Question about Samsung AH5900092W Remote Control
Changing Samsung Remote Codes (2 TV's Same Remote Frequency)
I have a Samsung 50" Plasma downstairs and have just bought a Samsung37" LCD for upstairs.
Problem is I also have a remote extender in both rooms to control the PVR downstairs. Everytime I press the power button, channel numbers etc, it also switches the TV on downstairs and changes downstairs etc....
On my Panasonic DVD recorders which I have in each room I am able to change the remote code..... can this be done someway on either of the Samsung TV's???
  • 5 more comments
  • Anonymous Aug 25, 2008
    I have the same problem and i don´t know what to do.
  • stepppy Aug 27, 2008
    I phoned Samsung and they said it wasn't possible, but I thought some clever person may be able to sort it out :(
  • Anonymous Sep 09, 2008
    i also have same problem...samsung tv and sumsung pc/tv monitor in bedroom and both operate on same code! and i dont know how to change it....please help !
  • stepppy Sep 16, 2008
    Samsung say there is no way to change the remote codes, but I am sure I read somewhere that it is possible ???
  • cstewbaby Dec 16, 2008
    We have one LCD Samsung with remote, and we just bought another one that was a floor model, with no remote. The cheap universal remote we got does not handle anything beyond power, channels and volume, so we can't get the captioning to turn off. I thought for sure I could reprogram our existing Samsung remote, but can find no codes for TVs. However, you can buy a replacement remote, which would have to be programmed, so there must be some way to do it.
  • Anonymous Jan 18, 2009
    Same problem; samsung tv in the living room and husband has a samsung hd monitor on his computer just a few feet away.  The tv remote keeps messing with his monitor, so we can't use both at the same time since he's quite the gamer...argh
  • Capone1212 Feb 10, 2009
    I too have this problem. I have a Samsung 50" plasma in my lounge and a 42" Samsung plasma in my bedroom. Whenever I go to bed and switch off the tv it switches on the tv in the lounge as I have IR transmitter/receiver between the two room to control my PVR from the bedroom. The IR receiver in the lounge is not near the TV nor in direct line of the tv
    This is extreamly frustrating as I end up having to get up out of bed and switch off the lounge TV. I resort to the sleep timer to avoid it which helps a little.
    Scholar:
  • 102 Answers
There is NO solution to this problem. I'm an electronics engineer. I have three Samsung TV and IR remote extenders. It is a continual problem. If someone told you could "re-program" the Samsung remote, they must have thought you could write assembly level programming code. There is NO incentive for Samsung to modify their highly popular, simple, cheap remote system.
Believe me, I even tried putting polarizing filters over the IR sensors but the ones for cameras do not polarize light at IR frequencies.
Posted on Sep 20, 2009
I have 2 LG tvs next to each other, and I used pieces of transparent sheet of plastic with polarizer on the tv IR receiver AND the remote. if you just put the sheets on the receiver, it won't work. The trick here is that when both sheets are in the same space (both vertical or both horizontal) the signal will get through, if they are not (i.e. one vertical and the other horizontal) light (or IR wave) won't pass, ergo, it won't get to one of the devices. you have to put one of the tv polarizer sheets rotated 90 degrees (or one vertical and one horizontal), that way, when you tilt your remote (pointing the tv, but rotated 90 degrees), it will control one tv, and in normal position (pointing the tv and rotated 0 degrees) it will control the other TV. of course, this works if you have nothing between the remote and the tv; if you have a repeater, I don't know what will happen, but I think it won't work (except of course if you do the same thing of putting the plastic sheet in the repeater). You can find plastic sheets from cell phone screens, old calculators, clocks, etc. If this thing doesn't work, it means that your polarizer is not good, and you need to find another one. Hope I had helped a tiny bit :)
Posted on Mar 13, 2010
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 158 Answers
Google it
Posted on Sep 03, 2015
I have a Samsung TV iamuseing a ermsom remote need codes for this remote
Search Results
    Remote Control Codes
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    ... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...‎Guide to Programming the ... - ‎Download the Manual - ‎8 Device Learning Jumbo ...
    Remotes - Device Codes - HiFi Remote
    www.hifi-remote.com/codes-tv.shtml
    TYPE, BRAND, CODES ... TV, Emerson, 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, ... TV, Samsung, 0019, 0060, 0030, 0056, 0178, 0032.
Feb 05, 2016 | Samsung 50 in. Plasma TV
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
Virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Nov 18, 2011 | Samsung 50 in. Plasma TV
I need the remotev codes for samsung
i need your remote control model number.  or you can get your original remote control part from www.replacementremotes.com
Apr 17, 2009 | Samsung TV Remote Control
Sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Device code
some older cable remotes do not have the new lcd /plasm tv codes, you should consult with some one at the cable company and see if they have a box with remote that will support your tv.
May 27, 2008 | Samsung HP-T5064 50 in. Plasma HDTV
Samsung plasma tv
Samsung codes for sky reomte 0060 065, 584, 037, 245, 476, 398, 516, 292, 318,
037
Click here for the link
Jan 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Panasonic TV 50 inch plasma
Dear RyanVa21;
Try changing the picture size with your set's remote, press the aspect ratio button. The remote must be the original Panasonic remote.
Please let me know if that did it.
Thanks!
Richard
Nov 08, 2007 | Panasonic TH-50PX75U Plasma HDTV
Weird colors problem
i have a samsung LCD tv 32 inch tv. when switched on the pic is seen for about one sec then goes off. when i change channels the audio changes but the screen is blank. every time i switch off and on the same thing is repeated there is no display on the screen looks like a back screen light fail . can the problem be sorted out by changing the inverter or the whole LCD panel needs to be changed? pl be free to answer.
Aug 17, 2006 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung AH5900092W Remote Control Logo
16,171 people viewed this question
Henry  Thomas
Henry Thomas
