Question about Denon Audio Players & Recorders
Denon 2500 and Denon 6000 and both trays aren't working (reading) I need to get them fixed. Where? Can you guys fix it? Henrik Strater
  • 4,234 Answers
First of all, we are not a service center but a resource to assist and guide you to a solution. We can not recommend a specific service center, but without knowing your location, we can not even suggest much of anything. You can try searching the DENON website for an authorized service center, or you can use look for a local servicer.
Typically, these units fail because the tray belts start slipping if they won't load or if the discs aren't recognized, the optics are either dirty or failing. These often use Sony optics assemblies that are readily available. Is the problem that the discs are not read? If so, try opening up the unit and carefully clean the lens using a cotton swab and alcohol.
Let us know the results.
Dan
Posted on Jul 21, 2008
Why did my Denon Carousel CD player stop working and can it be fixed?
I'm not sure if this will help, but when that happened to my CD player the solution was very simple. I removed the outter cover and took a Q-tip dampened with some alcohol and cleaned the little lens that reads the cd. It's a very common problem, and the fact that yours is 15 years old guarentees the lens is dirty. Some people trash their stero when It could've been good as new with just a Q-tip & little alcohol.
I hope it works!
Laura
Mar 05, 2015 | Denon Audio Players & Recorders
Denon AVR and PS3 issues
Sounds like a problem with the digital board. Expensive fix - hope it's still under warranty.
Jul 02, 2013 | Audio Players & Recorders
Tray error on a denon dn 4000
The cd transport is up the swanny (broken , kaput).
take it to your nearest registered denon repair/service centre
Sep 05, 2012 | Audio Players & Recorders
How to replace the lens dvd 3800
To replace the lens of the Denon DVD-3800 is very easy.
First umplug the television, then you unscrew the screws you find around it holding it together, once you unscrew the screws, you will be able to lift off the top cover, when you remove the top cover, you will have direct access to the disc tray, unscrew it from the sides, then you will be able to lift off the disc tray also, then you can disconnect the lens from the cable attached to it, then you will be able to fix in a new lens.
After doing this, reverse the process to reassemble the Denon DVD-3800 DVD player back together.
Take care and good luck
Oct 28, 2010 | Denon DVD-3800 DVD Player
I have a denon 3500 cd player my cd is stuck
Open the top cover of your CD using a screw driver, (usually a star screw driver),. Then, manually turn the driving gear of the CD tray to free the stucked tray and until to the point where you can take the disc from the tray. Be careful so the setting of the tray and the laser eye is not change. Then, close the close the cover and play. You can send your e-mail thru fix ya to let me know.
Sep 25, 2009 | Sony CDP-C910 10-Disc CD Changer
XBOX360 WONT READ DISC
Though i fixed the Disc Read Error myself within anhour but please test the below method at your OWN Risk. Please alsonote that microsoft is no longer providing Extended warranty for E74Error.
Check out this DIY Video Guide,that explains step by step instructions to fix Disc Read Error yourselfwithin an hour. It also provides the money back guarantee in case youare not satisfied. As i fixed my Xbox myself so i thought to share itwith you guys....
Apr 06, 2009 | Microsoft Xbox 360 Console
Loading disc and reading
Check out this DIY Video Guide,that explains step by step instructions to fix Disc Read Error yourselfwithin an hour. It also provides the money back guarantee in case youare not satisfied. As i fixed my Xbox myself so i thought to share itwith you guys.......
Mar 26, 2009 | Microsoft Xbox 360 Console
When i put the disc in the xbox it says reading then about 3 seconds after it says open tray
Check out this DIY Video Guide,that explains step by step instructions to fix Disc Read Error yourselfwithin an hour. It also provides the money back guarantee in case youare not satisfied. As i fixed my Xbox myself so i thought to share itwith you guys...............
Nov 28, 2008 | Microsoft Xbox 360 Console
Cd tray won't open
It is Koss brand,you shouldn't expect much from it. You could have an A/V repair guy to fix it for you or buy a better brand like panasonic,denon, or even samsung.
Oct 19, 2007 | Koss KS2503 System
CD Changer
You can probably fix it yourself but you may need some parts. Here's Denon's link that'll take you to the next step http://www.usa.denon.com/
May 09, 2007 | Denon D-M50S CD Shelf System
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
