Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
How do I make sure the dispenser is completly empty?
I"m changing from a "chloride based" detergent to enzyme based brand. How do I make sure the "smart dispense" is empty? Can I just use the manual dispenser?
Thanks!
Just use the manual dispense. The smart dispenser is horrible. You will never get it empty AND you will have congealed soap in the dispenser for ever.
Posted on Oct 22, 2008
I have a GE profile PDW9980N20SS dishwasher that has a smart dispense feature to auto dispense the detergent. The manual warns to not interchange enzyme based and chlorine based detergents or it will...
Hello, ajswave
I was trying to help you out here. I am not sure if this well help you? But here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting on most common dishwashers. If you go to this link and click around, I am sure you will find out so much about your Dishwasher, you will know more that the company that made it.If you already solved the problem this is good for future problems. Here Is the link for you to click on.
http://home.howstuffworks.com/dishwasher.htm
Please if this helps you at all, and if you can find the time to rate my help and some kind words written would be appreciated for my free help. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike :)
http://beta.fixya.com/users/mc1bean
May 01, 2011 | Maytag Dishwasher
The smart soap dispenser on my GE profile dishwasher is not dispensing soap. I filled the smart dispenser several months ago and it does not appear that any of the soap was dispensed. how do i resolve?...
We mistakenly switched liquid detergents and mixed enzyme based and bleach based. They gelled in the dispenser. I took the outer door cover off and could not figure out how to take the white plastic despenser off of the main door without breaking it. I disconected the electrical harness and took the main door off the hinges so I could take it outside, turn it upside down and use the garden hose pressure nozzle to blast the gellout of the white plastic dispenser. I use a piece of plastic coat hanger to poke around inside to break up the gell several times. It all came out in marble size pieces.
Aug 17, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
How do I purge congealed gel detergent from the Smart Dispense bulk dispenser? I've scooped out all that I can and added water to dilute the remaining, but it doesn't want to empty during cleaning cycles....
Part of the solution is on the GE website: http://www.geappliances.com/search/fast/infobase/10010832.htm
But first you must remove or mash the gelled detergent into very small pieces so it can pass through the pump and outlet. You must clean out most of the gelled detergent down in the door going towards the pump and the outlet at the base of the door. You can disassemble the door, or I used a length of 3/8" soft plastic tubing pushed down into the detergent cavity repeatedly to break up and pull the chunks up to the fill door where I could remove or mash them. You may also need to this between the first run of the procedure and the second. You may need to do the purge filling the dispenser with water (I used hot - 120F) more than the once in the procedure.
Jun 25, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Low detergent light does not come on indicating the GE profile dishwasher is out of detergent.
It is probably because your Smart Dispenser is full of water and there may be a clog of some type in the pump. Try purging your Smart Dispenser and see if it fixes the problem!! It fixed ours!!
How to Purge Smart Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Jul 09, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
DETERGENT DISPENSER NOT EMPTYING ON DD603SS
Hi- It sounds like the solenoid on the dispenser is not changing the water diverter to the wash portion (cup) of the dispenser. You most likely need a new dispenser. Probably best to have a Tech out to change it.
Mar 06, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Smart dispense detergent dispenser
There are two different types of dishwasher detergent types, bleach based and enzyme based.  The owner's manual states that if the two are ever mixed that the mixture will congeal, clogging the dispenser.
I don't know exactly how to safely remove the detergent that is in there, perhaps a wet/dry vaccuum.  There is likely a service mode for the dishwasher if it has electronic buttons, in the service mode you could activate the pump that dispenses the detergent.  Use caution, the thicker the clog, the harder the pump has to work and it may fail.  Hope this helps.
Nov 08, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher's detergent reservoir clogged
I have the same problem...I think I mixed the soap types (Enzyme based with Bleach based). The manual clearly says not to do this.
What I did was brought out my trusty wet-vac and sucked it out while using HOT water to break up the crusty mess. I am going to fill the dispenser with water and add soap the old way until I see the "low soap" light go on.
I'll keep you posted if this happens.
Oct 08, 2008 | Dishwashers
GE Profile SmartDispense clog
I have the same problem and found the below on the GE website. It says to purge the detergent from the Smart Dispense. I am in the process of doing it now...we'll see if it works:
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
Apr 20, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
538 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
