Question about Avaya Lands Phones
Change rings from 2 to 4 before answering machine picks up
  • Anonymous May 11, 2010
    What kind of system?
Problem solved after 3 hours of reading the manual and driving myself nuts
Posted on Jul 22, 2008
CHANGE THE NUMBER OF RINGS ON THE VTECH CS6719-16
The CS6719-16 isn't an answering machine. It will ring until someone answers, some other answering machine picks up, or the caller hangs up.
If you want to change the number of rings before an answering machine picks up, please reply to this post and specify the answering machine.
Apr 08, 2014 | Vtech CS6719-16 Cordless Phone with Caller...
How do I change the number of rings before answering machine picks up Vtech cs6619
The CS6619 isn't an answering machine. It will ring until you answer, an answering machine picks up, or the caller hangs up. To change the ring count on an answering machine, please refer to the documentation for that machine. If you require further assistance, please add a comment to this question and identify the answering machine.
Feb 17, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
How do I change the number or rings on my vtech cs6619-2
The CS6619-2 isn't an answering machine. It will continue to ring until someone or something picks up, or the caller hangs up.
To change the number of rings before your answering machine picks up, please consult the documentation for your answering machine.
Dec 05, 2012 | Vtech DECT 6.0 Digital Cordless Phone
My answering machine (phone line) is picking up when I dial my fax number. How do I set my fax machine up so that it will pick up when I dial the fax number?
Either your fax machine is set to answer on more rings then your answering machine is or you dont have the automatic answer key pushed?
Determine how many rings your answering machine picks up on and then change the number of rings to a lower amount on your fax machine. To change the number of rings before picking up the line, press the "menu" key on the fax machine and use the up and down arrows to scroll until you find the "basic fax set up" or the "advanced set up" areas. I am not sure which one will have the number of rings setting. Try looking in both until you find it.
when you see it press "ok" or "enter" get in and change the amount of rings before answering. call your fax machine to make sure it picks up before your answering machine.
This should solve your problem.
Mar 21, 2011 | Office Equipment & Supplies
I have an officejet 6500 all in one printer and I am setting up the fax section. It sends and recieve OK but my answering machine is picking up before the fax machine. How can I change that around so the...
You need to check the setup ..
The telephone line which is coming from out should be connected to the line 1 of the printer and Telephone answering machine should be connected to Line 2 .
2. You also need to check that after how many rings the Telephone answering machine answers the call you have to keep the "Rings to answer" 2 less than that of Telephone answering machine.
Lets assume that your Telephone Answering Machine answers the call after 4 rings then keep the rings to answer in All in One to 2
How to set Rings to Answer
1. Press the Setup button on the Front panel of the printer
2. Scroll Down and go to Basic Fax Setup - Select it
3. Scroll down and got to - Rings to Answer - Select it
4. Set the Rings here and then try Fax
it will fix the problem :)
Feb 26, 2011 | HP Officejet 6500 Wireless All-in-One...
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
GE answering machine 29870 How do I change the number of rings beffore the machine picks up
SETTING THE RINGS TO ANSWER
The unit announces the rings to answer. To change,
press NEXT or PREVIOUS. To set and go on to the next
item, press SET.
1. Press and release NEXT or PREVIOUS until the unit
announces and displays the correct number of rings
for the answerer to pick up.
2. Once the rings to answer is set, press SET to enter
the incoming message length menu.
Mar 24, 2010 | GE 29870GE1 Corded Phone
Machine is picking up after 2 rings with man's voice.
problem solved, grandkids used other phone with answering machine and left it in different mode "7" so it was picking up after 2 rings...thanks for answering my request.... solution solved... Thanks, Netta
Aug 07, 2009 | Casio TA-111 Digital Answering Machine
Fax feature
You have to set the printer to pickup 2 rings higher than your answering machine. If the answering machine picks up on 4 the printer should pick up on 6.
I believe the menu should be Setup button - down arrow key until you see basic fax setup and press ok - down arrow key until you see rings to answer and press ok - change to 2 higher than answering machine.
Now you should receive faxes and calls!
Jan 05, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Lands Phones Logo
61 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
