Question about LG Televison & Video
I have an LG DVD HDD recorder( RH266 ) into which I have inserted a blank disc to record onto from the hard drive.The on-screen message 'preparing please wait' appears and remains for about two minutes followed by the 'LG' symbol and then it just keeps repeating this sequence over and over.It wil not eject the disc and turning the machine on and off does not help.I have tried the high tech. solution of hitting it with a hammer but that drew no response either!Any help would be greatly appreciated. JL.
  • 2 more comments
  • leahyj Jul 22, 2008
    I don't know any way of getting the disc out except by removing the cover and I don't know if this is safe on account of the laser.Could you please advise.Thank you.
    JL.
    JL.
    No response to anything,just the on-screen message ''preparing please wait ''.Do you know if it safe to open it up,with the machine unplugged of course?Is it there any danger from the laser?
  • leahyj Jul 24, 2008
    After much unscrewing I finally got the disc out and the machine seems to be working now.I have'nt risked inserting another disc yet.Thanks for your help.
    JL.
    Genius:
  • 1,689 Answers
I was supposed to give out a hot switch but since you have the disc out, then your all set then.
Posted on Jul 24, 2008
  • 781 Answers
To remove cd insert long needle into small hole in the front of cd fascia you will come to a stop press the stop in and cd should open
about the problem not reading cd suspect that cd not inserted properly and that is why it will not open
Posted on Jul 22, 2008
    Genius:
  • 1,011 Answers
Sir,
This is because of dust problem in Lens. U must buy a good lens cleaner and play it on dvd. If any dvd is struck and not eject the disc, if mean u could open the door and take it manually. U also manually open the door only to fix this problem.
Thanks
good luck
Don't forget to rate the solution
    Sergeant:
    Champion:
  • 347 Answers
Hello leahyj,
Does your DVD power up?
Is the disk stuck or jamed on your DVD or is it just your DVD that wonteject the DVD?
Do you hear a motor or anysound as if the DVD was trying to eject the disk when you press eject?
  • Santiago Vallejo
    Santiago Vallejo Jul 22, 2008
    leahyj,
    im not sure if your DVD has this but almost all devices with CD reader has it.
    Check if your DVD has a small hole (about 2mm in diameter).
    It should be right beside the DVD tray or anywhere on the DVD player.
    Anyway, If you find thah hole get something pointy, such as a paperclip, and stick into the hole. That way you will manually open the CD tray.
    Good luck, and let me know if that didnt solve your problem.
    Dahaka
  • 3,037 Answers
Go here: http://lgservice.com/ -> Product Support -> Contact Us
And fill in the form about your problem and Lg can send you the firmware
Posted on Jul 21, 2008
  • Benjamin Patri
    Benjamin Patri Jul 21, 2008
    my previous post never posted, basically you need to upgrade your firmware and if that doesn't help, then have LG replace the device for you or fix it for free. Let me know of any other questions that you may have
    good luck
    Master:
  • 555 Answers
Try using the manual disc release to get the DVD out. I would try using a different brand of recordable DVD in the future.
My lg recorder will not delete progs !?
my l g hard drive recorder/dvd,suddenly would not delete programmes that i wanted to edit ,also the timeshift would not work,but i could still record ok,and i had a few hours space left on the hard drive .so i copied to disc my favourite stored programmes ,about 3 discs,and put them to one side .
i tried then to format the complete hard drive ,but it didnt do anything !so i put it on record for 7hours on sp,then i stopped recording, and tried deleting the programme straight away ,and it did !it also cleaned the hard drive empty ! the timeshift is ok and all else is ok ,so i fixed it witha bit of my logic !hope this helps someone one day !
Sep 22, 2009 | LG RH266 Recorder
We bought the LG HDD/DVD RECORDER MODEL RH1F99MHS with the intent of recording directly onto the hard drive. How do we make that happen?! WCSU Film Class
I got a DVD+R & a DVD-R recordable discs and I used my LG HDD\ DVD recorder model RH1F99MHS and i recorded on the discs , the DVD can read them but my pc & laptop can't also other DVD players can't play them
Apr 30, 2008 | LG Televison & Video
LG HDD/DVD Recorder Model: RH265
What you need to do is to put in your dvd that you wish to copy onto and then press the DVD button on your remote control. (this is next to the HDD button which is under the POWER button) Then follow the on screen prompts and instructions in the owners manual. I had the same problem but found the solution by mistake!
Hope this helps,
Nicky
Mar 02, 2008 | Televison & Video
Recording problem with LG RH266 Recorder.
If the DVD is copy right protected then it won't record. By this I mean, you can't simply rent a DVD at Blockbuster and transfer it to the Hard Drive (use a computer to do this instead). Try using a DVD that is not protected, like a home video or a cd with MP3s
Feb 26, 2008 | LG RH266 Recorder
Finalization problem2
After transfering video from HD to DVD, before you press the "Menu" button. please make sure you you press "DVD" button on your remote to tell the machine you want the menu for "DVD" first.
It confused me at first :-)
Hope this helped
Feb 11, 2008 | LG RH266 Recorder
My samsung dvd-hr735 now region free wont let me record onto dvd
Could be your using the wrong disc.
type is DVD-R where - is a minus as distinct from DVD+R
Feb 09, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Record at once on dvd?
No direct record from TV to DVD on this model, yes it is very annoying...
Jan 16, 2008 | LG RH266 Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Recording problem with LG RH266 Recorder..
Just bought unit. Had same problem.Tried lots of different types of disks with no luck. Tried to play already written +R disk. Worked OK. Then took out and replaced with blank -R. Came up with new screen asking me if I wanted to initialize disk. Answered yes and it took about 20 seconds. Then tried to DUB from HDD to DVD again. This time it came up with the dubbing menu, I hadn't seen before, and worked.
Hardly ideal, but the trick was to get it to recognise it as a blank and initialize. Currently burning my first disk. Didnt realise about 'FAST' mode, so taking ages.
Jan 05, 2008 | LG RH266 Recorder
Lg rh266 recorder
When you put your disc in and its ready for copying over through Dubbing - when you see the quality ie xp - just press right or left til the FAST sign comes up. it maynot always come up if the recording time is any longer than an hour or less than 30 mins.
pg 47 of your manual
Regards Chris
chrisbradley80@gmail.com
Dec 20, 2007 | LG RH266 Recorder
Televison & Video Logo
403 people viewed this question
Computer Repairing
Computer Repairing
