Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door keypad & remote
I recently entered a password on my keypad and now my remote will not function. What can I do to fix that?
You need to sync both. I have a LiftMaster. If you want to change the code on your keypad you need to open up the garage door motor compartment where the light is (mine is in the back). Press the learn button, within 30 seconds enter the new code on your keypad and hold down the enter button for several seconds until the light on the opener blinks to tell you it has learned the code. Test the new code to see if it works. If the new keypad code works, then try the remote. My remote will not work after I reprogram the keypad. If the remote does not work (check battery) then climb back up the ladder and press the learn button on the garage door motor again, press the remote button and hold down until the light blinks again and the opener has learned the new code. This process works when I need to sync my remote and keypad. Good luck, I hope this helps.
Posted on Jul 25, 2008
NEED TO CHANGE PASSWORD ON KEYPAD
If it is a wireless keypad you need to locate the smart/learn button which is near where all those white wires go. Press and hold this for 6 seconds. This will erase the memory and none of your remotes or keypad will work.
For the keypad: Press and immediately release the smart/learn button and walk over and key in any 4 digit PIN you like and press enter.
For your remotes: Hold down the button on your remote and then press and immediately release the smart/learn button. Do this for each remote.
Sep 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can't reset remote keypad
Press and immediately release the SRT button and then walk over to your keypad and key in any 4 digit code you like and press enter.
Aug 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
How to reprogram Sears Mult-Function Keyless Entry garage opener
On the garage opener that actually opens the door the one on the ceilling has a green or orange button that is called the learn button just press and release it you have 30 seconds to punch in a 4 digit code and when your done press and hold the enter button until the lights on the garage open blink once or twice then just press the code again and it will open the door press enter once to reverse the effect and and twice to stop the door completely.
Hope that helps
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens on it own and light blinks
  • Stuck remote control button. Check all remotes. check LED on receiver.
  • Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
  • Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Clicker garage door keypad works inconsistently
no relation. did you plug rpm sensor and logic board connectors on well.
Dec 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftman Garage Door
I enrolled in the Assistant Premium Plan and am waiting on a response.
Apr 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
I was having a problem with the remotes. Program one remote, and the other stops working and vice-versa. I found the solution to be as follows: Using 61LM single-button remotes for Lift-master WhisperDrive (belt drive) garage door opener, I set the dipswitches (find them by removing battery replacement cover) to identical settings in both remotes. Set the first dipswitch to the neutral (0) setting. Next -- and this is the important part -- press the learn button on the main door opening unit, and, while the small LED light is lit, press the button on ONE of the remotes. DO NOT REPEAT ON THE SECOND REMOTE. Upon doing this, I found that BOTH remotes at last worked. I then went on to program a keyless entry pad, which was accomplished by again pressing the learn button on the main unit, and then entering the number sequence I had chosen for my entry code on the keypad, and pressing Enter. Both remotes continued to function and the keypad functions as well.
Mar 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
390 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
