You\'re in luck! Go to the Krups Online Store (krupsonlinestore.com). They have a pusher KRW MS-4952202. It\'s clear plastic and the top is a bit different from that of the original white pusher, but it fits into the feed tube exactly right and has the same penetration. It lists for $6.99. I had to pay $6.95 for handling and shipping.
You're in luck! Go to the Krups Online Store (krupsonlinestore.com). They have a pusher KRW MS-4952202. It's clear plastic and the top is a bit different from that of the original white pusher, but it fits into the feed tube exactly right and has the same ***********. It lists for $6.99. I had to pay $6.95 for handling and shipping.
SOURCE: OPENING the JC-250 Juice Extractor
I have the same juicer and it works great. I dread the cleanup though. To take the mesh strainer out, you push down and turn the casing clockwise then pull the stainer up. Easier said then done I know but that' how the directions read. The makers forgot to put in, Pull the stainer straight up with everything you have.
Hope this helps.
SOURCE: manual for an OscarJuice Extractor ?
Here the manual for Oscar 900 that is quite similar, the operations and recipes should be the same.
SOURCE: rival juice extractor model 965
I HAVE LOST THE BOOK AND PAPERWORK TO MY RIVAL JUICE EXTRACTOR MODEL 965. IS IT POSSIBLE TO GET ANOTHER BOOK AND PAPERWORK FOR IT?
SOURCE: I have a Krups Vitamight model 294 juice
i was having the same problem and couldn't find it anywhere... finally figured out that you twist the top off. place the unit with front towards you.
pull/twist the right side (pulp catcher) towards you about a quarter turn and the entire top comes off including the sieve.
