Question about Malber WD1000 Front Load Washer/Dryer
Malber WD 1000 dryer help...
I just moved into a place with a Malber WD 1000 and read your instructions post and found it very helpful.  I wanted to thank you and ask one additional question....
Once may machine is done with the spin cycle and it goes onto the dry cycle (timer is set and operation light is on) the drum no longer spins.  Is this normal, or should I be concerned?
Thanks Again,
Jack
  • 487 Answers
Jack it should start turning after a while as soon as the dryer has warmed up.
Does it dry however?
Posted on Jul 23, 2008
Broke the door handle on malber wd 1000? Do they sell the handle or door?
Sorry to see this 16 months too late.
You can find Malber Distribution Corp online, or call them at 516-323-5299. Tell them Mike, in DC, says hi.
Oct 30, 2012 | Malber WD1000 Front Load Washer/Dryer
Where to get parts of malber wd 1000 washing machine
The Malber service center number in NYC is 718-767-7396. Try calling them to find out where you can get parts. Hope this helps
Jul 17, 2011 | Malber WD1000 Front Load Washer/Dryer
Hi, 1) I need a new Capacitor for my Malber WD 1000 washing machine. Can I order that from you ? How much is it ? 2) The dryer is not working - is there a way for me to troubleshoot to find out what...
hi there you say you need a new capacitor i would assume your motor is not operating .you should be able to get a new capacitor from any elec strore the size is stamped on the side ie 8uf 10 uf etc hope this helps
Jun 07, 2011 | Malber WD1000 Front Load Washer/Dryer
Burned out wd 1000 motor, is there a cheap fix? Don't want to move and don't want to spend for new.
it is impossible to fix it because you said that is already burn out and for its only two things
1. is to buy a new motor
2. is to rewind the motor. this is the cheaper.
Mar 07, 2011 | Malber WD1000 Front Load Washer/Dryer
BELT REPLACEMENT
718 767 7396 or 718 747 3835
Apr 22, 2009 | Malber WD1000 Front Load Washer/Dryer
Malber WD 1000 takes four plus hours to dry one load
i would check the thermostat and heating element. one or the other is not on enouph to dry your clothes.
Aug 14, 2008 | Malber WD1000 Front Load Washer/Dryer
Dry cycle
Try setting the washer dial to the stop setting at the end of setting number 4 then set the dryer timer and turn on the machine.  This works for mine to get the dryer to run by itself.  It should begin about 30 seconds later, when the door locks.  Hope this helps.
May 13, 2008 | Malber WD1000 Front Load Washer/Dryer
Dryer doesn't dry clothes, doesn't start right after Wash
If the machine is brand new, I imagine all you want to do is check you're using the machine correctly before you claim on the warranty. Trouble is, the design of this machine is so weird, and the instructions so poor that it's easy to get it wrong. So far as I can make out from this distance, you need to have all of: Spin Cancel: Out Half Load: In Cold/Cold: In Hot/Cold: Out Cold water supply: Available Drain Hose: Connected .... and as with most condensing dryers, you need to let it run to the end of its cycle - if you take stuff out without running the final 12 minute cooldown period, everything will come out feeling a bit clammy. If those control settings don't help, try a functional faultfinding approach. To dry properly, the machine needs to do four things at once: 1. Tumble the clothes: You can see whether this is happening or not. From your description, it sounds like this is working. If this isn't right, see if changing control settings works, but then for a new machine make a warranty call. 2. Blow hot air over the clothes: You should be able to hear the fan running, and if you open the door, the air which comes out should be quite warm. If this isn't right, see if changing control settings works, but then for a new machine make a warranty call. 3. Condense the moisture out of the circulating air: If this isn't happening, the clothes don't get any dryer - they just get increasingly hot. Before making a warranty claim, all you need to do with this problem is ensure that the supplies and settings are such that cold water (and only cold water) is getting to the condenser. 4. Pump out the condensate: If you've just washed successfully, this is probably going to be working fine. If not, then you'll start to see the drum slowly filling with water. If this happens, check the filter (p12 of the manual), then get the warranty claim going. Welcome follow-on questions or news on how you get on posted as a comment to this query. A.
Jun 27, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
345 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
