SOURCE: whirlpool washer cabinet reataining clip
its a weird clip ill give you that, theres a side with a 90 degree angle to it?? that end will hook up and into the **** cut in to the rear panel of the unit. then the 2 curved humps should kinda sorta line up with the 2 small rectangle cut outs in the cabinet, they should just about line up and witha slight push down with the heel of your hand it will snpa in, if it doesnt line up just right it means thecabinet is not on correctly]
SOURCE: Need to Know how to remove top and cabinet
first, do you have phillips screws on back of console at bottom goin down or in front bottom? one or the other remove these then slide console forward and fold back on hinge on top. if no screws then clips are hidden on front edge on end plates. use putty knife from front to push and release lifting console at same time. fold back.
use screw driver to pry and release brass clips holding top to rear panel. unplug lid sw connector and pull cabinet body away from machine. top and cabinet is screwed together and removed as one piece. cabinet hinges under base on front and sits on top of sides.
