Question about Dell 5110cn Laser Printer
Toner smearing all over page
We are having a problem with our Del 5110 Magenta toner. It seems to be spreading all over the page. Not to the point that we can't see what's bein gprinted.... but it almost seems we need to clean the inside of the printer somewhere. We have no idea where to start. We purchased the printer from someone who had no problems with it at all. PLEASE HELP. Thanks!
  • jenny469 Sep 14, 2008
    We have horizontal magenta stripes across everything we print at the moment. Any ideas??
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 188 Answers
The problem with this printer is not the fuser. It is one of the following:
1) Imaging drum. The drum contains 4 imaging drums. One for each color. They are independent of one another on the initial image transfer and only combine after the initial image is developed. This IS a user replaceable consumable and should be tried first. If this does not resolve the problem see #2.
2) It is the magenta photo developer unit. This part is NOT a user replaceable part, and requires quite a bit of work to get to. The photo developer is located in the developer frame assembly, which can be seen behind the imaging drum when it is removed. The top cover, left side cover, HVPS, and all 4 toner feed tubes have to be removed in order to remove the photo developer frame, and after the frame is removed, the photo developer itself has to be removed from the frame and replaced. reverse disasembly to put back together.
Usually the tell tale sign for a leaking developer, other then full sheets of light color, is extream excess toner dust behind the imaging unit.
Posted on Oct 01, 2008
Get a new printer (hopefully a warranty replacement) is the only fix I have found. I have 10 of these printer. On average, at least 1 of them will develop this exact issue each month. Nothing ever fixes it. We have tried new drums, new fusers, and techs to come out and replace the developer unit. The replacement of the developer fixes it for a few days, but the problem comes back. There is something that causes it to go bad that Dell has not figured out yet.
Posted on Jun 11, 2009
Phlybnt
do you use Dell branded toners or have you been using a compatible toners? If you are using compatible toners can you tell me what brand they are?
Posted on Dec 22, 2009
Try a new fuser.
Posted on Aug 19, 2008
Replacing the transfer roller unit has fixed this in 5110cn printers for me. There is sensor in the printer that triggers an error when the transfer roller is full of toner and needs to be replaced. However, I believe this circuitry is often faulty or that the transfer rollers do not work correctly even though the sensor circuit thinks the transfer roller is ok (not full). Try the following diagnostic. If you get an H in the end, replace the transfer roller unit:
Replace Transfer Roller Diagnostic
  • Power off
  • Hold Up and Down arrow button while…
  • Power on
  • Customer Mode
  • Right arrow to
  • IOT Diag
  • Enter
  • Digital Input
  • Enter
  • Arrow up to
  • DI 23 off
  • Enter
  • DI 23 – L or DI 23 – H
  • H means Toner Full
Posted on Jul 09, 2009
Xerox phaser 6360 smearing magenta toner only
that's the developer assembly that has gone bad. If you're using 3rd party toner it wears down a lot quicker. You'll need to replace the magenta developer unit, part number is 848K03850.
http://www.iteminconline.com/848k03850_848k03850-xerox-6360-developer-assembly-magenta-oem-new-genuine.htm
Feb 09, 2016 | Xerox Office Equipment & Supplies
Why is magenta blotching on left side of printed page?
IT SOUNDS LIKE THE MAGENTA IMAGINE UNIT YOU MIGHT HAVE GOTTEN A BAD ONE.
Nov 05, 2015 | Samsung C460FW Multifunction Printer...
I have a Lexmark C522 Color Laser printer, all cartridges are showing as ok, no error messages but printed pages have specks of magenta toner on them
It sounds as though you have a leaking toner cartridge. If you aren't using Lexmark brand toner, that is VERY likely.. nobody seems to be able to make a good compatible cartridge. Test by replacing it.
Feb 22, 2014 | Lexmark C522n Laser Printer
HP CP2025 Heavy smears of magenta appear down the right-hand side of paper. Have tried restart and changing paper weight.
It is due to spilled magenta toner leaking from side to the toner cartridge. Take the cartridge out of the printer and clean it. Clean visible inside of the printer. Shake the cartridge lightly in horizontal position to evenly distribute the toner inside the cartridge and put it back. The issue sould be fixed after some prints.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 23, 2010 | HP Laserjet Cp2025n Printer
Smearing yellow toner on copies
Yellow is usually the least used color and it is usually near the fusing unit getting the heat. It seems to "dust" more than the others.I have found that yellow toner seems to build up under or around the yellow drum unit to the point that a passing page will contact the actual buildup near the yellow drum area. Take a visual inspection around the yellow drum area. Make sure you charge coronas are clean. Hope this helps.
May 07, 2009 | Canon Office Equipment & Supplies
Konica Minolta 2300W ink smears
check the transfer belt..there is a reason why some used printers are sold on ebay!
be prepared for sticker shot.
Apr 08, 2009 | Konica Minolta magicolor 2300DL Laser...
HP Color LaserJet 2600n toner problems
In speaking with other tech support people it appears my image drum needs to be replaced. Also sounds like it will be more economical to buy a new printer.
Feb 19, 2009 | HP Color LaserJet 2600n Printer
Pages full of toner / toner streaking
First off, this is a comment from a random person who may or may not know ALOT about these printers and toner/printer design in general. All toners are not designed to the same specification. Toner is a combination of plastic "pigment" and iron like shavings to make it magentically attracted to the electrical charges within the unit. Different toners conform to different grades and mainly size of the particles within the blend. The manufacturer doesnt only recommend that you use their toner to make them money, yes of course it makes money, but its because when the unit is designed it is designed to use a certain grade of toner, trust me if you put the non-branded toner vs the branded toner under a microscope you would see quite a difference. Often the non-branded toner is much larger in particle size (obviousely because its cheaper to make at this spec). This causes a variety of issues from excess toner not being cleaned off of developer rollers, IDT rollers, or clogging of toner dispenser tubes in the unit and the micro filters contained at the toner dispenser assy and developer assys. Also as for the issue not changing when switching to dell branded toner - the dispenser tubes within this unit contain up to 500-1000 pages worth of toner, making no change in toner you make immediately visible. Also depending on the damage caused by the previous toner, it may not be able to be fixed until all the components in between the toner and final delivery (drum cart) are replaced. In this case more than likely the toner dispenser assy, all developer assy's, and drum cartridge need to be replaced, and than be sure to stick with factory branded toner :)
Apr 26, 2008 | Dell 5110cn Laser Printer
Dell 5110cn Laser Printer Logo
1,986 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
