-   Also had water leaking and found there was a blockage from grounds in the line. Also the rubber ring around the area that grinds and taps the coffee is broken. Trying to find a replacement ring as I love this machine. Have had mine over 5 years. Can't bear to part with it.
-   debbieferini
I had this problem. I had to have the boiler replaced for about $100. Unfortunately the first time they did it , the leak continued. I took it back and they re-repaired it. Have it done by a Saeco dealer.
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
I'm having trouble descaling my machine,
the booklet says to remove the portafilter (I assume...
(More)
the booklet says to remove the portafilter (I assume the filter) and the steam wand (no Idea how to).
If anyone would be able to provide assistance it would be appreciated.
my odea giro is pumping well after the 3 expresso. The first few cups have the pump going, then...
(More)
my odea giro is pumping well after the 3 expresso. The first few cups have the pump going, then idling,then going again. I descaled and it did not change anything.
