Question about Sub-Zero 632 / S
Frig side not cooling properly
My subzero model 532 is having a problem keeping the fresh food side cool and it runs all the time. took the inside cover off and the upper part of the coil is iceing up .the condensor coil is clean.the suction pressure is about 23 psi r-12 what should the suctionand head pressure be? i hope you can help me out,
  • ptmtvrm Aug 06, 2008
    subzero 532, the refrigator coils had ice just on the top three coils of the evaporator. its been three days since i cleaned it and still does not seem to want to get to 40 deg. there is no defrost in the frig, so whats my problem?
  • luckylorra Aug 10, 2008
    Model 532 Sub zero ices up on back wall and does the cool properly. Had a new thermostat installed 2 years ago. Runs almost all the time.
  • 71 Answers
Just the upper part? you are lw in freon pression are arond 36 cut in 16 cut out. 2 option replace the evap or in your case add freon> r 12 or remove all old 12 and use 414 ...... good luck.... LEAVE A COMMENT IF IT WAS GOOD FOR YOU
Posted on Apr 02, 2010
Frig side by side model glrs267zcq1 freezer cool but not frozen no ice
Hello friend, thanks for your post!
I see your Frigidaire refrigerator is not freezing in the freezer section but keeping your fresh food side cool. Some possibilities could be your refrigerator stuck in defrost mode, the control panel, or sealed system. I would recommend performing a reset on your appliance which would be flipping your household circuit breaker off for ten minutes. If that does not resolve your issue I would seek assistance from a professional to properly diagnose and repair your appliance. -Matt
Aug 17, 2014 | Frigidaire Refrigerators
SubZero 532 model Water collecting in bottom of refrigerator below vegetable drawers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Refrigerators
I have A Subzero 690 and the water no longer comes out as cold
the water container is located on the fresh food side. This is how your water is cooled. I would get a Temp Gauge and put it in the fresh food side to see if the temp is correct.
Aug 11, 2010 | Sub-Zero 690 Side by Side Refrigerator
Will freezer side work if frig side is out
The freezer will appear to still work for awhile after the fresh food side fail to maintain a cool temp, you will need to remove the back in the freezer section and see if the fan motor is turning, if the fan motor is not turning you willl need to replace the fan motor and this will correct the problem and allow cool air to circulate to the fresh food section and cool the fresh food side of the refrigerator
Apr 17, 2010 | Refrigerators
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Coils keep freezing up its 4 years old
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bough a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 30, 2009 | GE GSS20IEP Side by Side Refrigerator
FRESH FOOD SIDE OF FRIG NOT COOLING
i would take the back freezer panel off and see what kind of frost pattern your coils have.they may be frosted over and the begining of a defrost problem.
Mar 11, 2009 | GE GSH22KGM Side by Side Refrigerator
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Doesn't cool fresh food
It´s probably overloaded. Any refrigerator has a specific cooling capacity eg x Kg/24hours. you must check that capacity and charge acording to that.
Jun 30, 2008 | GE Refrigerators
Sub-Zero 632 / S Logo
369 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
