Question about Audio Technica ATW-T52 Professional Microphone
Vocals disappear in parts using this mic
When singing into my ATW-T52 wireless mic, it leaves gaps or blank spaces in the transmission. I have 2 of these mics and receivers and both have the same problem. I have used this model mic before and it worked well. I do not have a user manual how do I solve this?
It is very common to have the squelch on the receiver set at full or much too high. With the audio output unplugged or at least turned all the way down, and with the transmitter turned off, locate the squelch control - you may need a screwdriver depending on which model of receiver you have. Turn the squelch control counter-clockwise until the TX light turns on, then turn it back up just past the point where it turns back off.
If you turn it all the way down and the TX light doesn't come on, that's okay. If you get blasts of noise occasionally when the transmitter is turned off, then set the squelch a little (only a little) higher until it stops.
Joe
Posted on Jul 23, 2008
How can I get a professional sound out of my vocals; what I'm trying to say is how do I edit my vocals to get that studio effect or what ever, like all of that panning and equalizing business and so...
first, you need a hugh quality studio mic or a seinheiser, sure sm 58s and cheaper mics sould muffled compared to real studio mics.
whatever mic you have, the key to the studio sound os overtracking. record your vocals, singing exactly the same, 2 times, and pan 1 take to the right, and another to the left. this will give it as chorus effect.
then, use an eq to drop everything below 500 hertz about 20 decibels or so, thios will make it cut above the pusic and sound clearer.
after this, you can add effects such as delay, reverb and maybe chorus, but too much effects will muddy the sound.
Dec 01, 2010 | Electronics - Others
I have a atw-t52 audio techina wireless mic. And when i turn it on thr crackling begins to come through the speakers and i have to play with the input and output cable and move the base unit around and...
I have the same problem in my ATW T52, in st by its ok (the rf leds show perfect signal) but when i set in on the af level start punch and i hear in the monitor a noise like a heartbeat (pum-pum-pum....) Please any answer for this problem
German
Radio del Sol 96.3 Mhz
Villa de Merlo - San Luis
Argentina
May 20, 2010 | Audio Technica ATW-T52 Professional...
I have problem with channel on Audio Technica wireless microfon How can I change the channel because the same things wireless channel digital television and she considers the work of the microphone. Type...
I don't think is possible. But its entirely my point of view,as i feel technically its not possible.
Try checking your user manual provided for microphone. That may offer you better guidance.
Oct 10, 2017 | Audio Technica ATW-R14 DIVERSITY RECEIVER...
ATW-T52, hissing/crackling.
A common problem that SOME have is due to the foam windscreen inside the metal screen rubbing the diaphram of the mic.
Unscfew the dome screen and make sure the foam is out agaist the scree everywhere.
If the dome has become dented, this is my cure: Temporarily remove the foam sheet inside the dome. Put the dome over the handle of a Crescent wrench (has about the right contour). Pound on the screen with a RUBBER mallet, rotating the screen as it reforms! Good as new! Replace the foam sheet and reassemble!
Dec 20, 2009 | Audio Technica ATW-T52 Professional...
How do I program the frequency of transmission on the mic?
Some of these have a body cover that just unscrews off, and expose a set of rotary channel and group selector that you can turn with a small flat screw driver. Match to the new numbers letters on the receiver. If it is the LED type you just need to hold the ch or grp button down until the display flashes then just toggle through the codes.
Jul 27, 2009 | Audio Technica ATW-T52 Professional...
Change the frequency
hello firstable you need to know at how many ohms is the base unit then in microphone change the impedance transformer to match the low or high frecuency you want......saludos
Nov 20, 2008 | Audio Technica ATW-T52 Microphone
HELP
Audio Technica Part number 235401550, call 330-686-2600. The cost is $21.93, plus shipping
Jul 29, 2008 | Audio Technica ATW-T52 Professional...
Microphone
It really depends on where you will be using the microphone and and whether it is just going to be used for fun at home or in a club oor for recording?
Some golden rules for microphone selection.
1) Make sure the microphone is Uni-Directional. This means it will only pick up sound from the direction it points in. You are less likely to get feedback or background intereference.
2) For a vocalist, make sure the mic is a reasonable size. If it is too small and you need to hold it, after a while it becomes fiddly and uncomfortable.
3) When singing always use a foam hood or pop filter with the microphone. This will reduce explosive sounds on the letter "P" etc.
4) Choose a microphone with a wide frequency response but not too much bass which can make vocals sound boomy.
5) Finally, the microphone must have a reasonable dynamic range so that if you suddenly shout it does not distort excessively, but it will also work when you speak or sing softly.
Feb 29, 2008 | Audio Technica Audio-Technica ATW-T341...
Vocal problem
hi there..if there is video and background audio coming out from the TV, and no voice recognition from the mic- then mic is the problem. I believed the problem is the "voice coil". This is a part that can be replaced- you can contact me and we can repair that.
two ways to check
remove the mic ball
the part which the mic ball is is covering is the voice coil.
try holding both terminals (black and white wire)- if there is feedback sound- it is open and need to be replaced
try using your tester- test the impedance- there should be 500- 600 ohms reading
(sean.delcarmen@magicmic.com or customerservice @magicmic.com)
Dec 18, 2006 | Magic Sing Along Consumer Microphone
Audio Technica ATW-T52 Professional Microphone Logo
360 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
