Question about Wolfgang Puck 5-Quart Electronic Pressure Cooker - Silver
Steam leaking under lid of pressure cooker
Looses steam while under pressure, seems like the seal is not sealing: The food comes out steamed and not cooked
  • Anonymous Nov 12, 2008
    I have steam that leaks under the lid. I have just replaced the seal and plug and still have the problem. I am losing a lot of liquid and never getting pressure.
  • Jimi9746 Feb 26, 2009
    Where did you get the new seal?
4 Suggested Answers
cactus bob
  • 267 Answers
SOURCE: Steam escapes from pressure cooker
the gaskets are junk , i had to toss one myself i used one time then stored for a year and the gasket went bad , mine came from hsn when i called them ,there where no parts made for it . so out it went cheep china junk . sorry , good luck
Posted on Jan 16, 2009
  • 1739 Answers
SOURCE: The rubber seal on the
Replacement parts for the Wolfgang Puck pressure cookers are available here:
http://www.wpcookware.com/categories.asp?cat=29
If you do not see the part you require or are unsure about the model numbers; suggest you contact their Customer Service at 1-800-275-8273 or via their webform at:
http://www.wpcookware.com/contact.asp
Sorry someone has not responded sooner.
Posted on Apr 01, 2011
pms24-7
That is what happened to mine and I notice it was not the gasket, but plastic lock on the inside of the handle, it broke. Why make is out of plastic and controlled with a spring? DuH? This controls locking the handle and also hold the small pressure valve done. This caused the steam to escape before item is cooked even if it's not 100% broke and lid still locks.
Posted on Apr 06, 2015
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
How do I open the stuck lid on my Power Pressure Cooker?
The cooling food has caused a vacuum making it worse. If you heat the food very gently as not to burn the contents, the lid should open once it is hot. Release any pressure and try and open it again.
Jan 01, 2016 | Crock Pots & Slow Cookers
Manual for Mirro pressure cooker Model M- 0536-1
go google and type in -- user manual for mirro pressure cooker model m-0536-1-- and if there is one it will be a pdf version down load
make sure that the lid seal went in without any twists
put something under the seal and go around the lid several time to allow the seal to untwist
Oct 26, 2015 | Crock Pots & Slow Cookers
How do I remove a lid from a pot after it has been sealed by steam
What has likely happened is when the cooker heated up, the air expanded and escaped, when it cooled off, an air tight seal developed and the top acted as a valve and now the pressure is lower inside the cooker than outside. You need to break the vacuum... This may be done by gently prying the top a bit (carefully so as not to break it) or reheat the cooker. Is there liquid still inside? You could either turn it back on or possibly heat the entire cooker.
Dec 30, 2014 | Crock Pots & Slow Cookers
I do NOT know how to use i.e keep at pressure without burning stuff. This is my daughter's Sambonet pressure cooker, it has a strange looking style of lid lock down that is part of the pressurisation...
Pressure cookers rely on pressure and steam,
Do a dry run first...well not dry but with just water, (no food) especially if it's an old cooker.
Inspect for cracks or pinholes before you go ahead, a crack ANYWHERE in a pressure cooker makes it a bomb...or a flower pot.
Ensure all safety devices like the pressure regulator and blow out plug are in good condition and not plugged.
If some previous owner replaced the blow out plug with a bolt or something silly don't use the cooker till it's repaired.
Bring your pressure cooker slowly up to pressure over medium heat with an inch or two of water in the bottom.
When it starts to vent steam turn the heat down so the steam barely escapes, if it has a rocker weight it will wobble a couple times a minute.
Slow gentle heat is the trick. A cooker will run for hours like that without boiling dry.
A couple tips, use salt and spice sparingly, it's trapped in there and permeates the food.
Be careful with foods that expand on cooking like rice and dried things, they can get up and block the vents if they reach the lid.
TickMagnet
Jul 22, 2011 | Presto 01282 Aluminum Pressure Cooker Slow...
Do you lock the lid while cooking?
make sure u DO NOT lock the clips while cooking, its not a pressure cooker. if you lock the lid the heat and pressure from whatever you are cooking causes an air-tight seal and the lid will shatter or the ceramic pot it self will crack...
Nov 29, 2010 | Hamilton Beach Set & Forget Stay or Go...
The rubber seal on the inside of the lid always becomes loose and doesn't allow the cooker to come up to pressure. I always check it and make sure that it seems to be fitted properly, and when I actually...
Oct 31, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Steam coming out of floating valve on handle.
No. if the steam is coming out, the vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
Jan 16, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Steam comes out through rubber seal, it takes longer cooking, where can I purchase a seal.
try contacting the maker voia phone or computer,remember to include make and model number
Dec 16, 2009 | Faberware FPC800V 8-Quart
Jan 14, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Wolfgang Puck 5-Quart Electronic Pressure Cooker - Silver Logo
350 people viewed this question
Top Wolfgang Puck Crock Pots & Slow Cookers Experts
gbob59
Are you a Wolfgang Puck Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
