Question about Nintendo DS Lite Console
White line on touch screen
When I turn on my DS A white line appears through the touch screen????
  • 103 Answers
A white line cannot be the Touchscreen. It must be the LCD screen under it. Could be a defective screen.
Posted on Jul 22, 2008
Dots appear on the touch screen
hi lea, does this dots and lines appears occasionally or it just stays there? because if its permanently there, then you might need to replace the lcd part of the lower screen (not the touch screen part) but if its occasionally, then try to see if it happens when your on the lowest brightness or highest brightness, if it is then you will have to adjust the variable resistor on the motherboard of the DS,let me know if you have to do this.
Dec 20, 2011 | Nintendo DS Lite Console
When i turn my ds on it goes to the action replay before anything pops up it turns white even before datel shows up
    1. Remove all games from the Nintendo DS.
    2. Turn the system on by pressing up on the POWER switch.
    3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
    4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen.
    5. Tap the Options icon.
    6. Tap the Start-up Mode icon.
    7. Tap the top box for "M Manual Mode" and tap the "Confirm" rectangle.
    8. Wait for the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Mar 25, 2011 | Datel Action Replay for Nintendo DS
Just received a used ds lite from ebay. when I type on the screen it enters the letter next to the one I touched. Is this a serious problem? Never used a DS before; will this have an impact on game...
Sounds like you should try recaliberating the touch screen. Calibration must be done with a stylus. Please note: Using a unlicsensed screen protector can lower the sensitivity of the screen, making calibration difficult. If the problem you are encountering started happening after installing a screen protector, this may be the cause of the problem. Remove all games from the Nintendo DS. Turn the system on by pressing the POWER button. Press the A Button when the "Touch the Touch Screen to continue" message appears. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button. should look like this :
icon_settings.gif Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button. should look like this:
    icon_calibrate.gif Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves. You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start If the touch screen is not responding properly, hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner. Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings. hope this helps
Dec 02, 2010 | Nintendo DS Lite White Console
Potentially dead Nintendo DS lite LCD screen. (bottom)
Hey, I can help you.
Yes, the Bottom LCD is dead. You will have to exchange it.
Below I have two links you should follow through. One to purchase a bottom LCD for a very cheap price and the other will show you how to replace the bottom LCD.
REMEMBER.. To place a plastic pad under the bottom lcd so it doesn't ground out the board. Forgetting to do this could potentially blow a fuse and you will have to replace those!!
1.) http://www.amazon.com/dp/B000RWXCE2?tag=wit08-20&camp=14573&creative=327641&linkCode=as1&creativeASIN=B000RWXCE2&adid=0JJ799NSS5VV0XTY8DYK&
2.) http://www.instructables.com/id/S3ZZJPKFA0CVIFO/
May 27, 2009 | Nintendo DS Lite
Problem with the touch screen on my ds
clean off th game and the gae slot and retr
Dec 25, 2008 | Nintendo DS Lite Console
Lines on Touch screen
I know if you use a DS stylus on a DS lite it will mess up the touch screan i dont know what DS you have though and your not suppose to touch the top screan with the stylus. Try reading the DS manual I don't know what to do...
Nov 16, 2008 | Nintendo DS Console
Nintendo ds NEED HELP
My DS touch screen is very light. If you turn look at a particular angle you can still see what is shown on the screen, but other than that, the screen looks white. I have already changed the touch pad and that was not the problem. Any assistance would be appreciated.
Thanks
Feb 04, 2008 | Nintendo DS Console
Lines on the non-touch screen
The connection to the lower screen is probably a bit broken. If you feel up to it you could take your DS apart using a tri winged screwdriver (can be bought from www.whitedog.co.uk/catalog/nintendo-wing...) and check the connections or you could just send it in for repair.
Oct 27, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
514 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
