Question about Xerox Office Equipment & Supplies
I have a Xerox Phaser 8400 and it states that I need a IEEE 1284 Parallel Printer Cable. I ordered that cable. One end fits to my PC, but the other end does not fit on the printer it is too big. The parallel port on my printer is smaller. What exactly do I need to get to work?
  • 2,072 Answers
An 8400 prints with a USB or a cat 5 cable ( ethernet, regular internet cable). You can not print to a Phaser 8400 with a parallel cable. I really can't figure why you would get that message.You enter the network settgings and set an IP address, then configure your print driver to match.
There is no parallel port on a 8400.
Posted on Jul 22, 2008
How do I connect my computer to a Copystar CS-5035 Copier/printer? It does not appear to be a regular USB connection in the back. The specs for CS-5035 read Parallel IEEE 1284 or High Speed USB 2.0.
All 2.0and 3.0 Will work just fine . there should be a cable supplied with the copier . With a fitting to fit the copier at one end a USB fitting at the other end to fit the computer .
Sep 16, 2014 | Office Equipment & Supplies
Panasonic IEEE 1284
Not sure what the question is. IEEE 1284 is a parallel cable interface, standard on most computers up until Windows XP for sure. This interface was substantially replaced by USB. If you have an older printer with this interface you can still connect this to a newer computer without the parallel interface by installing an interface card (into a desktop computer) or connecting via a Parallel to USB adapter.
May 08, 2014 | Microsoft IEEE 1284.4 compatible printer
How to connect to the computer?
Devices: Canon CanoScan FB330P/FB630P Color Flatbed Scanners
Check pages 22-23 of this copy of your Canon Canoscan 630P Product Guide.
You'll need an "IBM-type" parallel printer cable - with a DB25 on each end, and your computer will also need to have an "IBM-type" DB-25 parallel printer port.
What the Canon Product Guide fails to mention is that this "IBM-type" printer cable is a kluged Centronics parallel printer cable, but became so popular (on older computers - your laptop may not have this port), that it got an IEEE standard: IEEE 1284 (with DB25 connectors on both ends).
You'll need a DB25-to-DB25 M/F cable, meaning DB25 connectors on both ends, with a Male on one end, and a Female on the other end.
The Male DB25 will plug into the Female DB25 connector on your computer/laptop, with the Female DB25 going to the FB630P Color scanner..
Here are some pictures/pricing:
The nice thing about the design of the Canon FB630P Color Scanner is that the scanner also has a Female DB25 Printer port for an existing parallel printer, so when you connect an FB330P/FB630P to your system, your existing parallel printer is daisy-chained through this port - so you needn't give up you printer (to scan), nor must you install another parallel printer port onto your PCI-bus tower PC to keep your printer.
Canon Canoscan FB330P/FB630P Color Scanner Product Guide (82 pages):
Most modern printers are USB-attached to laptop systems, so you may need an adapter, an example of which is seen here:
Dec 05, 2011 | Canon CanoScan FB630P Flatbed Scanner
I just bought a new computer and the connections don't match up. what do i do? I have the Eltron LP 2443PSA Thanks, Mike
I beleive your printer only has a Parallel interface and your new pc does not. You will need a USB to Parallel cable.
Parallel Connection:
USB to Parallel Cable:
Apr 17, 2011 | Zebra Eltron Orion LP2443 Thermal Printer
Xerox Workcentre XD100 not printing
You need to use a IEEE-1284 Compliant parallel cable for this machine. A "changer" will not work, sorry.
Jan 25, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Connect printer to usb
I apologize for the delay in responding to your inquiry. I have researched this matter for you, and then typed a fairly lengthy solution. For some reason, just before it was to be posted it disappeared. (We have to love these PC's, right?)
At any rate, the connector on the printer is known as a mini- or micro-concentric parallel connection; therefore, you will need an IEEE-1284 premium mini-concentric parallel cable. This reference is posted merely for you to see the particular cable, and should not be interpreted as an endorsement of any kind concerning the vendor. In order for the IEEE 1284 end of the cable to attach to a USB port, in this instance, would require an adaptor to convert the parallel to a USB connector of the proper type and size. In fact, given that I do not know the remaining specifics of your system, and so that you will gain familiarity with the various adaptors, I would suggest that you take a look at this page:
Again, please do not construe my posting of this vendor's pages as an endorsement of any sort, as I have had no experience with them whatsoever. The references are posted here simply for your review.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 21, 2008 | HP LaserJet 1100 Printer
Printer non compactability
i bought a hp psc 500 without an installing cd or connecting cable to a Laptop. what can i do
May 22, 2008 | HP PSC 500 All-In-One Printer
Printing does not work on Xerox Workcenter XD125F
Does the printer show up when you unplug it from the USB port and plug it back in? Does it say New Hardware or Printer found?
Does it print from a parallel port or does your computer have one?
Unlikely the cable since I have used those on that product before.
If it will print from a computer parallel to parallel, I would suspect the cable obviously.
You can take the back off the printer and reseat the board, and connectors.
What happens when you popo the printer itself?
Jan 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
70 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
