Olympus Camedia D-510 Zoom Digital Camera Logo
Posted on Jul 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camedia download My computer crashed and i need to download the camedia software. I dont have the disk Some how I have difficulties to down load the 2.5 version
Anonymous
Level 3:
President:
  • Master 919 Answers
  • Posted on Dec 17, 2008
Anonymous
Master
Level 3:
President:
Answers
919
Questions
0
Helped
348037
Points
2397
To learn about the new and free version of Olympus Master 2 software go to: http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp Click on 'Free Download' to register your email address to receive an email containing a link to download either the Windows or Mac version. This software replaces all previous versions of Camedia Master, Olympus Master 1.x and is XP and Vista compatible.
2answers
Camedia master 4.2 does not work with windows 7 is there a solution?
try going to the camera manufacturer web site , find the download for your model and select the win 7 os
down load and run from the web page
win cp and win 7 are no longer supported by Microsoft so there is every possibility that the driver on the win 7 os is not operating
My computer crashed and lost all pictures. I have a olympus camedia d-540 zoom camera. I need a disk to download. where can I get
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
2answers
How do I download photos from my Olympus Camedia
either get a card reader to hook up to your usb on your computer this is easiest and dont have to download a driver for your camera if you dont have a disk. Or just get a usb for your camera and download them.
My pc can't find my C765 camedia zoom camera
That depends - what operating system is running on your computer? If you are running Vista it is because Camedia Master is not compatible with that operating system.
To learn about the new and free version of Olympus Master 2 software go to: http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp Click on 'Free Download' to register your email address to receive an email containing a link to download either the Windows or Mac version. This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x and is XP and Vista compatible.
Camedia software for D-520Zoom
Windows compatibility with Olympus digital products is supplied below by model. This information will be updated as additional testing is
completed.
Windows Compatibility For Camedia Master Software Versions
Software Version Remarks
Camedia Master 4.3 Windows 98, 98SE, 2000, ME, and XP are fully supported with Camedia Master 4.3
Camedia Master 4.2 Windows 98, 98SE, 2000, ME, and XP are fully supported with Camedia Master 4.2
Camedia Master 4.1 Windows 98, 2000, ME, and XP are fully supported with Camedia Master 4.1
Camedia Master 4.0 Windows 98, 2000, ME, and XP are fully supported with Camedia Master 4.0.
Camedia Master 2.5
In order to use the drag and drop functionality in Windows XP you will need to download and install the Camedia Master 2.51 patch
for Windows XP compatibility located at http://www.olympusamerica.com/files/cm251_update.exe This patch will not work on any
other operating system.
Camedia Master 2.0
While you can download images using Camedia Master 2.0, you may experience incompatibilities when using the drag and drop
feature in Windows 98, 2000, ME, and XP.
Digital Vision 3.0 The Digital Vision 3.0 software is functio nal but not officially supported with Windows 98, 2000, ME, and XP.
Also, here is a link for the Camedia Master software updates
It is for Camedia Master 2.x or 4.x
Also, on the page you can download the new Olympus Master 2.0 software.
http://www.olympusamerica.com/cpg_section/cpg_downloads.asp?special=11
Hope this was helpful.
Please rate this advice. Thanks so much!
Mar 27, 2008 • Cameras
8helpful
7answers
Camedia 4.1 installation error
I have the answer!
I had same problema nd found solution on another board.
It is a quicktime error.
Download new quicktime software from here;
http://www.apple.com/quicktime/download/
Then camedia will load/install.
Cheers
Albert Teacake
I am trying to install the Camedia Master software into a new pc, but when the disk gets to 90% loaded it freezes.
A CRC error (Cyclic Redundancy Check) is a data corruption error. This basically means that the data read from the media did not match what was expected to be read by the software. I would say that it is most likely that the source media that you are copying/reading from is corrupted. It is also possible that the destination media that you are copying to could be the source of the problem. If it is a hard drive try running scan disk or other disk repair software, if it is a CD - clean or replace the CD. David Millier Advance Camera Repair
Camedia software to see my camera via the USB port.
I'm assuming a Windows Machine (98 or 2000), and that you have (known to be) working USB ports. Boot your computer. Plug the computer end of the USB cable directly into the computer USB port (not a hub). Turn off the camera. Plug the camera end of the USB cable into the 3000. Then turn on the 3000. Windows should recognize new hardware. When Windows asks about drivers for the new hardware, direct it to your Camedia CD. Probably directory \USB\Win98 (or 2000) or something similar. Windows should then load the driver automatically. I *don't* think the 3000 will show up as a Drive device in My Computer. I think only the 2040/3040/E10 models will. But, Camedia should see it now. Toward the left-hand side (center) of the Camedia screen you should see a camera icon. Click it and it should open directories, drill down till your pix appear as thumbnail images. If Camedia says it can't find the camera, select Edit/Options/Download from the Camedia menu and ensure that USB is the selected choice.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
