Question about Intel D915GAG Motherboard
Motherboard not powering up
Tested the mobo on the bench with a power supply and monitor, powered up o.k. and looked at the bios setup. Installed the mobo into my case, connected all the power leads (with the power supply in the case) and all the cables, etc. Mobo did not power up. Nothing happens at all, no fans start. Pulled out mobo and tried it on the bench again, with the power supply I used to test it before on the bench, and the same problem. It still doesn't power up. Has anyone had this problem before?
    Problem Solver:
  • 5 Answers
Check the smps its purely smps problem
Posted on Jul 22, 2008
  • srinu babu Jul 26, 2008
    The problem is due to eitther problem in RAM or Problem of SMPS. Please replace with anothter RAM and check if the problems persists, then change the SMPS..the problem be get vanished.,. if still u feel it...definatley it would be the internal defect of the MB...just call to the customer service of ur MOBO vendor and sat serial no and AA number then they will pick up ur mother board.....
Problem with the P4M800-M7A Motherboard Hi all, the power supply burnt out. Replaced the power supply, pc turns on and fans running etc but nothing on the screen! Is the mobo fried?
May be. have u tried another monitor? if not then pls try to do that . If the other monitor does not work then it can be an issue with the motherboard......Do u have any graphics card installed? IF yes then then setting are needed to checked and changed (if necessary) in bios.
Feb 17, 2011 | Computers & Internet
Gigabyte mobo soft start power up not working
assuming that u r a professional..
hv u tested the 3.3v..the ram..the cmos battery (above +3v)..the cpu..
if so look for the smd fuse..capacitors (esp above 1000mfd)..mosfets..circuitry at the south bridge..the crystal clock generator..
hope this'll work..else contact system admin/vendor....
Oct 30, 2009 | Intel Motherboard
Installed new Mother board and cannot get the power supply to turn on computer. How can I tell if the Power supply is bad or something else is wrong?
First off is the power supply powerful enough for this new mobo? is it new, old?. Is the motherboard securely earthed either in the case or on test bench?
If you have it in a case already strip out everything leaving just the motherboard and graphic card in. Power up now.
If this works put the memory back in.
Then hard drive etc until you have everything you need installed.
If it doesn't work you should try another graphic card if you have access to one. Also make sure the graphic card is seated properly.
If none of the above works then there is a good chance you have a faulty motherboard so best to replace it.
Oct 16, 2009 | Gateway Computers & Internet
Machine doesn't power up
Remove and reseat all memory, power and processor.
Check your power supply and if good check the board for bad Caps.
Sep 20, 2009 | Abit KV-85 Motherboard
Hardware monitor found an error
First I would make sure all the power plugs are properly plugged into the motherboard and all other devices.
If that does not solve it then I would get the Power supply tested at a local PC shop. Or just get a new decent power supply. Looks like the Power supply without a doubt is defective.
Jul 08, 2009 | ASUS A7V333 Motherboard
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
K8N motherboard
Have you tried a secondary PSU? (though it sounds like your motherboard needs replacing)
May 23, 2008 | ASUS K8N Motherboard
My Asus mobo P5ld2 cant turn on
Did you try to unplug all AC Power; remove internal surface battery; and then jumper the 'reset' pins from 1-2 to 2-3 ? Leave in this state for about 5 minutes- then replace battery; re-jumper back to pins 1-2- replace AC power cord. Sometimes wiping out the BIOS setup information and restarting/re-setting it up will do the trick!
Apr 12, 2008 | ASUS P5LD2-VM Motherboard
Pc resets itself
Hello
If you havent check it with an other power supply(atx) plz TRY and tell me what happened
AYADI
Apr 05, 2008 | Syntax SV266M Motherboard
P4i65G - brand new want start.
Try getting a slower cpu, I have a 3.0Ghz P4 with 512mb of ram and it works great, I emailed them about upgrading ram and they said: "Upgrading the memory would not affect the Video card, unless the memory is not compatible with the motherboard, then the computer might not turn on at all."
Oct 24, 2007 | Asrock P4i65GV Motherboard
Intel D915GAG Motherboard Logo
178 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
