Question about Maytag Washing Machines
Maytag Neptune washer (mah4000aww) turn timer nob but now water, makes some noise and atempt but doesnt work, replaced motor, motor contol, and timer. but still doesnt work is it likely to be main control board or other?
  • 79 Answers
SOURCE: Maytag Neptune washer model #MAH4000AWW,
Check out your motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new motor conversion kit which includes the motor, motor control board and the wire harness.
These kits are offered on the order form and they ship UPS Ground.
This kit takes about an hour to install.
Don't forget to see the info on the website regarding the defective door latch wax motor that will eventually fail and damage your machine control board.
Posted on Jul 15, 2008
  • 50 Answers
SOURCE: i have a maytag neptune washer the water will not drain out of it
Check for obstruction in pump located at back of machine. Remove back panel and pump will be located on left hand side.
Posted on Feb 23, 2009
SOURCE: Maytag Neptune MAH4000AWW will not drain all the water out.
The First comment here was absolutely right! Thanks! save a lot of $$$. In my case there was a piece of rubber that was keeping the propeler of the pump motor from spining, that's why the water won't drain.
Posted on Jun 07, 2009
SOURCE: maytag neptune MAH4000AWW Very loud noise
I found this on line ... 6/15/09 . Does your Maytag Neptune front loader sound like a runaway freight train when it is in high speed spin cycle? 2. Is your Neptune getting so loud that you cannot be in the same room while it is spinning your clothes? It sounds like your bearings may need some attention if you answered YES to the questions See ... Frank
Posted on Jun 15, 2009
  • 414 Answers
SOURCE: mah4000aww no door locked light
The lid/door safety switch needs replaced
Posted on Mar 08, 2010
MAH4000AWW Does not agitate or spin. Sometimes motor will turn very slowly and makes noise. No smell. Door locks. Water fills/drains. Circuit board ok. Belt ok.
this sounds like a motor & controler/ the 4000's used a DC motor and they changed it to a/c . the two parts come in a motor kit . and will solve the problem .. the part # is 12002039 . thanks and hope this helps **** and thanks for using fix ya .
Nov 07, 2011 | Maytag MAH6500 Neptune Front Loading...
Washer won't spin
You need to check this part of you machine:
Test the lid switch
Test the timer control
Test the centrifugal switch
Test the water level switch
Inspect the motor coupler
Inspect the drive belt(belt drive only)
Inspect under the washer for soot (clutch)
Test the motor
Inspect the pulley
Test the transmission
Check this parts this are the some cause to not spinning.
Dec 10, 2009 | Maytag Neptune Washer
Strange growling sounds on rinse and spin cycle
I would check the motor control board located near the floor on the right side for burnt components. The motor is a 3 phase unit and if one of the phases are working the motor will growl and won't be able to supply the proper torque.
See for disassembly photos and for more info on the faulty door latch wax motor.
Jan 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer Maytag Neptune
Most likely the motor control unit, the MCU controls the timer (loop circuit). Best way to check is to just pull the MCU out and visually inspect it for burned components, although it is not always visible. You may need to make some involved voltage readings to verify.
Sep 22, 2008 | Washing Machines
Jan 15, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Netune Mah4000AWW
Makes a loud humming noise. Does the machine go thru its cycles ? Is the humm ther all the time ?
Jan 06, 2008 | Maytag MAH6500 Neptune Front Loading...
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Maytag washer
Maybe you over-loaded, or you did not shut the door properly. Try reading the users' manual.
Mar 12, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag washer
It helps trying to actually weigh your dirty linen. Try to wash within what is mentioned in your manual. Also see that the door is closed firmly. Would be useful if you'd post back results.....
Open Questions:
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
