Question about Uniden Solara - VHF Marine 2-Way Radio
I cannot send, only recieve
I can hear others talking, but they cannot hear me. All they can hear is a "click" when I try to talk to them? any suggestions
    Brigadier General:
  • 6,966 Answers
Based on your description, possibly a microphone problem. Either that or a wire is cut/open in the microphone cable. Remote possibility is the FM modulator circuitry internal to the marine radio.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 25, 2008
I can recieve conversations clearly. I respond and it sounds like I am under water
The mic is probably your problem but...if your radio has ssb/lsb make sure your on am and the clarifier knob is in the center. Really need to know the specs and radio make ?
Oct 10, 2012 | Cobra Radio Communications
I have a walkie talkie i can talk to the reciever and hear it but i cant talk back from the reciever
Check your private line code (aka tone code or interference eliminator code). One of your radios possibly has it set differently than the other.
Sep 24, 2011 | Radio Communications
Bluetooth from lg 290cm
Straight Talk phones can only send and recieve items via bluetooth to other Straight Talk customers
Nov 15, 2009 | Cell Phones
My cb transmits with a very weak signal and won't recieve anything. The weather band recieves with no problems. I couldn't even pick up a signal on my SWR meter but a friend of mine tested it on his home...
There are a few things that could be wrong. If there is something wrong with the mic, you may not hear anything on the radio. but weather will work.
Other then that, the receive section of the radio could be blown.
Try a new mic, and if it doesn't work, then there is something blown in the radio. It needs a tech.
Sep 25, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Can not receive or send fax. When I send a fax, it says no answer, when I try to receive a fax, the other side hear it was ringing on and on, but they did not get the receiving signal.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq22
Aug 18, 2009 | HP Officejet 5610 All-In-One InkJet...
Fail to send and recieve
Well it was fixed after I called our telephonecompany.
They told us last Thursday that the lina was ok, but yesterday I talked to a extremely competent callcenteragent and he could confirm the problem lay in the connection.
So, it wasn't a problem wit the JX200 after all.
Jun 03, 2009 | Canon FAX JX200 - Fax / copier - ink-jet...
One micro talk 1 can ring the other and talk & one does not ring
the other set is not transmitting but its able to receive,
so a transmitter be checked.
Mar 29, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Calling sound problems
I have verizon, had the similar problem. Call *611 speak to someone in tech support, and have them send you out a replacement phone. If your closer to a store you can do the same thing, don't have to wait for the mail ha ha. Good luck though! Hope I've been of some assistance!
Mar 18, 2009 | Verizon Communications LG enV Cell Phone -...
Cant send recieve picture messages
try send ytour self a picture message i would also talk to your service provider maby tou havent done your settings properly, hope this is some help to you! also some networks wont accept photo from other networks
Dec 28, 2008 | Samsung SGH-G800 Cellular Phone
Uniden Solara - VHF Marine 2-Way Radio Logo
303 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
