Question about Singer 7462 Mechanical Sewing Machine
I have a SINGER "Esteem" model # 1732. My problem is that no matter how much I adjust the tension, the thread just snaps instead of sewing...sometimes it sews an inch or two before stopping. Also, even if I change the stitch pattern, it doesn't do any of the other stitches, just plain straight stitch. Is this something I can fix myself?
SOURCE: thread tension
I have had this problem when the bobbin was wound wrong and also when the machine was improperly threaded. Check your manual to make sure you hit all the threading points, but I think the most common one i've missed that caused this was the metal loop you thread immediately before threading the needle.
Posted on Nov 13, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 43 Answers
SOURCE: reverse stitching on a singer 514, HELP!
In the center of the stitch length knob (at the right side of the machine) is a button. You would push that button in to get the machine to reverse.
Posted on May 08, 2009
  • 1388 Answers
SOURCE: singer 237 stitches loose on bottom of fabric
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really .....actually .....need adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do is,
and eventually, you do get a "feel" for the correct tension and then it happens quite a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Posted on Sep 02, 2009
  • 1116 Answers
SOURCE: How do you thread a singer esteem model 1732
Posted on Mar 03, 2010
Got a Singer Esteem 1732 and the bobbin test shows it has no tension at all (which shows on the stitch)
normally loose bottom stitches indicate a problem with the needle thread tension not the bobbin. try removing top thread completely and then rethread machine with presser foot down, if you do it with foot raised auto tension will not function
Feb 16, 2014 | Sewing Machines
Singer 1732 esteem sewing machine
the tension dial may need to be replaced
Jan 26, 2014 | Sewing Machines
Singer 3116 tension problem
since the tension is the same no matter where the dial is set, the machine may need a new tension dial.
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number--(example 3116)
Click search
Mar 25, 2012 | Singer 3116 Simple
Singer industrial tacking machine model 269W8 Having tension problem because of the tension discs....threads get stuck in there no matter how I try to adjust it...and right now I am having that...
Maybe, you can try, rethread, now with the presser foot up, pull on the top thread, it should pull smoothly, then lower the presser foot, pull on the top thread again, it should barely move. This sometimes will seat the thread in the tension discs. Hope it works for you, otherwise you will have to have it serviced by a professional
Nov 23, 2010 | Singer Sewing Machines
My bottom stitch is "loose"
You might try adjusting your bobbin. You can do this with a tiny flat head screwdriver. Adjust in very small increments! There is a screw located on your bobbin case.
Here is the info directly from the manual:
"To test if the bobbin thread tension is correct, suspend the bobbin case by the thread and **** it once. Correct bobbin tension will result in the thread unwinding by only one or two inches. If too loose it will unwind continuously. If too tight, the thread will not unwind at all. When adjusting the tension on the bobbin case, make only slight adjustments with a screwdriver."
That is usually the cause of garbled up threads on the bottom side. Sure hope this helps!
(The 132Q is my third Singer, but will be my last. It's been a nightmare to deal with, and ALWAYS has something going wrong with it. I can never just sit down and do a project.... it is like the settings never stay put. There is also a LOT of plastic inside this model, and it cracks, breaks, warps, etc. We've replaced plastic gears/parts with metal parts, and it still acts up. Just a lemon model!)
Nov 05, 2010 | Singer Featherweight 132Q Mechanical...
Can't adjust the tension on old singer!
increase top thread tension slowly till u get similar stitches on both sides
Nov 03, 2009 | Singer Sewing Machines
Is there a way to attach the Singer esteem 1732 in a wood sewing machine cabinet
Horn cabinets will fit all machines but you need to find a sewing machine supplier to order one because they are very expensive
Oct 17, 2009 | Singer 132QRFB Mechanical Sewing Machine
I have a Singer Sewing Machine 5817C, the thread bunches under the fabric while sewing. I have tried adjusting all the switches so that I just get a standard straight stitch, but it bunches up on the...
Make sure that there is tension on the thread when you have passed it through the tension unit, by making sure the presser foot is down, and then gently pulling the thread to feel tension. If there is no tension, as seems to be the case, check the tension discs inside the unit to make sure that there is no debris stopping them from closing.
Oct 14, 2009 | Singer Sewing Machines
Amatur Sewer?threads tangled below
Stop sewing! You need to adjust your tension. Your book will explain exactly how to do this. If you can't find your book, try setting the tensions to the same number. If your tension adjustments have a mark at a certain number, use that setting for most materials. If not, try setting it to about 3.
To test your settings, thread your bobbin with a different color, then do a test stitch. Check the top and bottom stitches for a spot of the other color thread showing through. If the bobbin thread shows in the top, raise the bobbin tension setting a bit and try it again.
Hope this FixesYa!
Aug 11, 2008 | Singer 3116 Simple
Singer 7462 Mechanical Sewing Machine Logo
113 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
