I removed the lid of our Techko schredder Model:SH2610PO and as I lifted it a small grey slender part became dislodged---NOW I do not know where to return it. HELP!
Thank you for your reply. I managed to fix the problem myself.
Blessings in abundance to each of you!
Posted on Jul 22, 2008
How do I change the lid on a Cabrio washer (model # WTW7800XW2)?
If you lift the lid up and go to the base you will see 2 torx head screws on each side remove them lid will slide up an off small tip when trying to remove screws if they are tight or stubborn stop they have a tendency to rust in place you may snap off trying to remove bad design if this happens order new screws 4 and hinges they are different order left and right
Feb 12, 2015 | Whirlpool Washing Machines
Stuck card in printer
- Open the lid.
-Lift the print head.
-remove the ribbon.
Now, on screen you will have the options to move the rollers back and forth. Take a look into the printer, us you move the rollers, to see if the card is dislodged and moving.
Try to avoid using any time type of adhesive-backed cards, as they cannot take much temperature and become warped. Regular CR-80 pvc cards work best with a DTC style printers.
Mar 13, 2014 | Fargo DTC550 Thermal Card Printer
Problem lifting cartridge lid on model dx7400
There's a small "latch" that holds the top of the lid "down". Push to release the latch, and then you can lift the lid, using the "hinge".
Jan 14, 2010 | Epson Stylus C86 InkJet Printer
Where is PCV filter on 2003 Frontier 4 cyl
The PCV filter is not in the air cleaner assembly body but rather in the lid. Remove the lid from the vehicle and turn it upside down. There you will see an almost triangular compartment with a grey plastic case that houses the fiber element. Look at the side of this compartment and in the small hole to see a small part of the grey plastic case that serves as the clip to secure it in the compartment. Insert your little finger into the hole and push on this small grey clip while lifting the case out. Remove the fiber element from the case and replace with new.
Oct 02, 2009 | Nissan Frontier Cars & Trucks
Need to know how to put in a print head
dear angie
Turn printer on
Raise scanner lid (grey KODAK lid)
Watch print cartridges automatically center and stop
Remove each cartridge (pinch the lower lip to upper)
Put index finger on printhead 1/2 inch above bullseye - on underside of upper bar - below the 1/2" slot in printhead
Find 1/2" "button" and push firmly; printhead snaps loose
Tip forward and lift printhead out
Feb 23, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Whirlpool washing machine "lid switch" is broken My lid switch came completely apart! I have a grey plastic switch (paddle) and two tiny springs. How do I lift the top of the washer to re-assemble the...
Found online:
Disconnect everything, power first. Keep the drain hose above the top of the washer if the bucket’s full of water. If there are clothes in it, remove them to a water-tight location (like a cooler or something).
Put the unit on an appliance dolly and get it onto the driveway before removing the drain hose from the rear of the unit. Water will gush out for a while here.
Unscrew the two hex bolts at the top of the unit that attach the plastic tabs to the console. Unscrew the screws in the end caps that attach it to the top of the cabinet. Unscrew the two hex bolts at the base of the rear panel that attach it to the base.
Pull the console forward and up a little to dislodge it. Slide it out of the way enough to get access to the two brass clips. Put a flat-head screwdriver in the hole towards the front and pry the clip forward a little to release it. Remove both clips. This releases the rear panel from the top of the cabinet.
One cable goes from the console to the top of the cabinet: this is the lid switch. Disconnect it.
Pull the cabinet forward now that everything is detached. It helps to have someone holding the console and rear panel while you do this. Remove the cabinet.
Place it on something to prevent scuffing, like a few towels or a small animal. The lid switch is the only device here. Unscrew it from the ground (one hex screw) and from the inside of the lid (two Phillips screws). Push the grey tube holding the wires out of the clip holding it in and release the plug from the top of the lid.
Take this to a parts shop and ask for another. It’s around $25-50 depending on how desperate you look.
Snap the gray tube back in, screw in the ground and switch. Close the lid: it should click now. If not, check that you actually screwed the new unit in properly. Yes, the new one.
Replace the cabinet and the rear panel, then the clips and the console. Replace all screws and bolts. Make sure there are no spare parts. Reattach all the cables and hoses and plug power in last.
Test it by putting it on a small load and let some water into the tub. Then stop it, move to spin dry, and start it with the lid open. Nothing should happen. Close the lid (you made sure to replace the drain hose, right?) and it should start spinning and pushing out water.
Congratulations, you saved over $100 and only lost a few hours of your life doing it.
And now you know where my morning went.
Pro tip: don’t let the lid fall down anymore. Place it down, don’t drop it.
Dec 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
I need to replace lid switch on Kenmore washer.
remove trims from edges of control panel
remove screws from under trims
rais and flip control panel over backwards(hinged at top) do not dislodge air hose to level sensor
remmove brass clips from washer body top, not position for reinstall
disconnect lid switch connector cable
lift and remove entire body
turn upsidie down
change switch
reassemble in reverse order
Oct 02, 2008 | Washing Machines
Hp 8250 printer
Hi, Just took mine apart.
Lift up the lid, and squeeze the clips on the supports, and pull the lid toward you. Lid slides off. Then look along both sides ( edge ) of the printer, you will see about 3 elongated holes. Push a small flat screwdriver through these to release the clips which hold on the grey trim around the edges.
Next slide the rear part of the trim to the left, to remove it. At this point you should undo the 4 hex screws that hold on the top ( the lid is attached to it by ribbon cable ). There are two at the front, two at the back ( the ones at the back are in 'tunnels' ).
Ribbon cable will unclip from the right side of the printer ( the circuit board ) and you can set the lid / top aside. The actual side of the printer simply hinge out. Everything else is fairly straightforward.
May 13, 2008 | HP Photosmart 8250 InkJet Printer
Canon 850 E001 Error
this is an problem in fixing heater unit open the door turn it on press 2 and 8 at the same time than press copier then function then clear then error the ok after that all turn it off again if it doesn't work u have a problem maybe a heater lamp a thermistor
Mar 26, 2008 | Office Equipment & Supplies
50 people viewed this question
