The windows might be corrupted. You could try editing the windows registry. here are the steps:
In order to delete upper and lower filters you're going to have to edit the registry. The usual cautions apply. If the registry is not edited properly your whole system can crash.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
last option, you could try installing imgburn. here's the download link:
http://www.imgburn.com/index.php?act=downloadIf nothing happens, your dvd drive is bad.
Good Luck,
Ryan
I have WMP11 on a PC with Vista and it writes to a blank DVD-R with no problem. I wrote to the DVD-R on the Vista PC and I was able to read it on the XP Pro PC, I just cannot write it on the XP Pro. According to Microsoft, WMP11 is supposed to write an audio file to a Data Disk.
Actually to be more precise, it does not support dvd audio burn on Windows XP (Home and Pro). See this article I found:http://www.microsoft.com/windowsxp/using... Thanks for helping me get to this answer. - jholmes900
