Question about Hoover Washing Machines
Water overflows to the floor instead of going through the hose into the sink
    President:
  • 1,462 Answers
Sounds as tho the drain hose is split
Posted on Jul 22, 2008
HOW DO i STOP WATER FROM DRAINING FROM THE TOP OF THE SINK, i HAVE A BOSCH DISHWASHER AND WATER COMES FROM THE TOP OF THE SINK INSTEAD OF A NORMAL DISPOSAL OF THE WATER WHEN IT STARTS ITS FIRST CYCLE.
I am assuming by 'top of the sink' you mean the overflow drain as opposed to the regular drain in the bottom of the sink.
It should go into the same drain somewhere under the sink but a picture might help see whats going on?
Jan 10, 2018 | Bosch Dishwashers
Tip
Clothes Washer won't stop filling with water?
If your washer continues to fill with water and does not overflow onto the floor where is that water going???
The water is siphoning from the machine as fast or faster than it it filling. This is caused by one of two situations both have to do with how the drain hose is routed.
The most common is that the drain is too low. The drain for your washer must first rise above the height of the tub or highest water level before it enters the house drain or drainage sink. This height is typically a minimum of 30". So if you are trying to drain the washer into a low pipe, a short sink or down hill you must first raise the hose or piping to that 30" before it heads down hill.
Second cause is where the drain hose is pushed too far into the house drain. A typical drain pipe in the home has a water trap at the bottom. If you put your washer drain hose down into the pipe too far and contact the water in that trap you will also siphon the water from the machine. The drain hose should hook and be secured to the drain pipe and go inside about 6", that's all that is needed.
Other washer issues:
SUDS http://www.fixya.com/support/r4621260-many_suds_in_clothes_washer
ODOR http://www.fixya.com/support/r4621314-odor_from_towels_or_clothes_washer
Control Locked http://www.fixya.com/support/r4624473-control_locked
on Apr 23, 2010 | Washing Machines
Unit is leaking water from somewhere
Upper drip pan drains clogged, water overflowing onto the floor.
Remove the rear cover of the unit and clean it thoroughly wit a vacuum. Let the unit fully defrost. Use a can of Air duster (for pc's) with the little hose on to clear the drain holes in the upper drip tray. Clean dirty evaporator fins with windex and toothbrush, flush with water. Excess condensate should now drain into the bottom tank instead of overflowing ontot he ground. Be sure to drain the bottom tank thoroughly. With the unit cleaned it should now vent condensate out the warm air duct rather than letting it build up in the unit.
Jul 06, 2012 | Windchaser PAC9 Air Conditioner
Pump continually running with F2 displayed.
There is water in the lower pan that you must access by removing the toe kick plate and then the panel behind it. you will see water in the overflow area. Clean that out and all will be well. Asko's are awesome dishwashers that capture any water they may overflow or leak internally instead of it going on your floor, then a float switch triggers the F2 error and runs the drain pump.
May 30, 2012 | Asko D1716 Built-in Dishwasher
Water vALVE DOES NOT QUITE SHUT OFF. AFTER WASH COMPLETED, water leaks slowly into tub and overflows onto floor. iT IS TYPE 1353-1. wHAT IS PART NUMBER FOR WATER VALVE? pRICE AND WHERE i CAN GET ONE? tHank...
If you can supply the Product number or model number I would be able to help.It would not be a major expense for a new inlet valve.Check if the drain pipe from the dishwasher if going into a pipe outlet in wall that it is not too far down into pipe as this could cause it to syphon back into unit.Also if drain goes to a sink outlet make sure the drain hose is above any other outlets,you could tie hose up into a "U" shape above outlet this will stop waste from sink getting into Dishwasher.
Hope this helps.
Jun 07, 2010 | Dishwashers
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
Dehumidifier emptys in the floor.
Check the float first - be sure the styrofoam on the bottom is still intact.  Be sure that you can move it up and down freely (and easily) with the bucket out of the machine.  If that is not bound up, and the foam is in place, next check the switch in the dehumidifier itself.  It's directly behind where the float goes - the way to test it is to turn the dehumidifier on and push the metal tab in with your finger.  The machine should cut out immediately - if it does not - the microswitch needs to be replaced.  (they're very cheap, and simple to replace)
Sep 13, 2008 | Maytag M7DH45B2A Dehumidifier
Dishwasher drains into sink
As background, the dirty water typically goes from the dishwasher to a small tube within a tube, and that goes to the disposal. This ensures that your dishwasher does not back up in the event of a clog.
The problem is likely that the tube that links the thing you see next to your faucet to the disposal is either totally or, more likely, partially blocked.
I recommend taking the entire flex pipe off and inspecting. In my case it was about 80% blocked, so a simple test whereby water was pored down failed to show the issue.
Once I took it apart and gave the tube a plumbing version of an angioplasty all was well.
Dec 31, 2007 | Tappan 18 in. MDR251RE Built-in Dishwasher
My dishwasher won't drain the water
Check under your sink where the hose connects to the tail piece. I had this problem and the piece of the tail piece where the hose connects was stopped up.If the drain hose runs to an airlock mounted on your sink, then check it too.
Jun 13, 2017 | Frigidaire 24 in. FDB636GF Built-in...
Washing Machines Logo
27 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
