Question about Sony Cyber-shot DSC-W50 Digital Camera
Fix my camera
Somehow i am unable to fix the problem with my lens pulling on and off
tell me what to do please?
  • 58 Answers
Either check into your warranty, or buy a new camera.
Posted on Jul 21, 2008
Nikon 18-55
Unless you have a lens collimator and other equipment required to ensure proper alignment when you disassemble and then reassemble the lens, you'll have to pay to replace or repair your lens after you attempt it.
May 08, 2012 | Cameras
I have a sanyo vpc-e1090 which displays a Lens Error 0x0311. The camera powers up then shuts down. I am unable to get into the menu to check any setting. Any ideas on how to fix this issue?
Maybe the lens are blocked.
Try :
1.- Turn OFF the camera and push softly the lents
2.- Turn ON the camera and PULL softly the lens.
Is importan to people who share knowledge hear your comments or received rate points
Sep 16, 2011 | Cameras
Error message "lens not open properly" unable to
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Jan 12, 2011 | Sony Handycam DCR-DVD108 DVD Camcorder
Panasonic Lumix System Error (zoom)
Hello
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
Regards
Andrea
Aug 06, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
NIKON COOLPIX
The Camera displays lens error only when it's unable to retract or expand. This usually happens when the internal Hardware that controls the lens fails or any dust particle settles around the lens. In this case, just give slight bumps to the Camera against your palm. If the issue persists then service will be required.
Dec 01, 2009 | Nikon Coolpix 5700 Digital Camera
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
E 18 problem
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 12, 2009 | Canon PowerShot A400 Digital Camera
M547 camera lens will not open
My son has this camera and dropped in the sand this summer. He had the same problem.
I found this blog posting.
Read it. And try all the techniques.
I took the camera to our photo printing store and the guy sprayed it with compressed air. It didn't do the trick but I think it helped. We tried all the techniques in the article. In the end I put some WD-40 in a dish and used a toothpick to drip the WD-40 into the space between the lens barrel and the camera case. I powered on the camera while my son pulled on the lens. He pushed back the flaps and pulled from them. Somehow, after several tries - and I was ready to give up - the lens opened. We still got a lens error message. We kept brushing away and blowing out sand and turning the camera on and off. Eventually it started working. However, the zoom is not working. But we are going to go back to the photo store and have him blow more air into the lens.
Good luck. Hope this isn't too late and helps you.
Aug 10, 2008 | HP Photosmart M547 Digital Camera
Lens Error unable to switch camera off
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 27, 2007 | Nikon COOLPIX L2 Digital Camera
Canon SD600 lens jam
I followed the directions contained in http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/ and by disassembling the camera and turning the rotor just a little bit (page 4 of the instructions), it freed up the lens and it is now working perfectly! The camera had been put down on the lens as the lens was retracting and I assume that jammed the retract mechanism. While the camera was open, I blew out whatever dust/dirt was there (didn't see much). The fix took me probably 20-30 minutes, and I am very pleased with myself!
Oct 24, 2007 | Canon PowerShot SD600 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
18 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
