Hi, I'm having trouble finding the plastic coupler from a model 320 Karcher pressure washer. There is a # stamped right on the part: 9.036-652 and directly below it 9.036-712 this is where the little intake filter sits in, also where your supply water line attaches to. I am in Alberta, Canada and am having a heck of a time finding this part. Any help would be appreciated. Thank You. Henry. vmx.holeshot@gmail.com
5 Suggested Answers
particleman
  • 9 Answers
SOURCE: No hot water entering
1. Make sure water comes out of the hot water hose into a bucket.
2. Check to make sure the solenoid valve is working. The buzzing is the 60Hz on the coil and can make a lot of noise if valve does not operate properly. Try blowing into the hot water port. If the solenoid is functioning properly air will move freely, if not its stuck.
Posted on Jan 10, 2008
aborcass
  • 2651 Answers
SOURCE: Kenmore Elite Quiet Pak 1 Model No.110.26942503
yea if valve is leaking into machine when not on youll need to replace the valve. part number for the inlet valve 3979346 . you can find a diagram as well as a part list at sears.com.
http://www.searspartsdirect.com/partsdirect/retrieveModelActionHome!retrieve.action;jsessionid=UFaeD4IGtGIcYFtrZmj97w**.shcapp3205?modelNumber=110.26942503&pop=flush
Posted on Mar 26, 2008
SOURCE: got a karcher 410 water
Fairly simple to opperate. Connect water supply hose. Connect wand hose. Plug in, turn on water supply and turn on. Then squeeze the wand handle to spray. With mine, there are times when the unit looses pressure, but if you leave it running, it seems to recover. Also note that you can turn the flare at the end of the wand for a soft stream versus pressure spray. I have had mixed results with the pull out clear tube that is supposed to siphon liquid soap into the mix.
Posted on Apr 28, 2008
  • 313 Answers
SOURCE: I have a Karcher electric
see www.pressureparts.com for karcher
Posted on Jul 08, 2008
SOURCE: Karcher 620M not drawing water
my 620m has a problem when i press the switch on it has no pressure and the pump sounds like it is not kicking in .... plese help !!!
steve ..
Posted on Jul 31, 2008
I have a karcher k2.65m pressure washer which is leaking from inside after removing the outside covers i could not see how to separate the black plastic case to get into the pump etc any ideas ??
A picture might help.
You could always find the part and number here http://www.ereplacementparts.com/karcher-226m-16016020-pressure-washer-parts-c-33388_33389_33977.html Karcher 2 26M 16016020 Pressure Washer Parts
Aug 11, 2015 | Karcher Garden
Hose keeps popping off... Brand new. Is there a method of starting up ? I attached the hose... On goes karcher...On goes hosepipe tap....the plop, off comes the pipe ? What am I doing wrong. It is attached...
The best thing is to get a complete pair of quick couplers. One male one female and replace the ones you currently have. Stick the male on the washer the female on the hose and as they are the same should be able to hold under the pressure of water.
Mar 24, 2014 | Karcher Garden
The karcher works well, but when you stop spraying. The pump cycles on and off.
This is a cooling feature. There is a thermal coupler to allow the cool water to cycle and cool off the pump.
thank you
Joe
Feb 10, 2011 | Karcher 1850 PSI Electric Pressure Washer...
Karcher k 3.99 does not pause correct
Is there a water leak from the bottom ?
Is so, then there maybe a small crack in the seam of the plastic manifold pump housing or one of the connecting fittings. A New Manifold Complete about $61.00. You may purchase direct from Karcher, and replace if you are mechanically inclined.
If under 1 year old, and you can find a receipt, Karcher will replace the whole Pressure washer under warranty.
May 09, 2010 | Karcher K 5.85 M Electric Pressure Washer
Is there a water leaking from the bottom ? If so then there maybe is a small crack in the Pump Plastic Manifold Housing. A New Manifold Complete Replacement is approx. $61.03 from Karcher, if you are mechanically inclined.
If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
Mar 16, 2010 | Karcher K 5.85 M Electric Pressure Washer
Karcher K6.50 possible pressure switch problem?
sounds like the unloader is stuck onthe machine which pushes against the micro switch.
follow the instructions for a parts diagram.
www.karcher.com
click on europe
then click on international
go to service and spare parts will open, click spare parts
then put in k6.50m on there will be another number on your machine 8 digit , easy way to find your machine, could 10 different models
Mar 17, 2009 | Garden
Karcher 395
I found that by putting the housing in the freezer for a couple of hours, i was able to tap the metal and plastic body apart and install the new inlet elbow.
Aug 17, 2008 | Karcher 2500 PSI Pressure Washer
Washing Machines Logo
430 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
