Question about Car Audio & Video
No sound I installed a Sony Xplod into my jeep cherokee bought an adapter wiring harness from Wal-mart, not first time installing radios. Turns on but no sound, i checked out radio on other car works fine. checked the wiring over and over nothing missed, wondering if harness is bad. help please.
  • 58 Answers
If you are sure you matched the wires up correctly, then odds are it is a bad harness. If you have access to a multimeter, you can check voltage on the speaker terminal to see if you are actually getting a signal. I would verify Jeep follows a normal wiring scheme as well. I have never installed a radio on a Jeep, so I can't say for sure. I would assume they would. You will probably have to get a new harness. Wal-mart will probably do an exchange for you.
Posted on Jul 21, 2008
Sony xplod stereo wiring diagram
Yes you need to turn on the BOSE amplifier in the car to hear the sound. The wiring diagram is actually on top of the factory radio
You will need a 12v trigger to turn the amp on. this is assuming you have all the speaker (inputs) connected to the output from your new deck.
Sep 09, 2013 | 2001 Audi TT
I just bought a new kw-AVX740 radio and i have a 01 mustang and i don't really no how to install it
first and foremost you need to buy a car audio installation kit for your car model and year. Wal mart has some, but i think you may need to drive down to your local car audio shop and buy one from them if wal mart don't have them. Remove the old/factory radio. If an aftermarket radio is already installed then you may get lucky and find the harness already installed, but depending on what kind or radio it is( ex: DIN or Double DIN), but the specs for your radio is Double DIN(fat) so you may still need to buy the installation kit. Once you have the kit, everything is color coded, just match the wires and connect, then plug the harness after you have secured the wires. For a clean professional installation look, solder your wires(60/40 solder and soldering iron needed) and seal the connection with a heat shrink tube(audio shop carries the tube as well) and your good to go. I found you the install manual, just copy and paste(make sure all wires are connected with keys off the ignition until everything is good and connected)
http://resources.jvc.com/Resources/00/01/50/LVT2173-002A.pdf
Jul 14, 2011 | JVC Car Audio & Video
1994 jeep cherokee sport radio just all of a sudden quite playing do you have any suggestions
Check the fuse. If you aren't sure where to find it, then check the owners manual for the fuse listing(schematic). It's also possible the cheap radio may have croaked. Cheap replacements & easy install wiring kits are available @ wal-mart. Ask the department clerk for help if need be.
Aug 28, 2010 | 1994 Jeep Cherokee
Sondy Xplod CDX GT170 - I have bought a car and it has this stereo in it - they have given me the manual but couldnt find the installation instructions. I think it has been installed wrong because every...
the yellow wire on the radio harness needs to have a constant 12v power supply and the red wire needs a switched 12v supply and that should solve your problem
Jun 08, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
I need a diagram to wire a sony car radio to a 2006 toyota tundra
I'd suggest starting with a radio harness adapter designed to provide wire-ends for the plug head in your tundra, I've found a few on eBay in this search:
http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=06+tundra+radio+harness
Beyond that, here's the wiring diagram & installation manual for your gt200 radio:
http://www.docs.sony.com/release/CDXGT200_Installation_Guide.pdf
and here's the operating manual:
http://www.docs.sony.com/release/CDXGT20W_200.pdf
I hope that helps.
Jan 18, 2010 | Sony XPLOD CDX-GT200 CD Player
Iam looking for a picture diagram showing how to install an after market radio ,any one know where i can find this online ? thank you
Buy an install kit. This will include faceplate and radio chassis adapters for your vehicle. They are not costly. You will also want to get a plug and play style wiring harness adapter for your vehicle; Scosche is one of a few different manufacturers who make both of these indispensable items for stereo installations. Electronics stores almost always have these, as do Wal-Marts.
Nov 17, 2009 | 1993 Toyota 4Runner
Need to know color schematics for radio harness wiring
If installing Toyota radios/CD Players they just plug in regluar sockets in vehicle.
If installing Non-Toyota radios/CD Players youll have to buy a wiring kit from Wal-Mart/Circuit City/etc it would have the wiring diagram in it.
Jul 27, 2008 | 2003 Toyota ECHO
Factory Amp
I assume you used the correct Metra plug (70-1878) to install the radio. Ensure the blue and white wire on the Metra is attached to the blue and white wire (or solid blue) on the Sony. This will provide + turn on voltage to the factory amp.
The other good possibility is that the Metra harness has a black and a black and white set of wires both must be ground.
Lastly the Metra harness does not provide these( -) grounds, they are supplied by the braided strap . or the single wire that was attached to the back of the Jeep radio.
Jul 22, 2008 | Infinity 475A Car Audio Amplifier
Car Audio & Video Logo
205 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
