Question about HP CD-Writer Plus 7570i (C4411A#ABA) CD-RW Burner
Color of monitor
I have 14' Inch Microtek VGA Monitor, the issue is that the colors seems to be fadedout or missing. Red color appears as black & its really hassle. Kindly suggest the best resolution.
Change the moniter is the best solution, coz repair could be cost more than its worth
Posted on Nov 04, 2008
Red cable crt
Sometimes certain pins are missed or added more.
Or some pin connection are bad.
Try this.
Use VGA to DVI adapter from laptop and see what happes.
Jun 21, 2013 | HP L1910 19 inch LCD Monitor
Shaded areas on my X2gen 19 inch monitor do not Show up.
It sounds like the PC video color setting is at 16 instead of 24 or 32 bit color setup. You need to check the display properties setting on the PC (Right click on the desk top). Also try it on other PC and also check the VGA cable.
Apr 07, 2010 | X2Gen MG19MY 19" LCD Monitor
Red color missing in LCD monitor
if under warranty contact the manufacturer for repairs. otherwise you'd be in the market for a new monitor.
Also check your graphics card. Might be causing the problem rather than your monitor.
Jul 14, 2009 | Acer 22" X223w LCD Monitor
Color change
1. red colour on the screen , or redcolour missing. redpatchs on the screen. tell me.
(1). in case red colour on the screen red colour missing.change the vga male connector.
2. red patches on the screen external digosing use.
Oct 13, 2008 | HP Pavilion M703c 17 in.CRT Conventional...
No color red displays.
If you think that electronic repair is very difficult to learn then you have to read this article where only by using a solder gun could solve a Monitor color problem. Of course there were many tough dog cases (very difficult to find out the fault) in electronic repair but at the same time there were also many cases that can be solve by some simple ways. This G70fmb Monitor came in with no blue color problem. How do I know if the blue color was missing? Simply run a color test (that you may also download from the internet) or from a Monitor testing program generator, you could clearly see as which of the color is missing when you run the color bar test.
A missing blue color in the Monitor could cause the display to turn yellowish. Troubleshooting color problem is one of the easiest in Monitor repairing. Whether the missing color is from blue, red or green there are some areas that you need to check in order to successfully repair it. Here are some of the points that you need to check:
- A bended color pin at the VGA connector. (If pin one is bend then there would be no red color)
- A defective VGA signal cable. If the internal wires were broken then there would be missing colors. You can check if the signal cable is good or bad by doing a continuity test using a multimeter.
- Dry joints in the CRT board such as in the CRT socket pins, video pre amp and driver IC and even at the connector pins. In fact this problem contributed about 80% of Monitor color problems. Applying fresh solder would usually solve the color problem.
- A defective IC either in the Video Pre-amp or Video Driver IC.
- Faulty components in the CRT board. It could be a shorted driver transistor or even electrolytic capacitors that the ESR reading had shot up!
- A bad CRT socket. Sometimes decayed glue could cause the internal pins rusted and thus affecting the colors. Replacing only the CRT socket would definitely solve the problem.
- A weak or a defective picture tube (CRT tube). Yes, I do came across one of the electron gun (most probably the cathode materials had used up) in the tube faulty caused a missing color in the screen. There’s no way to repair this type of problem-the only way is to replace the CRT tube.
- In the newer type of Monitor, color setting is save in the EEPROM IC . Thus, if the EEprom data is corrupted, you would also get a missing color! The only way to repair it is to reprogram the IC or use a soft jig to tune it back the color setting.
Now, which one of the above is the easiest to start with first when comes to troubleshooting the color problem? I believe you would agree with me that the first, second and the third are the easiest compare to the rest. Normally I would hit the Monitor with my bare hands to see if there are any changes in color at the display (be careful not to hit too hard till the casing broken). If there is a change or flashes then I can say that the Monitor has dry joints. And if it stills the same no matter how many times I hit it, I will then starts check the VGA connector and the cable.
In the above Monitor, the problem was dry joints because when I softly hit it with my hand at the side of the Monitor, the blue color immediately appears. The aluminum shielding at the CRT board was opened and I could clearly see lots of dry joints especially in the video pre amplifier and the video driver IC. When you resolder please don’t just touch on the IC’s only, you need to resolder others area as well like the CRT socket pins. Doing this would prevent any color loss again in the future. A good job would prevent call back and to save you time and money and most of all your reputation!
After everything was done, you then need to gently knock at the CRT board again with the plastic handle of the screw driver to see if the color problem still exists. You may also knock on the main board just in case there is any dry joints there. One more thing, if you find that the Monitor is a bit dusty, you may use a vacuum cleaner and a brush to clean up the dirty area.
Whether you are repairing the g70fmb or any other brand of Monitors, if you come across any monitor color problem, you can always use the procedure above to find out the fault. If the VGA signal cable is okay and there were no dry joints in the Monitor, I guess the only way is to use voltage testing method and start checking components with your tester or meter.
Aug 05, 2008 | ViewSonic G70fmb (Black) 17" CRT Monitor
Samtron vga cabal color coding problum
SIGNAL CABLE WIREING.
1) RED
2)GREEN
3)BLUE
4)GROUND
5)BLACK SHIELD
6)BLACK SHIELD
7)BLACK SHIELD
8)BLACK SHIELD
9)BLACK
10)VILET
11)
12)ORANGE
13)SHIELD
14)YELOW
15)WHITE
Jan 23, 2008 | SAMTRON 55V 15" CRT Monitor
One of the primary color is absent
Hey Kuld.. Just asking... since both, your TV and your monitor have the same color issue...??.... have you been to the optometrist lately... (My Dad had this color issue with his eyes!).. he was red color blind..
Good luck,
Jun 20, 2017 | LG Studioworks 700B (White) 17 in.CRT...
Benq v772 CRT show only Blue and Green color
It has to be either a cable or an IC issue. Get your cable checked first (VGA cable)
Oct 01, 2007 | BenQ Value V772 17" CRT Monitor
Monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
May 13, 2007 | SAMTRON 55V 15" CRT Monitor
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
HP CD-Writer Plus 7570i (C4411A#ABA) CD-RW Burner Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
