arcsoft Print Creations - Cards &...
I recently discovered that Anytime I start my Toshiba Saetelite A105-S3611 laptop/notebook with windows Xp SP2, there is a message: ?Toshiba Power Saver?, A fatal error has occurred, this program will be...
Download the hotkey utility from the toshiba web site. I got this errorafter installing service pack 2 for xp. The hotkey utility fixed it.error appeared every time I started windows xp. Go to:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
and go to downloads, select model and download:
Toshiba Hotkey Utility
Install and restart, problem solved. thank you, thank you...
May 05, 2009 | Computers & Internet
Power save mode problem -- during the PC boot up
Hi Geekman,
Thank you very much for the quick follow up. I am very sorry that I couldn't update the issue on time as I was very busy on my work.
My problem was solved even I am not sure what was happened to me.
As I wrote down before, I left my computer disconnected to all power cable (power supply cable and monitor cable) on Nov. 18 at 5 am. This afternoon I connected monitor's power cable and main AC power cable, and turned on main AC power; then the bios check and memory check had appeared on the screen, and also asked for resetting the COMS. After I have reset all parameters, the computer is boot up as before and had the Windows Advance Options Menu (I didn't hit F8). I chose boot as "last knowing ...", after I had the desktop, then I went to Control Panel ... > to switch off the Screen Saver. Now everything is fine. I don't know if the length of the time of the disconnected power was the key point. Until now, I still do not know what is the correct scenario (the exact step by step) of clear COMS. I checked with websites, seems like there are so many different ways to do it (more than four ways). Does this mean every way is correct or can I say COMS can be cleared in any way?
Thank you again,
Nov 17, 2008 | Microsoft Windows XP Home Edition
Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
Oct 29, 2008 | ViewSonic VE155b 15" LCD Monitor
Computer
Security Policy is hinding screen saver tab.
Go to Start Menu
Click on "Run"
type: gpedit.msc
click OK
User configuration
- Administrative Templates
- Control Panel
- Display
Look at Hide Screen Saver tab
make sure it is set to disable.
Jun 26, 2008 | Dell Dimension 4500 PC Desktop
Won't come out of "power saver mode"!! PLS HELP
before anything else... just try to check or diagnose if your video card is not defective..and you try also to use another computer to connect to identify the problem...
Jan 28, 2008 | LG Flatron L1710M 17" LCD Monitor
Power saver error 0x5
Dec 10, 2007 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
109 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
