Question about Tappan TGF657 Gas Kitchen Range
Clock and temperature lights are very dim
I have a Tappan TGF657 36" gas range. It works great, except I have difficulty seeing the aqua colored numbers of the clock and the orange colored numbers for the temperature. Is there a way to fix this problem?
  • pmazza419 Oct 21, 2008
    both clock light and temperature lights are dim on my TEF367 tappan range
  • Anonymous Oct 21, 2008
    same here
huuum
  • 750 Answers
SOURCE: Oven shuts off
astrosandiWelcome to fixya.
I'm Huuum and happy to assist you,
you asked , Is there a recall on this Tappan range? You are exasperated; you have replaced the electronic control three times in the last six years and the clock still blinks off and on occasionally and the oven shuts itself off. Totally frustrated and would never buy this oven again.
What is the model number?
How old is the range?
Don't put good money into bad!
You need to shop quality and not price!
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old range
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your range,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your range is under warranty or less than four years old ,
paying for a repair makes sense.
Note that ranges under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your ranger is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new range.
Data also shows that it doesn't pay to fix a less-expensive range
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of ranges you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Repair or replace?
Please remember to give a rating before you sign off!
Posted on Sep 24, 2008
SOURCE: tappan 36 gas range display says door loc how do i unlock
let it stay locked it will open by itself, it is just going through a scanning prossing
Posted on Dec 26, 2008
SOURCE: TAPPAN GAS RANGE, CLOCK CONTINUALLY
I CALLED TAPPAN DIRECTLY. THEY HAD ME TRIP THE BREAKERS WHICH DID NOT HELP. THEN I HAD THE GAS CO COME OUT TO MAKE SURE THERE WASN'T A GAS LEAK. THE CLOCK STOPPED BEEPING ON IT'S OWN AFTER THE SERVICE MAN MOVED THE STOVE OUT TO INSPECT IT. THE NEXT STEP WOULD HAVE BEEN TO HAVE A TAPPAN SERVICE COME OUT, BUT I GUESS I'LL NEVER KNOW WHAT THE REASON WAS. HOPE IT DOESN'T HAPPEN AGAIN,.
Posted on Jan 17, 2009
milten1
  • 1304 Answers
SOURCE: I HAVE A CLOCK TIMER FOR A TAPPAN STOVE PART # 3181012300
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153988
depending on the color of your range but black goes with everything
Posted on Oct 21, 2009
  • 3 Answers
SOURCE: tappan series 110 gas range
Takes about 15 minutes to fix. You will need a philips head screwdriver, pair of scissors and a butter knife. What you're going to do is cut the wire to the beeper. Your clock will still function.
Start by removing the glass faceplate that encloses your clock. By removing the 2 screws on either side of the metal housing, you can remove the faceplate (you'll have to remove the clock's pushbuttons, but that isn't hard, either. I used some spring-loaded pliers to get a good purchase, then pulled straight back. Oh yeah. You need pliers, too. Don't worry, you won't break the buttons; they'll snap out and push back in, later). Use the butter-knife to carefully work the glass out of the metal frame. The actual clock is secured by a couple more screws, which are easily removed, once you've removed the abovementioned faceplate.
[The clock, btw, is made by Fridgidaire (part # AP2125434 ), in case you want to replace it. Costs more than $130(!)]
If you haven't already unplugged the stove, now is a good time. Do not touch the two metal connectors of the two most prominent wires on the back of the clock, when the unit is plugged in! Yes, it's the voice of experience, talking...
You will notice, when you're looking at the back of the clock unit, a small metal disc, enclosed in plastic. If you plug in the stove, and listen, you should hear the beeping coming from this area. There is a medium-sized hole in the middle of the plastic housing, allowing access to the metal disc. There are two very small wires, red and black, leading into the housing and attached to the disc in two places. One wire is attached to essentially the center part of the disc. The other wire (in my case, the black wire) is attached rather toward the outer edge of the metal disc. The outer edge is even a slightly different color, so you can identify the two parts. In my case, the sound was emitting from the outer edge, as opposed to the center portion of the disc. If you press a Q-tip against the center portion of the disc (thru the hole in the plastic housing), and the beeping continues, unchanged, the sound is probably coming from the outer edge. You can check by bending the Q-tip, and working the tip over to the edge of the metal disc--by applying pressure, you should hear the sound change, slightly.
Unplug the unit, and cut the wire that corresponds to the part of the disc the sound is coming from--that should solve the problem!
Posted on Nov 16, 2009
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
My oven temperature light is so light I can hardly see it. How do I change the light?
you need to change the clock assy. the part number is 316455410 and it's around 65 bucks,that isn't the full model number so when you order it give the parts store the full number and you need the overlay,this number is for a black overlay 316220705 and that's around 20 bucks.let me know how you make out and if this was helpful,good luck
Nov 03, 2010 | Tappan TGF320 Gas Kitchen Range
TAPPAN MODEL 3 TGF367CFSA, GETTING A F3 CODE, OVEN DOES NOT WORK
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
Feb 07, 2010 | Tappan TGF364AS Gas Kitchen Range
TAPPAN GAS RANGE, CLOCK CONTINUALLY BEEPS. IS IT AN ALARM FOR GAS LEAK OR ANOTHER PROBLEM?
Jan 16, 2009 | Tappan TGF363 Gas Kitchen Range
Tappan Millennia range's baking component doesn't work.
Your ignitor has gone out or is no longer drawing enough current to open the gas valve. Replace the oven ignitor and it will fix your problem.
Nov 26, 2008 | Tappan TGF320 Gas Kitchen Range
F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Oven won't heat
try replacing the oven igniter/ glow bar the thing you see light up it sounds like it is weak you can tell if it glows with a white color in the bar it should glow a bright orange color
Aug 28, 2007 | Tappan TGFS_63 Gas Kitchen Range
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Jul 20, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan TGF657 Gas Kitchen Range Logo
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
