Question about Zenith TVBR0922Z 9 in. Combo
Tape won't play
Every so often the word "DEW" appears in the lower left hand corner of the screen and when this happens the VCR tape will not play; fast forward or rewind. Does anyone know what this DEW represents and how I can get it off? The past few times after a while it just disappeared after a while and then the tape works fine.
  • Zenith Master
  • 5,223 Answers
Moisture from the air has condensed into the VCR; the fact that it disappears after a while confirms it. You can check your manual. however my VCR's manual recommended leaving the unit plugged in and on for 2-3 hours until the unit dried itself out before trying to play a tape. I'd guess you are dealing with really humid air in your area. Air conditioning or a dehumidifier would reduce the humidity in the room with the VCR and prevent the issue in the future. (A dehumidifier will increase the room temperature, though.)
Posted on Jul 21, 2008
    Scholar:
  • 78 Answers
Hi hwgs,
The "DEW" warning appears if a VHS player or recorder has built up humidity. This, much like dew found on the grass on a cool morning, is the result of condensation building up, ususally after a temperature change. Once the moisture has evaporated the unit should work properly.
Be sure to keep your TV away from sources of humidity, such as a window or a bathroom/kitchen door. Also, make sure it is in a climate-controlled room away from drafts so the temperature does not change rapidly.
Thank you,
Jason,
Go Ahead. Use Us.
VHS tv says DEW lower left hand side, how can I fix this problem???
If the message comes out of your VHS tape recorder, means that humidity is present near the upper drum cylinder.That will stop the VCR from further actions because of danger to lock the tape on the head's surface.The proper actions are to blow inside hot air maybe from a hair dryer or remove cover and place the vcr on a sunny area for 30 minutes.If the error message continues then there;s nothing for you to do .Must take it to a nearest service because a faulty sensor or even a connector is displaced and needs a service person to act further on this.
Mar 02, 2015 | Video Cameras
Theres something on the vcr yhat says DWE OR DEW and theres a red light flashing beside it when thats flashing it wont allow the movie to play what does that mean
the DEW light is a warning light. it indicates moisture on the tape. so make sure the tape is dry and in a ventelated area.
Mar 08, 2011 | Audiovox AVP7280 VCR
We put a tape in vcr. we push record and the vcr ejects tape and shuts off.
Does the tape play normally? Does this happen with several tapes when you try to record? Check the record protect tab on the lower left hand side on the facing end of the tape. If this is broken or bent it will not record, you can put a piece of tape tightly across the tab as a repair
Oct 01, 2009 | Philips Televison & Video
Dew light is on vcr and will not play tape what can I do
take a hair dryer on low setting and try to blow warm air into the vcr to warm it up until light goes out
Jun 11, 2009 | Audiovox AVP7000 VCR
VHS Tape
Possibly the tape is wound too tight and is not actually playing when in play mode.
Also, tapes can be accidentally erased. If it is placed on a speaker or other magnetized surface it will erase itsself. The magnet draws something out of it.
I'm not sure exactly how it works but I know it happens.
Don't give up just yet. Check with your local video rental store... maybe they know a trick that will help you.
Good Luck :)
Jan 02, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Shuts down after 8 seconds of play.
Does the tape hang out when you eject the cassette?
8 seconds is about the time that the VCR brain allows the mechanism to run when there is a problem before shuting down. Just guessing from the model number, but I'd say the unit needs a belt job.
Dec 24, 2007 | Televison & Video
Code F13
It's sounds like the vcr's tape mechinisum is malfunctioning to me. Try unpluging it for a while. It will correct itself. Or it might have
dew sensors if the room is too cold the vcr wont work until the dew it gone off the heads. If it don't have dew sensors
and plays the tape with dew on it might eat the tape.
also if a timer is overlaping or is set to come on right now it might do this.
Nov 11, 2007 | Panasonic NV-HD680 VCR
Sansui TV/VCR 13" color
there is what is called a "dew sensor" in a lot of vcr's that keep you from playing a tape if it senses moisture in the unit because a tape will stick to the video head and get all bunged up. sometimes they go bad and will keep you from playing a tape even when there is no moisture present. if your are electronically inclined you can take the back off and locate the dew sensor, then disconnect it. the constant whirring noise is the unit's way of trying to dry off the video head cylinder. the dew sensor, which is usally located behind the video head, is a dark grey thing about a half inch by half inch and has two wires going to it.
Aug 03, 2007 | Sansui COM311AD 13 in. Combo
"DEW" is on screen and VCR not working
When the DEW appears leave tv on for several hrs at room temp. The heat from the picture tube will help remove the moisture.
Jun 30, 2007 | Sansui COM311AD 13 in. Combo
While playing back a recorded programme picture is lost and AV2 appears on the tv, sound can be heard on recorded programme playing back.The t.v screen goes black av2 appears in the left hand top corner,...
Does it do so on all tapes? It sounds like you are experiencing a tracking or tape path problem. You might try taking the top cover off, then cleaning the video head. Info is available on the 'net on how to do this. If problem remains, play a tape and see it is wandering up/down across video head. See if any of the tape guides are broken or bent, causing tape wandering. you may also have a problem in the electronics, perhaps in the servo circuitry, which has to do with careful control of tape speed, video head rotational speed, and certain other parameters. If electronics are bad, then VCR is likely a tosser, unless it is a high $ rig. Most electronics are disposable these days, unfortunately.
Mar 08, 2007 | Sony SLV-SE730 VHS VCR
Zenith TVBR0922Z 9 in. Combo Logo
149 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
