Question about Cuisinart DGB-600 Coffee Maker
Leaking coffeemaker Coffeemaker makes coffee but there will be a puddle of water under the unitwhen it is done brewing. If I put water in it and let it sit, there will be water under the unit, but less water than when it's making coffee.
  • marykay1 Jul 27, 2008
    I end up with coffee all over the counter and floor from where I have programmed the unit the night before. I don't know what I am doing wrong if anything??? Obviously, not the only one with this concern. I have not tried anything to resolve it yet just because I am afraid to go into the coffee maker and mess with anything. I downloaded manual but there is not any troubleshooting tips in it.
    Problem Solver:
  • 6 Answers
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Posted on Aug 12, 2008
My mr. coffeemaker beeps 5 times and doesn't brew the coffee I just purchased this coffee pot last month aug 2014. what could be the problem
I see two problems that you've described.
First, you have a bad empty-reservoir sensor. Mine went out on my first Mr. Coffee within the first month also. The purpose of the sensor is to trigger the beeping to simply let you know when the coffee is done. The coffeemaker would normally work fine otherwise.
Second, you have a bad heating element. This is the core function of your coffeemaker and renders it useless for anything but a nice warming plate.
I recommend replacing the coffeemaker.
In the future, make sure you do not add water to the reservoir unless the coffeemaker has been turned of for at least five minutes. This will help prolong the life of the heating element.
The heating element will naturally degrade over time. But, it can incur sudden damage when the reservoir is refilled with water too soon - while the element is still hot. Because of the simple design, if the coffeemaker is on, then both the warming plate's heating element and the reservoir's heating element are on. So, after a brewing cycle is complete, the reservoir's heating element stays on. Without any in the reservoir to keep it cool, the heating element superheats. So, if water is put in the reservoir while the coffeemaker is on or before the element has adequately cooled, the sudden burst of steam from the water contacting the element can be quite violent.
Sep 21, 2014 | Mr. Coffee Coffee Makers & Espresso...
Dcc-1200 coffeemaker self clean light blinks
There is no self clean button on mine, and I have done the above with vinegar and water......what next?
Nov 11, 2011 | Cuisinart DCC-1200 Coffee Maker
Cannot get the top cover removed so I can troubleshoot the electronics. All accessible screws removed. Seems to be some sort of catches where the side and top covers come together at the rear. Anybody done...
Decalcification
Decalcification refers to the removal of calcium
deposits which form over time on the metal
parts of the coffeemaker.
For best performance from your Brew Central
Thermal™ Coffeemaker, decalcify the base unit
from time to time. The frequency depends upon
the hardness of your tap water and how often
you use the coffeemaker. The flashing Clean
light will indicate when you should clean your
coffeemaker.
If the Clean light begins to flash when the
coffeemaker is turned on, it is telling you that
the calcium buildup is interfering with the
functioning of your coffeemaker and the flavor
of your coffee. To clean, fill the water reservoir to
capacity with a mixture of ¹⁄³ white vinegar and
²⁄³ water. Press the Clean button. When the self
clean light glows, turn the coffeemaker on by
pressing the on/off button. The Clean light will
shine steadily. The coffeemaker is now in Clean
mode. One cycle should be sufficient to
adequately clean the coffeemaker. When the
cycle is completed and the five beeps sound,
the coffeemaker will shut off. Turn the
coffeemaker ON to see if the Clean light
continues to flash. If it does, turn it to OFF and
then repeat the cleaning procedure with a fresh
solution of vinegar and water.
If the Clean light no longer flashes, turn the
coffeemaker to OFF and then run one cycle of
fresh cold water through the unit before using
the unit again to brew coffee.
Notes on the Clean F unction
Pressing the Clean button cancels all other
settings. If it is pressed accidentally, press it
again to return the coffeemaker to all its
previous settings. Pressing ON/OFF will also exit
the Clean Mode and turn the coffeemaker OF
Mar 21, 2011 | Cuisinart Keurig B50 Single Cup Coffee...
Coffee brewer works to the point wher you push the flashing brew button no water pumps through.
Hi
If your coffeemaker appears to be clogged. Create a vinegar and water solution and flush the concoction through your coffeemaker pump. This will help dissolve build up in your coffeemaker. If you do this once a month, your coffeemaker pump won't clog.Unplug the coffeemaker and inspect the pump valve. Water won't rise through the fill tube if the pump valve is stuck or broken. If your pump is sealed, replace the pump. If the pump valve is accessible, make sure there are no coffee grounds or mineral deposits around it.
Also check the brewing switch is in good working order. Remove the base plate on your coffeemaker and test the switch with a volt-ohm meter. Set your volt-ohm meter on the RX1 scale. If your switch reads zero ohms, your switch works fine. If it reads anything other than zero, replace the switch. Also take a look at the tube connectors, if your coffeemaker is sputtering, leaking or steaming. Leaks in pump coffeemakers are often due to faulty tube connectors. Unplug the coffeemaker and fill the reservoir with water. If water leaks from an elbow, clean the mating surfaces before replacing it. If your water leaks from a tube connector, replace the tube and mating elbow to ensure a good fit.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 07, 2011 | Breville BKC600XL Coffee Maker
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
The ''clean'' light is on my cusinart coffee maker
Let a half caraffe worth of distilled white vinegar sit in the water reservoir for about an hour. After the hour, turn the coffeemaker on and let it brew the vinegar until a small amount of vinegar appears in the caraffe. turn the coffeemaker off and let it sit for an additional 20 minutes. Then turn the coffeemaker back on and let it brew the rest of the vinegar. Then run a full caraffe of plain water to flush the vinegar out. If the self-clean light remians on - unplug the coffeemaker for 20 minutes or longer - if you unplug it for any less than 15 minutes, the coffeemaker will not reset itself. You should be good after that - as long as you do some sort of vinegar/water cleaning once a month henceforth.
-Tha Mp3 Doctor
Mar 13, 2009 | Cuisinart Coffeemakers
Coffeemaker does not brew
I put vinegar and water in and it was fixed.
Sep 07, 2008 | Black & Decker (050876530606)
DGB-600 grind & brew thermal coffeemaker
Jul 21, 2008 | Cuisinart DGB-600 Coffee Maker
Kenmore Elite coffeemaker - excess steam
Fold a large piece of foil into quarters. Place foil over reservoir and firmly close lid. Open lid and massage edge of foil inside and out with finger to get a kind of cap. Remove foil and trim neatly around outer edge of lip. Fill reservoir with water, place cap on top and close lid. Make coffee.
Mar 02, 2008 | Coffee Makers & Espresso Machines
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Nov 23, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Cuisinart DGB-600 Coffee Maker Logo
324 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Greg Cann
Greg Cann
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
