Question about Intertherm P3RA-048K Air Conditioner
Intertherm Heating and Cooling
My Air conditioner and heating is running at the same time, I can't get them to run seperately, any tips on how to fix the problem
  • recondoscout Dec 13, 2008
    when i turn on my heating from the thermostat the heat stays running as if at 70 degrees set it will not turn off it will continue to run until i turn it off
  • 828 Answers
I would say that you have ether a wiring problem or a faulty thermostat. The thermostat brings on the A/C through the Y terminal on your thermostat. The heating is brought on by the W terminal on the thermostat. If the wire for the A/C is shorting to the wire for the heating it would give the problem you are describing.
Posted on Jul 21, 2008
Why doesy intertherm air conditioner run most of the time
First off it may be undersized or too small for the area being cooled. the thermostat maybe un level if it has a mercury bulb. The cooling contactor could be stuck, or you may have wires shorted together.
Jun 22, 2014 | Intertherm Heating Cooling System 15kw...
How to fix intertherm mmhb-070a 2006 heater. light on control box is flashing 3 times
That's your fresh air damper control in most mobile homes. At some point the fresh air function is counter productive since it was intended disperse manufacturing fumes. Damper might be stuck or damper motor dead. Wouldn't worry about it.
Sep 24, 2013 | Intertherm Heating Cooling System 15kw...
Heating/cooling switch
I googled "intertherm richland hills" and got a list of dealers in my area. Such as
Give it a shot, hope this helps.
Nov 17, 2009 | Heating & Cooling
Not heating
1st you said the fan runs..but partial info so best guess it fan limit contor bad.
Jan 07, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm Furnace Will not stay on
Your furnace is likely getting too hot check your filter. make sure the fan is running. if you have weak air flow you may have a blocked heat transfer coil. you should have your heating and cooling system serviced yearly by a qualified company to inspect and test equipment.
Jan 04, 2009 | Intertherm Heating & Cooling
Intertherm heating
My heating unit is blowing cool air. The thermostat will start the blower when the unit is turned on at the thermostat, but the air isn't hot. But,when I turn the unit on at the furnace/blower using the "Fan On" button, I can see the heating element heat up. After the blower starts the heating element does out. What could be the problem?
Oct 29, 2008 | Intertherm P3RA-048K Air Conditioner
Adding a Condensing unit to an Intertherm electric furnace
you have the motor connected on more than one speed in heat mode. make sure inly one mode is connected
Oct 19, 2008 | Intertherm P3RA-048K Air Conditioner
Not heating
Yes, the reversing valve has a separate coil. some energize on cool mode, some on heat mode. Has the thermostat been replaced? I find this a common mistake.
Nov 03, 2007 | Amana Comfort Zone 18M33PCEH Air...
Intertherm P3RA-048K Air Conditioner Logo
284 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
