Question about Compaq Evo N610C Notebook
Screen Size My fiance mistakenly pressed a button on my laptop but doesn't know what she pressed. So now I have a very small screen. How do I get it back to its full size?
  • 1 more comment
  • musicmaker_1 Jul 21, 2008
    Media Man, the entire screen is reduced to the middle of my laptop screen. So whatever is on the screen is not the full size of my laptop screen, everything just sits in the dead middle even when I attempt to resize it to "full".
    Dilipbagdi, niether of those solutions worked.
  • John Byse
    John Byse May 11, 2010
    Is the display size itself smaller or does everything on the screen smaller (full screen)?
    President:
  • 1,257 Answers
Just press the three keys together..
control key + alt key + up arrow key...
Hope this works if i am right.
2nd solution
Right click anywhere on desktop and click properties >select setting tab > now under screen resolution lower the size to increase the resolution or the screen > select apply > ok..that's it.
Posted on Jul 21, 2008
  • Deeps . Jul 22, 2008
    Switch off the notebook,start it again and keep pressing f8 key which will take you to this screen,(please open this link to know more ),http://mysite.wanadoo-members.co.uk/powe...
    when you come to this screen select the option "Enable vga mode.",now just login and set the resolution by Right click anywhere on desktop and click properties >select setting
    if this solution fix the issue its good ,if not restart your computer and keep pressing f8 key untill you come to the screen http://mysite.wanadoo-members.co.uk/powe...
    now here select the option "Last known good configuration(your most recent setttings that worked.)"
    if still you face the problem then you can apply for our Fixya live session.
    Regard
    Dilip
Image size fit screen
Try pressing your "zoom" button on the remote. If that doesn't work, try pressing the video button to see if that changes your picture as well. One or the other should solve your problem.
Jul 15, 2014 | Insignia Televison & Video
Change screen font and size
This amazingly easy trick will instantly enlarge hard to see text on your screen!
Should you ever want to decrease the text, this trick in reverse will minimize text as well!
Spending lots of time online can cause eyestrain, especially if you encounter very small text. Don't squint or hunch over your screen! Squinting causes wrinkles!
Using these tips you can read screen text comfortably!
With the press of two keys, you can enlarge the screen text without going into your settings.
Simply press and hold down the "control" key, while pressing the "plus sign" key.
Be sure to keep the "control key" depressed while you press the "plus sign" key.
Each repetition will enlarge the text.
This can make reading small text SO much easier!
To return the text back to its original size (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key.
Each repetition will decrease the text size.
also
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
and text sizes largest to smallest
Apr 23, 2013 | Compaq Presario CQ56-115DX Laptop
Can anyone identify this PC Wallpaper
that's probably that your wallpaper isn't fit with your monitor resolution,for example,if your wallpaper size is 1280x1024 but your screen resolution (size) is 1024x768,it doesn't fit your screen and the wallpaper will only show half or even less
to check your current resolution,click
Start->Control Panel->click Appearance and Personalization->Click "adjust screen resolution" on the Display categories
you can see your current resolution and also you can set your resolution
To check the picture resolution,right click on the picture,select properties,click the Summary tab,and it doesn't show the resolution, click Advanced on the Summary tab
But I suggest you to download the wallpaper with a fit size instead of changing the screen resolution,because too high resolution will make your screen goes black
geez,i'm so sorry for my poor english
please rate this solution if it's work and let me know if you still has a problem.and thanks for using Fixya!
Aug 28, 2012 | Toshiba Computers & Internet
I have deii inspiron pc. I need to adjust screen size so that it can be much bigger. what should i do!?
Right-click on a blank section of the screen and select Properties from the fly-out menu. Then click the settings tab and reset the screen size. If the screen size seems normal, then click the Appearance tab and reset the font size.
If the menu is too small to be readable, hold down the Ctrl key and repeatedly press the + button. This will change the screen magnification and you will then be able to scroll to the text you are trying to read to reset things.
PCHELPSTER007 from youtube
Jun 25, 2011 | Computers & Internet
My sreen resolution and font size is large i can't go back to the smallest size i tried going to my desktop properties but it still shows that the fonts and the screen resolution are in their smallest...
Not knowing the make & model of your laptop can only suggest you try to do a system restore. Assuming laptop is running Windows XP, do the following...
1. on the bottom left of the desktop, click on the start button
2. on the start window, hover cursor over All Programs
3. on the All Programs window, hover cursor over Accessories
4. on the Accessories window, hover cursor over System Tools
5. on the System Tools window, click on System Restore
6. on the System Restore window, click radio button to set to Restore my computer to an earlier time
7. then click on the Next button at the bottom of the System Restore window
8. on the Select a Restore Point window, click on a bold date prior to your mistaken uninstall date
9. with the bold date for the Restore Point selected, click on the Next button at the window's bottom
10. on the Confirm Restore Point Selection window, confirm your date by clicking the Next button.
Apr 28, 2011 | Computers & Internet
Full screen
Press the F11 button to get full screen.
To return back to normal screen, press the F11 button again.
You can also hold down the CTRL key on the keyboard and Scroll down the scrolling button on the mouse.
To revert to normal , again hold the CTRL button on the keyboard and scroll upwards.
Cheer
Uttam
Jul 12, 2010 | Advent Netbook
Text size on screen too small
Have you tried this? In Internet Explorer, use View > Text Size to alter. Also, if you use a scroll mouse, it is possible for that to adjust your size (by holding down the Ctrl button while scrolling up or down).
Jan 04, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Desktop Screen Size
MOst LCD monitor needs a specific screen resolution to fill up the entire monitor, usually 1024 by 768 pixels and higher. Go to the display properties of your computer, under settings tab to change it. (Right click anywhere on your desktop and select properties.)
Jul 22, 2008 | Compaq Evo N610C Notebook
I broke my acer laptop screen. I want to run it off a pc screen but it keeps switching off the pc screen
you need to enable the 2nd screen from bios setup or the press the screen button combination witch is FN (function) and one of the F1-12 keys, It varies between laptops. Press the one with VGA or a small picture of a screen on it.
If you need more assistance let me know, I'm here to help
Apr 14, 2008 | Computers & Internet
Compaq Evo N610C Notebook Logo
138 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
