Question about Sharp UX 465L Plain Paper Thermal transfer Fax
Changing the date
I need to know how to change the date of the fax
  • 163 Answers
Here is the manual from Sharp, page 22 has what you need.
http://www.sharpusa.com/files/fax_man_ux465l.pdf
MM85
Posted on Jul 21, 2008
How to change th date in Tally 7.2 educational single user?
in tally 7.2 version there is no changing date.please advice me in detail and clearly
Jun 10, 2009 | Microsoft Computers & Internet
Changing date and time for panafax uf6000
press function-7-1-start- change the time and date on the machine. then hit start then stop
Jan 12, 2009 | Panasonic PANAFAX UF-6000 Fax
Changing date on Minolta 2800 Fax
You might try www.minolta.com to download a user manual. Otherwise you will have to scroll through the menus for SETUP
Oct 20, 2008 | Minolta MF1600E Plain Paper Laser Fax
Changing The Date
I got the time changed, I kept pushing buttons and apparently got the right one.
Aug 31, 2008 | Brother FAX-575 Plain Paper Thermal
Changing the time
lift the speed dail flaps. touch the data registration key
when the display say user setting touch set key first one
option should be date& time if not scroll to it
when date and time is displayed touch set. then enter
date and time using number key pad then touch set.
finally touch stop.
TRM
Jun 04, 2008 | Canon LaserClass 9000L Plain Paper Fax
I Have a Cannon, Laser Class 710, Super G3 Fax Machine and need to know the procedures to reset the time and date. Can't find my manual.
lift up the 3 speed dial panels
use Data registration key
select date/time settings
use the 4 direction arrows to navigate thru menus
and after changing info use set key to lock in setting
let me know if ya need more help
these are great faxes
May 23, 2008 | Canon Office Equipment & Supplies
Changing Date/Time on fax Machine
Press teh MENU button. Go to INITIAL SETUP. Then to DATE AND TIME
Nov 29, 2007 | Brother IntelliFAX 2800 Laser Fax
Canon pixma mp530 all-in-one printer set up
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Solution: Changing the TX report MP530
Change the TX Report 1. Press the <Menu> button to display [FAX SETTINGS].
2. Use the [ left.gif] or [ right.gif ] to select [TX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif ] to select [TX REPORT] then press <OK>.
4. Use the [ left.gif] or [ right.gif ] to select [PRINT ERROR ONLY] or [PRINT FOR EACH RX] then press <OK>.
5. Use the [ left.gif] or [ right.gif ] to select [YES] or [NO] for [ATTACH TX IMAGE:] then press <OK>.
6. Press <Stop/Reset>.
Changing the Paper Size, Type and Source
Changing the Paper Source
Before printing, confirm that the location where you have loaded paper is selected as a paper source. Press <Feed Switch> to change the paper source.
(A) Auto Sheet Feeder Lamp
(B) <Feed Switch>
(C) Cassette Lamp
Note: Press <Feed Switch> so that the Auto Sheet Feeder Lamp lights when loading paper in the
Auto Sheet Feeder and the Cassette Lamp lights when loading paper in the Cassette.
You can also select the paper source with the printer driver when printing from the
computer.
Changing the Page Size and Media Type
Note: The asterisk <* > on the LCD indicates the current setting.
1 . Press <Paper>.
When you do not need to change the page size, press <OK> to proceed to step 4.
2 . Use leftright.gif to select the page size: A4 / B5 / A5 / 4x6 / 5x7 / C-CARD / 8.5x11 / 8.5x14
sizetypelcd.gif 3 . Press <OK>.
4 . Use leftright.gif to select the media type: PLAIN / PHOTO PRO / PHOTO PLUS / MATT PHOTO / GLOSSY
Note: In order to obtain optimal quality print results, when copying photographs, use Canon-recommended Photo Paper Pro or Photo Paper Plus Glossy.
5 . Press <OK>.
Entering the Date and Time Note: When your machine is connected to a computer with the MP driver installed, even if the date and time are entered from the Operation Panel of the machine, the date and time will be read from your computer every time you start the computer, turn the machine on, or disconnect and connect the USB cable. When using your machine connecting to your computer, set the date and time on your computer precisely.
The date and time will be reset when you disconnect the power cord or there is a power failure. In this case, you can set it again on the machine. Alternatively, it can be read from your computer and set on the machine by connecting the machine to your computer with the MP driver installed.
1. Press [FAX], then press [Menu].
2. Use [ left.gif] or [ right.gif] to select <USER SETTINGS>.
3. Press [OK] two times.
datetimeset.gif 4. Use the numeric buttons to enter the date and time (in 24-hour format). Enter only the last two digits of the year.
Note: If you misentered the date and time, use [ left.gif] or [ right.gif] to move the cursor under the number to enter the correct number. Three formats of date are available.
5. Press [OK].
6. Press [Stop/Reset].
I hope it helps!!!
Nov 25, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Sharp UX 465L Plain Paper Thermal transfer Fax Logo
65 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
