Question about Sony Handycam DCR-DVD201 DVD Camcorder
All of them?
Hi, my computer recognizes the camera but only as a blank disc, i cant read or extract any files from the recorded dvd. do you think the solution is the same to unistall the universal serial bus controllers? and if so, do i have to unistall all of them i(i have 7)? will my usb ports work again? windows will ask me to reinstall them again by it self or i have to do something to reinstall them?
thank you so much!! sorry for all the questions but i dont want to mess up :/
greetings ruth
    Sergeant:
    Champion:
  • 319 Answers
May sure your computer is set to NTSC format
Posted on Aug 01, 2008
Disc load problem
DVD players need a finilized disk. When the program finilizes the disk, it's writing the TOC which is where the players go to find the files.
Mar 12, 2014 | Toshiba RD-XS34 DVD Player/HDD Recorder
Hello trying to upgrade my HCT HBR-1000BP Blu-ray Player firmware and can not figure out how. No support on HCT website. Would be thankful for any help
Where are you having a problem? I found directions on: http://hcthk.com/mall/s02.php . There were two links, one with directions and one with an arrow for downloading the needed file.
The firmware is in a zip file. First extract the files from the compressed archived. (For a Windows OS, right click on the folder and select Extract All.) If needed, open the new uncompressed folder and put a blank CD-R or CD-RW in your optical burner drive. Burn the two files from the extracted folder to the CD (drag and drop will work for any version of Windows (XP-7).) Do not include the folder, just the files. Then finalize the disc (close the session). If you are asked to format the disc, choose a mastered burn (single-session). In Windows Explorer, you can do this by right-clicking on the optical drive in Computer (My Computer) or from the menu for the drive when you double-click on it. (Alternatively, if you have your system set to finalize on eject, then choose Eject. This setting is in the drive's Properties (the Recording tab).)
Eject the disc from your computer and turn on the HBR-1000BP. Place the CD that you burned in the player. When the disc is recognized, press Play. If that doesn't work, try entering the System Menu and choosing System Update with your remote. Do not power down the unit during the update; a power failure during the update might leave you with an unusable player.
If this doesn't work, check if the Blu-ray Player reads any CDs. If it doesn't, try cleaning the laser lens with a CD/DVD lens cleaner. Then try again. The Blu-ray uses a different laser. If no disc works and the lens cleaner doesn't help, the CD/DVD laser has a tracking (alignment) issue or another problem. You'll need to get the optical drive in the HBR-1000BP replaced or fixed.
If it does read a different CD, then check if your optical disc burned and was finalized correctly. Can another optical drive read it? Try burning the files to CD on another optical drive. (If you are using an external optical drive burner, make sure that the computer is not running on battery power. Plug the external drive into two USB ports if it isn't self-powered.)
I hope this helps.
Mar 31, 2012 | Televison & Video
I keep getting the message...'Recording on disc disabled' or 'Drive Error"...just wondering if anyone knows how to fix this. The disc in the recorder is half used so I cant ec=ven look at what is...
Try reading the disc on a computer that has a DVD drive - should be able to detect what files are on it. If you can't record anymore, then the disc probably got "finalized" on the camera.
Nov 13, 2010 | Sony Handycam DCR-DVD805 DVD Camcorder
Won't work with the same kind of discs i've used before
I not sure as to which type of Discs that you are refering to (ie DVD+R or DVD+RW). This player will only recognize 4x (max) DVD+RW and 8x (max) DVR+R discs. If the DVD+R Disc is 16x, the DVD recorder will not recognize it once you start to record. The player will read the blank Disc and give the impression that it will record on it. I have noticed that when a 16x speed Disc is in the Drive, The recordable hours for the disc seems to double. The normal 6 Hour recording length comes up as 12 Hours when you hit the info button. Since the 8x Speed (max) discs are not available any longer, I found it best to use the DVD+RW 4x Discs and make it compatible. I then copy the compatible DVD+RW disc to a 16X DVD+R disc using my computer DVD burner. The DVD+RW disc can then be erased so that it can be reused.
Nov 23, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Have a cannonDC310 dvd camcorder,how to transfer the video to pc
Nice camera you can record directly to the 3.5 inch mini dvd's available virtually anywhere including walmart and Fred Meyer, those mini dvd's are playable on your computer and you can copy the files on them to your computer by placing them in your computer cd/dvd drive right clicking on them hitting explore highlighting the files you want to copy right click on them hit copy open the file you want to put them in and right click in that file and hit paste. You don't need cables, just put the disc in your computer. Be sure to read in the manual how to close the disc before you take it out of your camera or your computer won't recognize it.
May 12, 2009 | Panasonic PV-GS31 Mini DV Digital...
DVD writer not working
Let's make sure that Nero is not causing the problem. Try this:
-Insert a blank CD or DVD
-Find a file that you want to burn to disc
-Right-Click on said file and select Send To --> DVD-RW Drive (D:) (or whatever your recordable drive is labeled)
-Open My Computer, double click on your recordable drive
- You should see your file ready to be burned to disc
- In the left-hand panel, you should see a link that says "Burn these files to disc" or something similar - click this link and see what happens
If this process works and properly burns a disc, your issue is not with your drive but with Nero. If this process does NOT work, then you may need to reinstall drivers for your DVD writer or replace the drive if it is faulty.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 11, 2009 | Compaq 6710b Notebook
DVD-RW not recognising blank disk
Usually HPs are good with +R DVDs unless things have change over the last year or two.
Whats the model number on your computer?
Aug 09, 2008 | Tablets & eReaders
Can anybody help me, I purchased a Samsung dvd recorder model dvdvr350m, since purchasing the unit it will not recognize that it has recordable dvd's in it (dvd-rw),it tells me no disc inserted please...
Did the sales guy use the same DVD-RW that you did? Maybe the brand you are using is not of good quality and can not be recognized by the recorder. If he did not use the same disc did you notice if he used DVD-RW or DVD+RW? Some DVD-Recorders only recognize one or the other but this is kind of rare these days. I recommend verbatim brand discs. They should be available for sale at any shop. If you want the ultimate in quality DVDs then go with Taiyo Yuden. This Japanese brand invented recordable media and in addition to that they are obsessed with quality. www.supermediastore.com is always where I get my discs.
Thanks for reading!
Hope this was helpful
Apr 30, 2008 | Televison & Video
Hd writer 2.0E fro sx/sd
I had this same issue...I bet you're using DVD-R, am I correct?
Apparently you can't copy video from DVD-R to the HD Writer. Period. Just can't do it. (Would be nice if they mentioned this in the manual.)
You can only use DVD-RW and must format the disc to VR format, not Video format.
I'm using a program called Handbrake (free) which I think can convert your .vob files (from the Video_TS folder on your DVD) to quicktime files, or similar, so that you can actually do something with the video...
Best of luck, I'm really no expert, and I probably won't return to this page, so a reply to me is likely not going to be read by me...
Feb 07, 2008 | Panasonic HDC-SX5 DVD Camcorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Sony Handycam DCR-DVD201 DVD Camcorder Logo
41 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
