Question about Sony Playstation 3 (PS3) Console
PS3 sounds like its reading the disc but nothing appears
The TV says, check signal cable. We had a storm that messed up everything however the PS3 was turned off completely at the time, is it as simple as a cord?
  • 1 more comment
  • murphy5 Jul 22, 2008
    It was connected through an HDMI cable at the time. So i have tried hooking it up to 2 other tv's with the original av cords and it still didn't work so i'm not quite sure what to do next.
  • daverom2002 Mar 28, 2009
    Playstation turns on and it will take a disc, but I get no picture or sound.What could have happened?
  • antlob May 11, 2010
    How is your PS3 connected to the TV? Is the TV high definition?
    Problem Solver:
  • 4 Answers
Well if no TV recognizes your PS3, you will have to send in your TV for repair at Sony. If the PS3 was still plugged into the outlet then it could have been damaged by the storm.
Posted on Jul 22, 2008
  • 97 Answers
Try a new cord, ir maybe the storm fried the tv inputs.
My ps3 console will not read my games or movies and try a disc cleaner & nothing
The problem is not normally with the discs itself but with the lens coming away from where it needs to be.
You just need to readjust the lens that sounds difficult but really it is not too tough.
Check out this PS3 Repair blog and get the fix you need.
Nov 25, 2011 | Sony Playstation 3 (PS3) Console
I have an xbox 360, but i have a ps3 connect to the tv via hdmi. i swapped the hdmi cable to the xbox and powered on. i had all the cables in the correct position, the correct av selected on the tv, but...
Have you tried disconnecting the HDMI cable from both the TV and the console and then trying to reconnect?
Y+RT does not reset controllers for the Xbox 360, so not sure what you are attempting there?
What type of TV do you have? It appears the issue is with either your cable or the TV seeing that you are having the same issue with both your PS3 and Xbox 360.
I still think your first step should be to disconnect all cables from both ends and reconnect. (with poer off of all sytems of course) If this doesn't solve your issue then submit further information on your setup such as TV make and model and I can research other possibilities.
Jul 16, 2011 | Microsoft Xbox 360 Elite Console - Black
My ps3 wont read discs
your blue ray player is broken you have to send it back to sony if you have warrenty its free but if you dont its $150
Apr 01, 2010 | Sony Playstation 3 (PS3) Console
My sharp LC-19DV22U Will not connect to my PS3
well alex welcome to fixya technical support online.i just read your problems. there is an option to your problem you can use another cables with RCA inputs capable in your PS3 that can works on videos and also you can buy video converter. thanks!
Aug 14, 2009 | Sharp LC19DV22U 19 in. LCD Television
On a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Aug 11, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Powers on but nothing happens
It happened to me too. When you plug in your av cables and are ready to play, follow these steps. With your PS3 off (Red light on), Press and hold the power button on your console. (Do not use the controller to turn it on.) Keep holding the button until you hear a second beep. (it takes about 2 to 3 seconds.) You will notice your screen flickers, then your PS3 will show up on the tv. All you did was reset the PS3 display settings. You can always go back to HDMI or AV cables. Have Fun.
Mar 07, 2009 | Sony Playstation 3 (PS3) Console
No sound from hdmi cable
PS3 is The amazing device by sony but it has some common problems like sound but no video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
PS3 - tv says no signal
You need to change the resolution output on your PS3 to match the capabilities of your TV. If your TV is not HD you can't leave the PS3's video output on HD. SCART is for european television connections. Have you tried using component cables? Have you tried changing your tv's source to Video 1 or Component 1 or HDMI or anything that might work? Good luck!!
Sep 30, 2008 | Sony Playstation 3 (PS3) Console
PS3 DISC ERROR
I suggest to check the OPTICAL LENS on this game console ,and If recently purchased , its still on warranty , so you dont have nothing to lose , hope this helps AJ
May 02, 2008 | Sony Playstation 3 (PS3) Console
PS3 works on one TV but no pic/sound on Sony 100HZ. Tried soft reboot, messing with cables etc but nothing
try by pressing the button (on) from the ps3 when its turned off not the controller and hold it till it makes a sound after 5 sc i think. I had the same problem on 1 tv it worked and when i connected the ps3 to another tv nothing appeared
Dec 24, 2007 | Sony PlayStation® 3 (60 GB) Console
Sony Playstation 3 (PS3) Console Logo
65 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
