Question about Panasonic Office Equipment & Supplies
The panasonic kx-rc105 doesnt print dark enough and the ink cassete is brand new. How do we make it darker?
4 Suggested Answers
SOURCE: Dark Blurry Ink Line
When I print darker color images I get what I call Zebra stripes across the picture on a slant about 1/2 inch apart. Changed the toner and the drums are at 45% capacity. Any suggestions. Thank you.
Posted on Feb 13, 2009
  • 1550 Answers
SOURCE: printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
Posted on May 27, 2009
xptareq2000
  • 1447 Answers
SOURCE: The black is not printing dark enough. It shows it
it is problem your printer black cartridge
you change it or
technicaly you drop your black cartridge in water withen two days after tow days you dry black cartridge and clean head printer maintai nence software then solve your problem
Posted on Jul 30, 2009
e-Guru
  • 3917 Answers
SOURCE: hi i have a 1320c
This is a know error and the only way to resolve is by pulling all 8 sealing ribbons from the PHD unit during first setup and installation? (4 in front, 4 in rear). When you open the printer box. There's also a very good setup instructional video on the CD.
If the 4 rear ribbons are still installed, remove them and print about 20-30 pages. If the print is still faint, you've ruined the PHD unit and you'll need a new one, Dell P/N DT574
Please let us know if you were looking for something else or please accept the solution. Thank You for contacting Fixya.com
Posted on Feb 23, 2010
I am receiving an error in panasonic fax machine KX-FLB802 CHANGE SUPPLIES & CARTRIDGE LOW REPLACE SOON kindly tell me solution for this error or how to factory reset panasonic KX-FLB802 THANKS
Your printer is signalling that it is out of ink and that you should put a new ink cartridge in. Without a new ink cartridge it cannot print the pending faxes.
Mar 25, 2011 | Office Equipment & Supplies
Everything seems ok on my printer but when try to print something it comes very light not dark enough
Generally one can set the "Print Quality" in printer "defaults" often they are noted as, Fine, Normal, Fast Normal, Fast, or similar... now that means the amount of INK on the page, the faster you go, the less ink... the less darker it is. Try setting your printer to it Highest/best quality setting see if that helps.
Feb 05, 2010 | Office Equipment & Supplies
Even though both the color & b/w cartridge are new my print job is very light
You can try setting that darkness in your menu for set up printing. That will make it darker. If this just happened after changing the ink clean the jets before setting the darkness.
Dec 17, 2009 | HP Photosmart C3180 All-In-One InkJet...
Printer not printing dark enough
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
Sep 03, 2008 | Konica Minolta magicolor 7450 Laser...
Brother HL 1440 Printer Density Adjustment
For sure u can increase the darkness and there are settings to increase but u need to browse through the menu to locate the darkness increasing options. The mannual should definitely help.
Thanks
Feb 08, 2008 | Brother HL 1440 Laser Printer
Color prints too dark
1. Took out the color ink cart and clean the copper contacts of the ink cart with cotton swab, make sure that you do not touch the silver nozzle .
2. Try new ink color ink carts as someime this issue came up when the ink carts are about to finish up.
3. Replace the ink carts and do not us a refill ink.
Dec 26, 2007 | HP OfficeJet D135 All-In-One InkJet...
93 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
