Question about Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric will not turn on
No lights no sounds nothing-------- We replaced the thermal limiter but still acts like it is not even plugged in.
  • Anonymous Apr 11, 2009
    How do you ck the door switch
    Scholar:
  • 50 Answers
Check the terminal block where the cord attaches to the dryer. Sometimes a bad connecion can cause the terminal block and/ or cord to burn up.
Posted on Jul 21, 2008
Thermal Limiter Tripped/FAQE7077KRO
U MEAN THERMAL SHUT OFF? OR THERMAL CUT OFF? USUALLY NON RESETTABLE
Apr 12, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire dryer too hot
check for air flow on back of dyer, also check the heating element. could be a bad heating thermostat in dryer. good-day !
Feb 10, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire electric dryer model gleq2152es1 lights wont turn on and wont do anything
Hi ana piedranayari05, this is AP! Thank you for your post
I understand you are having trouble with your Frigidaire electric dryer not turning on. Make sure the dryer is still plugged into the outlet, and plugged in correctly. Also check to see if the house fuse is blown or circuit breaker tripped? If so, Replace fuse or re-set circuit breaker. Check to make sure that electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. Have a licensed electrician check to make sure it is on a circuit by itself. Additionally, the thermal limiter could have tripped or possibly an internal problem with the dryer. A thermal limiter automatically turns off the motor in the unlikely event of an overheated situation. A service technician must replace the thermal limiter after correcting the fault. If you have check the plug, fuses, and circuit breaker and still no power I would recommend contacting a local technician to diagnose and service your electric dryer.
Jan 18, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Was working on Frigidaire electric dryer GLEQ2152ES for a customer with a complaint of no heat, tested heater element and it tested good, only one of the wires going into the heater element was getting...
Hi Mark...
You test your thermal limiter with an ohm meter just like you used with the coil. It should show continuity.
Did you check the voltage at the receptacle to be sure you were getting 220v from the breaker?
Also check the electric cord going to the machine to make sure you do not have a broken wire in it. Check it where it connects to the back of the machine.
I hope this was your problem solver...good luck
Rate me please
Aug 28, 2010 | Frigidaire GLEQ2152ES Electric Dryer
How to change the fuse?
it is inside the dryer cabinet and called a "thermal limiter fuse" if it blew u have a shorted motor or heating element
Feb 23, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My frigidare dryer stops immediately after starting.
check the thermal limiter for continuity its a thermal safety switch and should show 0 or very low ohms like a regular switch,its located around the element and will have 2 wires colored RED and ORANGE connected to it
Jan 31, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My dryer will not blow hot air
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Oct 11, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Thermal limiter tripped
Once you take the top pannel off, the limiter is near the top back. It's kind of hard to get to so you may want to take the drum out before replacing.
Good luck :)
Aug 05, 2009 | Frigidaire GLEQ2152ES Electric Dryer
My dryer run but i get no heat
I replaced the thermister and it solved the problem
Jul 21, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
276 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
